Unknown command: $ in using check_eventlog with check_nrpe
raydx
Post by raydx »
I'm having an issue with check_eventlog with check_nrpe. The Nagios console displays:
Unknown command(s): $
From nagios.log:
[1544688000] CURRENT SERVICE STATE: per320-01;Applications errors;UNKNOWN;HARD;3;Unknown command(s): $
Service I'm using:
host_name per320-01,per320-02,svicsdlver01,svicsdlver03,svicsdlver04,
service_description Applications errors
check_command check_nrpe!check_eventlog -a "filter=provider = 'Application Error' and id = 1000 and message like 'Spacelabs.SLNIService.exe'"
nrpe.cfg and commands.cfg are attached.
Thanks!
commands.cfg
(7.85 KiB) Downloaded 370 times
nrpe.cfg
(12.18 KiB) Downloaded 374 times
danjoh
Re: Unknown command: $ in using check_eventlog with check_nr
Post by danjoh »
In commands.cfg you have
# 'check_nrpe' command definition
	command_name    check_nrpe
	command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -t 120 -c $ARGS$
I think that should be:
	command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -t 120 -c $ARG1$ -a $ARG2$
and the check should look like this:
        check_command check_nrpe!check_eventlog!"filter=provider = 'Application Error' and id = 1000 and message like 'Spacelabs.SLNIService.exe'"
And looking through your nrpe.cfg I do not see any command definition for "check_eventlog" .
D/\N
In addition to what @danjoh mentioned about the service definition, the service you have defined looks like something you would be running against a windows machine running nsclient++
Can you share the nsclient.ini from the windows machine?
raydx
Post by raydx »
Thank you @danjoh and @scottwilkerson for your assistance.
I up-dated commands.cfg and ICS.cfg. NRPE Plugin for Nagios is now displayed.
/usr/local/nagios/libexec does not contain check_eventlog
nsclient.ini is attached.
nsclient.ini
(1.56 KiB) Downloaded 515 times
raydx wrote:I up-dated commands.cfg and ICS.cfg. NRPE Plugin for Nagios is now displayed.
Is it now working as expected?
raydx wrote:/usr/local/nagios/libexec does not contain check_eventlog
It would not be in /usr/local/nagios/libexec, it is part of nsclient++
raydx
Post by raydx »
It is not working as expected.
What should I check on the windows machine that has NSClient++?
After making the change to the commands.cfg did you restart nagios?
what error are you getting in the UI after that? before it was this which was related to the error in the check_nrpe command
raydx
Post by raydx »
After making the changes to commands.cfg and ICS.cfg, nagios was re-started and
NRPE Plugin for Nagios was displayed in the Nagios console.
I reverted the changes and Unknown command(s): $ is displayed for all the check_eventlogs.
In checking the web for solutions, I did see that someone ran in
/usr/local/nagios/libexec$ ./check_nrpe - H 10.11.96.130 -t 30 -c check_event_log -a "file=security" "filetr=written 1t -2d" and NRPE: Command 'check_event_log' not defined is returned.
I am having difficulty with getting the correct command for nrpe.cfg.
Please show in your next post what you have configured for check_nrpe in the GUI
Also, the command you were trying to run before is different than what you are trying to run now from the CLI, try
./check_nrpe - H 10.11.96.130 -t 30 -c check_eventlog -a "filter=provider = 'Application Error' and id = 1000 and message like 'Spacelabs.SLNIService.exe'"
raydx
Post by raydx »
In re to "what you have configured for check_nrpe in the GUI", which file are you referring to?
In the CLI, in /usr/local/nagios/libexec$, I ran the command and CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
