Bulk host cloning and import bug
Benji
Re: Bulk host cloning and import bug
Post by Benji »
scottwilkerson wrote:
You should not clear the box if you want them replaced
I don't want them replaced, I want them added as the checkbox indicates.
I was able to re-create what you reported.
Attached is a fixed version of the wizard you can install through Admin -> Manage Config Wizards
Benji
Post by Benji »
scottwilkerson wrote:I was able to re-create what you reported.
Thanks! But I found another issue with this version. If parenthost or hostgroup are empty on the host being cloned, the imported parenthost or hostgroup is discarded. It will only add the imported value if there is something already there.
In my case, I've set up a template host that has a hostgroup, but no parenthost, that is being cloned. The hostgroup is now added to the existing list of hostgroups, but no parenthost is imported.
Thanks for catching this!
New version attached
Benji
Post by Benji »
scottwilkerson wrote:Thanks for catching this!
Perfect! Thanks for the quick turnaround!
Glad it is resolved!
Locking thread
