upgrade from xi-5.4.5 to 5.5.0 and then the latest in UI
benjaminsmith
Re: upgrade from xi-5.4.5 to 5.5.0 and then the latest in UI
Post by benjaminsmith »
Hi Irene,
Installing two servers on one host is not supported. Please open a support ticket for faster resolution on this issue and reference this post. Please run the installer once more and provide the full output of the log in the ticket.
Thanks.
To open a support ticket go to:
https://support.nagios.com/tickets/
iwang
Post by iwang »
hi i got another env and i am trying to do a fresh installation from tarball. the ./fullinstall still fails with the error:
Error: Package: nagiosxi-5.6.10-1.el6.x86_64 (/nagiosxi-5.6.10-1.el6.x86_64)
           Requires: php-imap
           Requires: mysql
           Requires: postgresql-server
           Requires: php-devel
           Requires: mysql-server
           Requires: net-snmp-perl
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
and yum repo list:
-bash-4.1# yum repolist
Loaded plugins: enabled_repos_upload, fastestmirror, package_upload, product-id, security, subscription-manager
certificate verify failed
Loading mirror speeds from cached hostfile
 * epel: mirror.sjc02.svwh.net
repo id                                    repo name        status
epel                                       Extra Packages for Enterprise Linux 6 - x86_64                               12,584
nagios-base                                Nagios        171
nagiosxi-deps                              Nagios XI Dependencies                                                           33
repolist: 12,788
Uploading Enabled Repositories Report
Loaded plugins: fastestmirror, product-id
Unable to upload Enabled Repositories Report
# cat /etc/yum.repos.d/epel.repo
[epel]
name=Extra Packages for Enterprise Linux 6 - $basearch
#baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch
mirrorlist=http://mirrors.fedoraproject.org/metalink?repo=epel-6&arch=$basearch
failovermethod=priority
enabled=1
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-6
[epel-debuginfo]
name=Extra Packages for Enterprise Linux 6 - $basearch - Debug
#baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch/debug
mirrorlist=http://mirrors.fedoraproject.org/metalink?repo=epel-debug-6&arch=$basearch
enabled=0
gpgcheck=1
[epel-source]
name=Extra Packages for Enterprise Linux 6 - $basearch - Source
#baseurl=http://download.fedoraproject.org/pub/epel/6/SRPMS
mirrorlist=http://mirrors.fedoraproject.org/metalink?repo=epel-source-6&arch=$basearch
enabled=0
gpgcheck=1
-bash-4.1# uname -a
Linux scclnagiosxi02.dvms.local 2.6.32-573.18.1.el6.x86_64 #1 SMP Tue Feb 9 22:46:17 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
-bash-4.1# cat /etc/redhat-release
CentOS release 6.7 (Final)
Looks like your instance cannot connect to the RedHat base repositories, is it registered?
iwang
Post by iwang »
it's a centOS machine if you check the previous thread. but now i got a fresh new machine, which is redhat 7. i got different error when I do fresh installation:
--> Processing Conflict: php56u-pdo-5.6.34-1.ius.el7.x86_64 conflicts php-pdo < 5.6
Error: mariadb101u-common conflicts with 1:mariadb-libs-5.5.60-1.el7_5.x86_64
Error: php72u-pdo conflicts with php-pdo-5.4.16-46.el7.x86_64
Error: php72u-cli conflicts with php56u-cli-5.6.34-1.ius.el7.x86_64
Error: php56u-pdo conflicts with php-pdo-5.4.16-46.el7.x86_64
Error: php72u-pdo conflicts with php56u-pdo-5.6.34-1.ius.el7.x86_64
Error: mariadb101u-libs conflicts with 1:mariadb-libs-5.5.60-1.el7_5.x86_64
Error: mariadb101u-errmsg conflicts with 1:mariadb-libs-5.5.60-1.el7_5.x86_64
Error: php72u-common conflicts with php-common-5.4.16-46.el7.x86_64
Error: mariadb101u-config conflicts with 1:mariadb-libs-5.5.60-1.el7_5.x86_64
Error: php72u-xml conflicts with php56u-xml-5.6.34-1.ius.el7.x86_64
Error: php56u-common conflicts with php-common-5.4.16-46.el7.x86_64
Error: php72u-common conflicts with php56u-common-5.6.34-1.ius.el7.x86_64
