error occurred when restored NagiosXI and DeActive some item
xpertech
Re: error occurred when restored NagiosXI and DeActive some
Post by xpertech »
The configuration finally applied successful after follow your suggestions, but when systemctl start nagios, there's an error?
xpertech
Post by xpertech »
a question, why nagios service stop? is it because apply configuration failed so it stop, or there's other reason?
xpertech wrote:a question, why nagios service stop? is it because apply configuration failed so it stop, or there's other reason?
I'm glad to see it running again.
Nagios wouldn't stop because of an apply configuration failure because it doesn't do the restart until the config verifivation suceeds.
I'm not actually sure why it was stopped but that could have an affect.
Can you apply configuration now?
