error occurred when restored NagiosXI and DeActive some item
xpertech
Post by xpertech »
After restored NagiosXI configuration, then DeActive some items, when apply configuration, it failed?!
cdienger
Re: error occurred when restored NagiosXI and DeActive some
Post by cdienger »
What items did you deactivate? Are you able to apply configuration if you activate them?
The error indicates an issue with a service escalation under Configure > Core Config Manager > Alerting > Service Escalations not having a proper hostname or description set. What do the configurations under there look like?
Errors like this can also be caused from configurations gettings stuck in /usr/local/nagios/etc/import/. Remove any files you may find in there and try applying the configuration again.
xpertech
Post by xpertech »
information ...1
xpertech
Post by xpertech »
information ...2
ssax
Dreams In Code
Post by ssax »
Please go to Configure > Core Config Manager > Tools > Config File Management:
- Click the Delete Files button (don't worry, it's safe, they will be rewritten)
- Then click the Write Configs button
- Then click the Verify Files button, if it verifies properly, please try to Apply Configuration
That alone may fix it.
If it fails again, please do this (in these exact steps):
Please run this tail command (and leave it running):
tail -Fn0 /usr/local/nagiosxi/var/cmdsubsys.log
Then try to apply configuration through the web interface and once it completes/errors send me the full output from the tail command above.
If all that doesn't fix it, do this:
Go to Configure > Core Config Manager > Tools > Config File Management:
- Once they are done being written (don't do anything in between, don't apply config or anything), run this command and send me the resulting /tmp/NAGIOSBADFILES.zip file:
zip -r /tmp/NAGIOSBADFILES.zip /usr/local/nagios/etc
Please send me a copy of your profile as well, you can download it from Admin > System Profile > Download Profile and upload it to the ticket by clicking the "choose item" link at the bottom of the menu.​ Make sure to wait until the file is finished uploading before clicking the Post Reply button.
xpertech
Post by xpertech »
still problem ...
xpertech
Post by xpertech »
attachment ...
Did you do the following?
ssax wrote:Please go to Configure > Core Config Manager > Tools > Config File Management:
Also, I noted that in your first screenshot there was the red ! next to your username in the upper right. Can you go to Admin -> System Status and send a screenshot of the status?
We also need to see if all items are running properly.
xpertech
Post by xpertech »
Already PM you...
Looks like the service cannot restart
Can you show the output of
systemctl status nagios.service
then lets run
systemctl stop nagios
killall -9 nagios
rm -f /var/run/nagios.lock
systemctl start nagios