Loaded plugins: product-id, subscription-manager
$ cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.6 (Maipo)
root@scclnagiosxi02:/tmp/rpms/nagiosxi$ yum repolist
Loaded plugins: enabled_repos_upload, package_upload, product-id, search-disabled-repos, subscription-manager
DataServices_EPEL_EPEL_7        | 2.8 kB  00:00:00
DataServices_ISRG-builds_isrg-builds                                                             | 2.1 kB  00:00:00
DataServices_ius_IUS        | 1.8 kB  00:00:00
rhel-7-server-optional-rpms        | 2.0 kB  00:00:00
rhel-7-server-rpms        | 2.0 kB  00:00:00
rhel-7-server-satellite-tools-6.4-rpms                                                           | 2.1 kB  00:00:00
rhel-7-server-supplementary-rpms        | 2.0 kB  00:00:00
rhel-server-rhscl-7-rpms        | 2.0 kB  00:00:00
(1/3): rhel-7-server-supplementary-rpms/7Server/x86_64/group                                     |  35 kB  00:00:00
(2/3): rhel-7-server-supplementary-rpms/7Server/x86_64/updateinfo                                |  72 kB  00:00:00
(3/3): rhel-7-server-supplementary-rpms/7Server/x86_64/primary                                   | 105 kB  00:00:00
rhel-7-server-supplementary-rpms        322/322
DataServices_EPEL_EPEL_7                        EPEL 7                                                            13,242
DataServices_ISRG-builds_isrg-builds            isrg-builds                                                            5
DataServices_ius_IUS                            IUS Community Packages for Enterprise Linux                          467
dockerrepo                                      Docker Repository                                                    110
epel/x86_64                                     Extra Packages for Enterprise Linux 7 - x86_64                    13,524
nagios-base                                     Nagios        96
nagiosxi-deps                                   Nagios XI Dependencies                                                31
rhel-7-server-optional-rpms/7Server/x86_64      Red Hat Enterprise Linux 7 Server - Optional (RPMs)               17,790
rhel-7-server-rpms/7Server/x86_64               Red Hat Enterprise Linux 7 Server (RPMs)                          24,398
rhel-7-server-satellite-tools-6.4-rpms/x86_64   Red Hat Satellite Tools 6.4 (for RHEL 7 Server) (RPMs)                81
rhel-7-server-supplementary-rpms/7Server/x86_64 Red Hat Enterprise Linux 7 Server - Supplementary (RPMs)             322
rhel-server-rhscl-7-rpms/7Server/x86_64         Red Hat Software Collections RPMs for Red Hat Enterprise Linux 7  11,241
repolist: 81,307
From our install doc
Important: Nagios Enterprises highly recommends and will only support installing Nagios XI on a newly installed, "clean" system (a bare minimal install with nothing else installed or configured).
https://assets.nagios.com/downloads/nag ... -Linux.pdf
the system you are installing on has numerous repositories added as well as various version of PHP installed already which is going to present a problem with Nagios XI.
iwang
Post by iwang »
i've solved the issue on the fresh env. but because of the complexity of moving the client agents' configuration. i have to pivot back to the old nagios server. i had resolved the php conflict problem origically i requested in this thread via remi repository. but i still got following errors:
# ./upgrade
Plugin "enabled_repos_upload" can't be imported
Plugin "package_upload" can't be imported
Plugin "product-id" can't be imported
Plugin "subscription-manager" can't be imported
Loaded plugins: fastestmirror, security
Setting up Local Package Process
Examining fping-3.10-1.el6.rf.x86_64.rpm: fping-3.10-1.el6.rf.x86_64
fping-3.10-1.el6.rf.x86_64.rpm: does not update installed package.
Examining freetds-0.91-2.el6.x86_64.rpm: freetds-0.91-2.el6.x86_64
freetds-0.91-2.el6.x86_64.rpm: does not update installed package.
