Centos/nagiosxi migration 7
sharding
Re: Centos/nagiosxi migration 7
Post by sharding »
whats the difference in
nagiosxi-5.5.8-1.el7.x86_64.tar.gz 96.00M 12/26/2018 11:40 -05:00 e1efa7c2d3f45d7ee2cdb14e99c298fc
nagiosxi-5.5.8-1.el6.x86_64.tar.gz 124.46M 12/26/2018 11:38 -05:00 48df3c69773bdfe2e5a2bc45e8429ac1
or is there a better place to get 5.5.8 from?
This is CentOS7
This is CentOS6
sharding
Post by sharding »
hhhhmmmmm
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.2
Last Modified: 2018-08-16
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 12 services.
Checked 1 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 2 contacts.
Checked 2 contact groups.
Checked 127 commands.
Checked 8 time periods.
Checked 0 host escalations.
Checked 1 hosts
Checked 0 host dependencies
Checked 8 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
> Return Code: 0
CCM data imported OK.
RESULT=0
Running './F-startdaemons'...
Daemons started OK
RESULT=0
Running './Z-webroot'...
RESULT=0
success
success
Error: Cannot open file php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm: [Errno 2] No such file or directory: 'php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm'
TypeError: an integer is required
FATAL ERROR: python callback <bound method RPMTransaction.callback of <yum.rpmtrans.RPMTransaction instance at 0x7f5a0b952050>> failed, aborting!
[root@nagiosxi2 nagiosxi]#
If you want the full log please let me know where to get it from
Where are you seeing this data? It looks like everything installed properly, not sure why you got an error regarding php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm
sharding
Post by sharding »
output from ./fullinstall script,
the login screen does come up on this though
now they are both 5.5.8 I'll carry on with migration, see what happens ;-)
sharding wrote:output from ./fullinstall script,
sounds good
sharding
Post by sharding »
ok so I worked throught the backup and restore doc. and ran the restore repair which was fine, I then saw the last nit that linked to
https://support.nagios.com/kb/article.php?id=166
the first block of code does not ever finish or even generate the perfdata tarball, do I have to do this step, if we don't care about moving over graph data?
is that the only thing that;s missing is the graph data?
You would only need to do any of that if you are switching from a 32bit to 64bit system.
sharding
Post by sharding »
which we are - my question is what data does it move?
it is not working as I mentioned , so if it needs to be done then I would prefer a remote session for assistance in doing this
If you don't care about moving over performance data (which can take hours to complete), you can just run the following on the new server
rm -rf /var/lib/mrtg/*
rm -rf /usr/local/nagios/share/perfdata/*
this will delete all the existing perfdata and allow new records to be created.
