Unable to Create Users
tvoll
Re: Unable to Create Users
Post by tvoll »
Still having issues adding users from Active Directory.
I see in the /usr/local/nagioslogserver/var/jobs.log:
Running command do_backups with args ' ' for job id: backups
SUCCESS
Still not populating any new files into /store/backups/nagioslogserver/
mbellerue
Post by mbellerue »
Alright, that's a little odd. Try running the backup command at the command line.
/usr/local/nagioslogserver/scripts/create_backup.sh
tvoll
Post by tvoll »
mbellerue wrote:Alright, that's a little odd. Try running the backup command at the command line.
That worked! Sent a PM with the backup attached.
cdienger
Post by cdienger »
Received. We will PM you the next steps.
mbellerue
Post by mbellerue »
I've just sent a PM with further instructions.
tvoll
Post by tvoll »
mbellerue wrote:I've just sent a PM with further instructions.
Thank you! The commands that you sent worked.
It was an issue with the user mapping file.
Verified that adding new Active Directory users worked without any issues!
mbellerue
Post by mbellerue »
Most excellent, glad to hear it worked! Closing thread.