Examining libmcrypt-2.5.8-9.el6.x86_64.rpm: libmcrypt-2.5.8-9.el6.x86_64
libmcrypt-2.5.8-9.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-5.6.10-1.el6.x86_64.rpm: nagiosxi-5.6.10-1.el6.x86_64
Marking nagiosxi-5.6.10-1.el6.x86_64.rpm to be installed
 * epel: mirrors.sonic.net
 * remi-safe: remi.xpg.com.br
Examining nagiosxi-mrtg-5.6.10-1.el6.x86_64.rpm: nagiosxi-mrtg-5.6.10-1.el6.x86_64
nagiosxi-mrtg-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nagioscore-5.6.10-1.el6.x86_64.rpm: nagiosxi-nagioscore-5.6.10-1.el6.x86_64
nagiosxi-nagioscore-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nagiosmobile-5.6.10-1.el6.x86_64.rpm: nagiosxi-nagiosmobile-5.6.10-1.el6.x86_64
nagiosxi-nagiosmobile-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nagiosplugins-5.6.10-1.el6.x86_64.rpm: nagiosxi-nagiosplugins-5.6.10-1.el6.x86_64
nagiosxi-nagiosplugins-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nagvis-5.6.10-1.el6.x86_64.rpm: nagiosxi-nagvis-5.6.10-1.el6.x86_64
nagiosxi-nagvis-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-ndoutils-5.6.10-1.el6.x86_64.rpm: nagiosxi-ndoutils-5.6.10-1.el6.x86_64
nagiosxi-ndoutils-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nrds-5.6.10-1.el6.x86_64.rpm: nagiosxi-nrds-5.6.10-1.el6.x86_64
nagiosxi-nrds-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nrpe-5.6.10-1.el6.x86_64.rpm: nagiosxi-nrpe-5.6.10-1.el6.x86_64
nagiosxi-nrpe-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nsca-5.6.10-1.el6.x86_64.rpm: nagiosxi-nsca-5.6.10-1.el6.x86_64
nagiosxi-nsca-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-nxti-5.6.10-1.el6.x86_64.rpm: nagiosxi-nxti-5.6.10-1.el6.x86_64
nagiosxi-nxti-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-pnp-5.6.10-1.el6.x86_64.rpm: nagiosxi-pnp-5.6.10-1.el6.x86_64
nagiosxi-pnp-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-shellinabox-5.6.10-1.el6.x86_64.rpm: nagiosxi-shellinabox-5.6.10-1.el6.x86_64
Marking nagiosxi-shellinabox-5.6.10-1.el6.x86_64.rpm to be installed
Examining nagiosxi-wkhtmltox-5.6.10-1.el6.x86_64.rpm: nagiosxi-wkhtmltox-5.6.10-1.el6.x86_64
nagiosxi-wkhtmltox-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nagiosxi-wmic-5.6.10-1.el6.x86_64.rpm: nagiosxi-wmic-5.6.10-1.el6.x86_64
nagiosxi-wmic-5.6.10-1.el6.x86_64.rpm: does not update installed package.
Examining nmap-6.47-1.x86_64.rpm: 2:nmap-6.47-1.x86_64
nmap-6.47-1.x86_64.rpm: does not update installed package.
Examining perl-Config-IniFiles-2.72-2.el6.noarch.rpm: perl-Config-IniFiles-2.72-2.el6.noarch
perl-Config-IniFiles-2.72-2.el6.noarch.rpm: does not update installed package.
Examining perl-Crypt-DES-2.05-9.el6.x86_64.rpm: perl-Crypt-DES-2.05-9.el6.x86_64
perl-Crypt-DES-2.05-9.el6.x86_64.rpm: does not update installed package.
Examining perl-Crypt-Rijndael-1.09-2.el6.x86_64.rpm: perl-Crypt-Rijndael-1.09-2.el6.x86_64
perl-Crypt-Rijndael-1.09-2.el6.x86_64.rpm: does not update installed package.
