Posts: 19396 Joined: Tue Nov 15, 2011 3:11 pm
Post
by scottwilkerson » Mon Aug 05, 2019 8:44 am
In your nsclient.ini under the section
You need to set
then restart NSCP
amitgupta19
Posts: 286 Joined: Fri Sep 08, 2017 5:53 am
Post
by amitgupta19 » Mon Aug 05, 2019 8:58 am
Hi Scott,
This section did not exist in the nsclient.ini file.
[/settings/NRPE/server]
So i added it manually on top of the file and then restarted the service NSClient++ .
After this it is giving the following error:
[xxxxxx@cblnagios01 libexec]$ ./check_nrpe -H xxx.xxx.xxx.xxx -p 5666 -c check_eventlog -a "filter=id=4003"
No file specified try adding: file=Application
Post
by scottwilkerson » Mon Aug 05, 2019 9:10 am
Lets try
./check_nrpe -H xxx.xxx.xxx.xxx -p 5666 -c check_eventlog -a "file=Application filter=id=4003"
amitgupta19
Post
by amitgupta19 » Mon Aug 05, 2019 10:00 am
Please find here with the output
[xxxxx@cblnagios01 libexec]$ ./check_nrpe -H xxx.xxx.xxx.xxx -p 5666 -c check_eventlog -a "file=Application filter=id=7002"
Parsing failed:
[xxxxx@cblnagios01 libexec]$ ./check_nrpe -H xxx.xxx.xxx.xxx -p 5666 -c check_eventlog -a "file=System filter=id=7002"
Parsing failed:
Regards
Amit
ssax
Dreams In Code
Posts: 7682 Joined: Wed Feb 11, 2015 12:54 pm
Post
by ssax » Mon Aug 05, 2019 4:10 pm
What does this show:
./check_nrpe -H xxx.xxx.xxx.xxx -p 5666 -c check_eventlog -a "show-default 'file=Application' 'filter=id=4003'"
amitgupta19
Post
by amitgupta19 » Tue Aug 06, 2019 4:53 am
[amgupta@cblnagios01 libexec]$ ./check_nrpe -H xxx.xxx.xxxx.xxx -p 5666 -c check_eventlog -a "show-default 'file=Application' 'filter=id=4003'"
Exception processing request: Request command contained illegal metachars!
amitgupta19
Post
by amitgupta19 » Wed Aug 07, 2019 9:45 am
Did anyone got a chance to look into this?
Post
by scottwilkerson » Thu Aug 08, 2019 8:43 am
What version of NSClient are you running?
Can you share your nsclient.ini ?
amitgupta19
Post
by amitgupta19 » Thu Aug 08, 2019 9:37 am
Version of the nsclient
[amgupta@cblnagios01 libexec]$ ./check_nrpe -H 172.23.1.83
I (0,4,1,105 2014-04-28) seem to be doing fine...
nsclient.ini is attached here with
nsclient.ini
NSCLIENT File (8.62 KiB) Downloaded 276 times
