Monitoring the Windows Event Log
amitgupta19
Post by amitgupta19 »
I am using the Nagios Core 4.4.3 on CentOS.
I have got the requirement to monitor the Windows Event Log.
Can anyone guide me how to do it using the NSClient++?
I know that we can do it using the Nagios Log Server as well, also can you point to any document which has all the details to achieve this using the Nagios Log Server.
Re: Monitoring the Windows Event Log
NSClient only can scan for pre-defined things, here is their documentation
https://docs.nsclient.org/reference/win ... kEventLog/
For Nagios Log Server, see this:
https://assets.nagios.com/downloads/nag ... Server.pdf
amitgupta19
I have the requirement to search only the some specific Event ID.
After going through the documentation for the NSClient, i could not find that how do i implement it?
Which script i need to download to my Nagios Server.
What command should i use?
Can you guide me?
In the "Checking for specific messages"section here
https://docs.nsclient.org/reference/win ... c-messages
You can see you can apply a filter and specify an id which corresponds to the event id
check_eventlog "filter=provider = 'Microsoft-Windows-Security-SPP' and id = 903"
or you could use just something like the following where the event id you want to use is 903
check_eventlog "filter=id = 903"
amitgupta19
Hi Scott,
Thanks for your response.
When i try to run the command manually it is giving the following error:
[xxxxxxxxx@cblnagios01 libexec]$ ./check_nrpe -H xxxxxxxx -p 5666 -c checkeventlog "filter=id=7002"
No file specified try adding: file=Application
If you can suggest me what command should i write in the commands.cfg file, and services.cfg file that will be great.
amitgupta19
Can anyone look into it?
benjaminsmith
Post by benjaminsmith »
Hi @amitgupta19 ,
The command doesn't look quite right, try running:
./check_nrpe -H xxxxxxxx -p 5666 -c check_eventlog - a "filter=id=7002"
Let me know if you get it working.
amitgupta19
Please find here with the update:
Error remains the same.
[xxxxxxx@cblnagios01 libexec]$ ./check_nrpe -H xxxxxxxx -p 5666 -c check_eventlog - a "filter=id=7002"
benjaminsmith
Hello @amitgupta19
It's working on my system.
It looks like there was an extra space in front of the a in the last command. My apologies, can you try it again?
./check_nrpe -H xxxxxxxx -p 5666 -c check_eventlog -a "filter=id=7002"
amitgupta19
Hi Benjamin,
Thanks for the clarification, i have typed the whole command instead of copy and pasting. Now it is giving a different e error:
[xxxxxxxx@cblnagios01 libexec]$ ./check_nrpe -H 172.16.xxx.xxx -p 5666 -c check_eventlog -a "filter=id=7002"
Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