Examining perl-Mail-IMAPClient-3.37-1.el6.noarch.rpm: perl-Mail-IMAPClient-3.37-1.el6.noarch
perl-Mail-IMAPClient-3.37-1.el6.noarch.rpm: does not update installed package.
Examining perl-Mail-POP3Client-2.18-6.el6.noarch.rpm: perl-Mail-POP3Client-2.18-6.el6.noarch
perl-Mail-POP3Client-2.18-6.el6.noarch.rpm: does not update installed package.
Examining perl-Math-Calc-Units-1.07-6.el6.noarch.rpm: perl-Math-Calc-Units-1.07-6.el6.noarch
perl-Math-Calc-Units-1.07-6.el6.noarch.rpm: does not update installed package.
Examining perl-Nagios-Monitoring-Plugin-0.51-1.el6.noarch.rpm: perl-Nagios-Monitoring-Plugin-0.51-1.el6.noarch
perl-Nagios-Monitoring-Plugin-0.51-1.el6.noarch.rpm: does not update installed package.
Examining perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch.rpm: perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch
perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch.rpm: does not update installed package.
Examining perl-Net-SNMP-5.2.0-4.el6.noarch.rpm: perl-Net-SNMP-5.2.0-4.el6.noarch
perl-Net-SNMP-5.2.0-4.el6.noarch.rpm: does not update installed package.
Examining perl-Number-Format-1.73-3.el6.noarch.rpm: perl-Number-Format-1.73-3.el6.noarch
perl-Number-Format-1.73-3.el6.noarch.rpm: does not update installed package.
Examining php-common-5.3.3-46.el6_6.x86_64.rpm: php-common-5.3.3-46.el6_6.x86_64
php-common-5.3.3-46.el6_6.x86_64.rpm: does not update installed package.
Examining php-mcrypt-5.3.3-5.el6.x86_64.rpm: php-mcrypt-5.3.3-5.el6.x86_64
php-mcrypt-5.3.3-5.el6.x86_64.rpm: does not update installed package.
Examining php-mssql-5.3.3-5.el6.x86_64.rpm: php-mssql-5.3.3-5.el6.x86_64
php-mssql-5.3.3-5.el6.x86_64.rpm: does not update installed package.
Examining php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm: php-pear-HTML-Template-IT-1.3.0-2.el5.noarch
php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm: does not update installed package.
Examining php-pecl-ssh2-0.11.0-7.el6.x86_64.rpm: php-pecl-ssh2-0.11.0-7.el6.x86_64
php-pecl-ssh2-0.11.0-7.el6.x86_64.rpm: does not update installed package.
Examining pymssql-1.0.2-4.el6.x86_64.rpm: pymssql-1.0.2-4.el6.x86_64
pymssql-1.0.2-4.el6.x86_64.rpm: does not update installed package.
Examining python-bson-2.5.2-3.el6.1.x86_64.rpm: python-bson-2.5.2-3.el6.1.x86_64
python-bson-2.5.2-3.el6.1.x86_64.rpm: does not update installed package.
Examining python-pymongo-2.5.2-3.el6.1.x86_64.rpm: python-pymongo-2.5.2-3.el6.1.x86_64
python-pymongo-2.5.2-3.el6.1.x86_64.rpm: does not update installed package.
