Graph Explorer Graphs Not Adding to Dashboard
MikeMAN987
Re: Graph Explorer Graphs Not Adding to Dashboard
Post by MikeMAN987 »
Different error - mysqldump: Couldn't find table: "nagiosxi"
npolovenko
Post by npolovenko »
@MikeMAN987, Please try this command:
mysqldump -uroot -pnagiosxi nagiosxi xi_usermeta > /tmp/usermeta.sql
MikeMAN987
Thank you! sql sent.
npolovenko
@MikeMAN987, Please go to the Admin menu in XI, click on System Settings in the left column and go to the Security tab. Check the box
Frame Restrictions -> Disable - Do not restrict pages from being opened in iframes from anywhere. Update settings and let me know if that allows you to see the graphs.
MikeMAN987
Thanks for the suggestion. I tried that, however i still have a blank page when generating the data..
Since you are using SSL, can you verify that you have "https" in both places - the "Program URL", and "External URL" (Admin > System Config > System Settings)? Also, have you tried using an IP address, instead of a hostname in the same two fields? Does this make any difference?
MikeMAN987
Does not seem to matter updating and visiting by IP. https is indeed in that setting.
The reason I asked you to check if you have "https" in the "Program/External URL" is because I saw log entries as this one:
http://nagiosxi.mgic.net/nagiosxi/includes/components/graphexplorer/
Your Nagios XI instance is quite old. Is upgrading XI an option for you? There have been a numerous bug fixes/added features in the latest releases of XI, so upgrading your Nagios XI instance *may* fix the issue.
Another option would be to open a support ticket via our support center here:
https://support.nagios.com/tickets/
Our support technicians could offer a remote session to speed up the resolution of the problem.