Resolving Dependencies
--> Running transaction check
---> Package nagiosxi.x86_64 0:5.6.10-1.el6 will be installed
--> Processing Dependency: net-snmp-perl for package: nagiosxi-5.6.10-1.el6.x86_64
---> Package nagiosxi-shellinabox.x86_64 0:5.6.10-1.el6 will be installed
---> Package net-snmp-perl.x86_64 1:5.5-54.el6_7.1 will be installed
--> Processing Dependency: net-snmp-libs = 1:5.5-54.el6_7.1 for package: 1:net-snmp-perl-5.5-54.el6_7.1.x86_64
---> Package net-snmp-libs.i686 1:5.5-54.el6_7.1 will be installed
--> Processing Dependency: libz.so.1 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libwrap.so.0 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libutil.so.1 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libsensors.so.4 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: librpmio.so.1 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: librpm.so.1 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libresolv.so.2 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libpthread.so.0(GLIBC_2.2) for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libpthread.so.0(GLIBC_2.0) for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libpthread.so.0 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libpopt.so.0 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libperl.so for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libnsl.so.1 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libm.so.6 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libdl.so.2(GLIBC_2.1) for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libdl.so.2(GLIBC_2.0) for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libdl.so.2 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libcrypto.so.10(libcrypto.so.10) for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libcrypto.so.10(OPENSSL_1.0.1) for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libcrypto.so.10 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libcrypt.so.1 for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
--> Processing Dependency: libc.so.6(GLIBC_2.7) for package: 1:net-snmp-libs-5.5-54.el6_7.1.i686
---> Package glibc.i686 0:2.12-1.166.el6_7.7 will be installed
--> Processing Dependency: libfreebl3.so(NSSRAWHASH_3.12.3) for package: glibc-2.12-1.166.el6_7.7.i686
--> Processing Dependency: libfreebl3.so for package: glibc-2.12-1.166.el6_7.7.i686
---> Package lm_sensors-libs.i686 0:3.1.1-17.el6 will be installed
---> Package openssl.i686 0:1.0.1e-42.el6_7.4 will be installed
--> Processing Dependency: libkrb5.so.3(krb5_3_MIT) for package: openssl-1.0.1e-42.el6_7.4.i686
--> Processing Dependency: libkrb5.so.3 for package: openssl-1.0.1e-42.el6_7.4.i686
--> Processing Dependency: libk5crypto.so.3(k5crypto_3_MIT) for package: openssl-1.0.1e-42.el6_7.4.i686
--> Processing Dependency: libk5crypto.so.3 for package: openssl-1.0.1e-42.el6_7.4.i686
--> Processing Dependency: libgssapi_krb5.so.2 for package: openssl-1.0.1e-42.el6_7.4.i686
--> Processing Dependency: libcom_err.so.2 for package: openssl-1.0.1e-42.el6_7.4.i686
---> Package perl-libs.i686 4:5.10.1-141.el6_7.1 will be installed
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 4:perl-libs-5.10.1-141.el6_7.1.i686
---> Package popt.i686 0:1.13-7.el6 will be installed
---> Package rpm-libs.i686 0:4.8.0-47.el6 will be installed
--> Processing Dependency: libcap(x86-32) >= 2.16 for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libselinux.so.1 for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libnss3.so(NSS_3.4) for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libnss3.so(NSS_3.2) for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libnss3.so(NSS_3.11.2) for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libnss3.so(NSS_3.10) for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libnss3.so for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libmagic.so.1 for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: liblzma.so.0 for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: liblua-5.1.so for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libgcc_s.so.1(GCC_3.3.1) for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libgcc_s.so.1(GCC_3.0) for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libgcc_s.so.1 for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libelf.so.1(ELFUTILS_1.1.1) for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libelf.so.1(ELFUTILS_1.0) for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libelf.so.1 for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libdb-4.7.so for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libcap.so.2 for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libbz2.so.1 for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libacl.so.1(ACL_1.0) for package: rpm-libs-4.8.0-47.el6.i686
--> Processing Dependency: libacl.so.1 for package: rpm-libs-4.8.0-47.el6.i686
---> Package tcp_wrappers-libs.i686 0:7.6-57.el6 will be installed
---> Package zlib.i686 0:1.2.3-29.el6 will be installed
---> Package bzip2-libs.i686 0:1.0.5-7.el6_0 will be installed
---> Package db4.i686 0:4.7.25-20.el6_7 will be installed
---> Package elfutils-libelf.i686 0:0.161-3.el6 will be installed
---> Package file-libs.i686 0:5.04-21.el6 will be installed
---> Package krb5-libs.i686 0:1.10.3-42.el6 will be installed
--> Processing Dependency: libkeyutils.so.1(KEYUTILS_0.3) for package: krb5-libs-1.10.3-42.el6.i686
--> Processing Dependency: libkeyutils.so.1 for package: krb5-libs-1.10.3-42.el6.i686
---> Package libacl.i686 0:2.2.49-6.el6 will be installed
--> Processing Dependency: libattr.so.1(ATTR_1.0) for package: libacl-2.2.49-6.el6.i686
--> Processing Dependency: libattr.so.1 for package: libacl-2.2.49-6.el6.i686
---> Package libcap.i686 0:2.16-5.5.el6 will be installed
---> Package libcom_err.i686 0:1.41.12-22.el6 will be installed
---> Package libgcc.i686 0:4.4.7-16.el6 will be installed
---> Package libselinux.i686 0:2.0.94-5.8.el6 will be installed
---> Package lua.i686 0:5.1.4-4.1.el6 will be installed
--> Processing Dependency: libreadline.so.6 for package: lua-5.1.4-4.1.el6.i686
--> Processing Dependency: libncurses.so.5 for package: lua-5.1.4-4.1.el6.i686
---> Package nss.i686 0:3.19.1-8.el6_7 will be installed
--> Processing Dependency: nss-softokn(x86-32) >= 3.14.3-22 for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libsoftokn3.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libplds4.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libplc4.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.17.1) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.15) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.14) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.13) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.12.5) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.12.3) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.12) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssdbm3.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnspr4.so for package: nss-3.19.1-8.el6_7.i686
---> Package nss-softokn-freebl.i686 0:3.14.3-23.el6_7 will be installed
---> Package xz-libs.i686 0:4.999.9-0.5.beta.20091007git.el6 will be installed
---> Package keyutils-libs.i686 0:1.4-5.el6 will be installed
---> Package libattr.i686 0:2.4.44-7.el6 will be installed
---> Package ncurses-libs.i686 0:5.7-4.20090207.el6 will be installed
---> Package nspr.i686 0:4.10.8-2.el6_7 will be installed
---> Package nss-softokn.i686 0:3.14.3-23.el6_7 will be installed
--> Processing Dependency: libsqlite3.so.0 for package: nss-softokn-3.14.3-23.el6_7.i686
---> Package nss-util.i686 0:3.19.1-5.el6_7 will be installed
---> Package readline.i686 0:6.0-4.el6 will be installed
---> Package sqlite.i686 0:3.6.20-1.el6_7.2 will be installed
--> Processing Conflict: nagiosxi-shellinabox-5.6.10-1.el6.x86_64 conflicts shellinabox
No package matched to upgrade: nagiosxi-shellinabox
Error: nagiosxi-shellinabox conflicts with shellinabox-2.20-5.el6.x86_64
Error: Package: 4:perl-libs-5.10.1-141.el6_7.1.i686 (updates)
           Requires: perl = 4:5.10.1-141.el6_7.1
           Installed: 4:perl-5.10.1-144.el6.x86_64 (@base)
               perl = 4:5.10.1-144.el6
           Available: 4:perl-5.10.1-141.el6.x86_64 (base)
           Available: 4:perl-5.10.1-141.el6_7.1.x86_64 (updates)
can you help please take a look? really appreciated.
Now it looks like you are installing an rpm upgrade when before you were using the manual upgrade from source?
You may be able to get past this blocker by running
yum remove shellinabox -y
but I suspect there will be more
iwang
Post by iwang »
scottwilkerson wrote:Now it looks like you are installing an rpm upgrade when before you were using the manual upgrade from source?
i did above step but i got the same error. and here is the repo information:
base                     CentOS-6 - Base                                                             6,575
cr                       CentOS-6 - CR        0
extras                   CentOS-6 - Extras                                                              50
remi-safe                Safe Remi's RPM repository for Enterprise Linux 6 - x86_64                  2,894
updates                  CentOS-6 - Updates                                                          1,263
repolist: 23,366
you did that and are still receiving this error?
Also, are you sure this server was installed from offline RPM to begin with and not source?
iwang
Post by iwang »
hi Scott,
it's upgrade from offline tarball not fresh installation.
as mentioned i am not clear about the migration challenges that's why i had moved back to work on the original nagios server.
