upgrade from xi-5.4.5 to 5.5.0 and then the latest in UI
iwang
Post by iwang »
since i was blocked to upgrade to the latest directly from GUI/manual/tarball(in the other thread), i move forward to upgrade from 5.4.5 to 5.5.0 with offline upgrade mode. there are some errors at the end from the terminal(attached). but from UI, it showed up as 5.5.0. and then when i click upgrade from GUI, the GUI upgrade panel showed as blank with message "Update in progress. Please wait. Update may take a few minutes" and takes forever. attached the errors here.
thank you for your assistant.
cat /var/log/httpd/error_log
[Sat Jan 25 14:00:26 2020] [notice] caught SIGTERM, shutting down
[Sat Jan 25 14:00:26 2020] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Jan 25 14:00:26 2020] [notice] Digest: generating secret for digest authentication ...
[Sat Jan 25 14:00:26 2020] [notice] Digest: done
[Sat Jan 25 14:00:26 2020] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Sat Jan 25 14:05:03 2020] [notice] caught SIGTERM, shutting down
[Sat Jan 25 14:05:03 2020] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Jan 25 14:05:03 2020] [notice] Digest: generating secret for digest authentication ...
[Sat Jan 25 14:05:03 2020] [notice] Digest: done
[Sat Jan 25 14:05:03 2020] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Sat Jan 25 15:38:07 2020] [notice] caught SIGTERM, shutting down
[Sat Jan 25 15:38:07 2020] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Jan 25 15:38:07 2020] [notice] Digest: generating secret for digest authentication ...
[Sat Jan 25 15:38:07 2020] [notice] Digest: done
[Sat Jan 25 15:38:07 2020] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Sat Jan 25 15:41:44 2020] [notice] caught SIGTERM, shutting down
[Sat Jan 25 15:41:44 2020] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Jan 25 15:41:44 2020] [notice] Digest: generating secret for digest authentication ...
[Sat Jan 25 15:41:44 2020] [notice] Digest: done
[Sat Jan 25 15:41:44 2020] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Sat Jan 25 20:16:22 2020] [notice] caught SIGTERM, shutting down
[Sat Jan 25 20:16:22 2020] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Jan 25 20:16:22 2020] [notice] Digest: generating secret for digest authentication ...
[Sat Jan 25 20:16:22 2020] [notice] Digest: done
[Sat Jan 25 20:16:22 2020] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Sat Jan 25 20:17:40 2020] [notice] SIGHUP received.  Attempting to restart
httpd: Could not reliably determine the server's fully qualified domain name, using scclnagiosxi01.dvms.local for ServerName
[Sat Jan 25 20:17:40 2020] [notice] Digest: generating secret for digest authentication ...
[Sat Jan 25 20:17:40 2020] [notice] Digest: done
[Sat Jan 25 20:17:40 2020] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Sat Jan 25 20:20:49 2020] [notice] caught SIGTERM, shutting down
[Sat Jan 25 20:20:49 2020] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Jan 25 20:20:49 2020] [notice] Digest: generating secret for digest authentication ...
[Sat Jan 25 20:20:49 2020] [notice] Digest: done
[Sat Jan 25 20:20:49 2020] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Sat Jan 25 20:39:58 2020] [error] [client 100.74.199.87] PHP Notice:  Undefined index: auth_type in /usr/local/nagiosxi/html/includes/components/scheduledbackups/managebackups.php on line 0, referer: http://scclnagiosxi01.dvms.local/nagiosxi/admin/
[Sat Jan 25 20:39:58 2020] [error] [client 100.74.199.87] PHP Notice:  Undefined index: pubkey_file in /usr/local/nagiosxi/html/includes/components/scheduledbackups/managebackups.php on line 0, referer: http://scclnagiosxi01.dvms.local/nagiosxi/admin/
[Sat Jan 25 20:39:58 2020] [error] [client 100.74.199.87] PHP Notice:  Undefined index: privkey_file in /usr/local/nagiosxi/html/includes/components/scheduledbackups/managebackups.php on line 0, referer: http://scclnagiosxi01.dvms.local/nagiosxi/admin/
[Sat Jan 25 20:39:58 2020] [error] [client 100.74.199.87] PHP Notice:  Undefined index: privkey_password in /usr/local/nagiosxi/html/includes/components/scheduledbackups/managebackups.php on line 0, referer: http://scclnagiosxi01.dvms.local/nagiosxi/admin/
You have new mail in /var/spool/mail/root
-bash-4.1# /etc/init.d/httpd status
httpd (pid  25504) is running...
-bash-4.1# cat /etc/httpd/conf.d/nagios
errors from the offline tarball upgrade:
---> Package nss.i686 0:3.19.1-8.el6_7 will be installed
--> Processing Dependency: nss-softokn(x86-32) >= 3.14.3-22 for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libsoftokn3.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libplds4.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libplc4.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.17.1) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.15) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.14) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.13) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.12.5) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.12.3) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so(NSSUTIL_3.12) for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssutil3.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnssdbm3.so for package: nss-3.19.1-8.el6_7.i686
--> Processing Dependency: libnspr4.so for package: nss-3.19.1-8.el6_7.i686
---> Package nss-softokn-freebl.i686 0:3.14.3-23.el6_7 will be installed
---> Package perl-libs.i686 4:5.10.1-141.el6_7.1 will be installed
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 4:perl-libs-5.10.1-141.el6_7.1.i686
---> Package xz-libs.i686 0:4.999.9-0.5.beta.20091007git.el6 will be installed
--> Running transaction check
---> Package keyutils-libs.i686 0:1.4-5.el6 will be installed
---> Package libattr.i686 0:2.4.44-7.el6 will be installed
---> Package ncurses-libs.i686 0:5.7-4.20090207.el6 will be installed
---> Package nspr.i686 0:4.10.8-2.el6_7 will be installed
---> Package nss-softokn.i686 0:3.14.3-23.el6_7 will be installed
--> Processing Dependency: libsqlite3.so.0 for package: nss-softokn-3.14.3-23.el6_7.i686
---> Package nss-util.x86_64 0:3.19.1-2.el6_7 will be updated
---> Package nss-util.i686 0:3.19.1-5.el6_7 will be installed
---> Package nss-util.x86_64 0:3.19.1-5.el6_7 will be an update
---> Package readline.i686 0:6.0-4.el6 will be installed
---> Package sqlite.i686 0:3.6.20-1.el6_7.2 will be installed
Error: Package: 4:perl-libs-5.10.1-141.el6_7.1.i686 (updates)
           Requires: perl = 4:5.10.1-141.el6_7.1
           Installed: 4:perl-5.10.1-144.el6.x86_64 (@base)
               perl = 4:5.10.1-144.el6
           Available: 4:perl-5.10.1-141.el6.x86_64 (base)
           Available: 4:perl-5.10.1-141.el6_7.1.x86_64 (updates)
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
Uploading Enabled Repositories Report
Loaded plugins: fastestmirror, product-id
Unable to upload Enabled Repositories Report
Download & installing supporting files
--2020-01-25 20:20:52--  http://assets.nagios.com/downloads/support/snmptrap-bins.tar.bz2
Resolving assets.nagios.com... 72.14.181.71, 2600:3c00::f03c:91ff:fedf:b821
Connecting to assets.nagios.com|72.14.181.71|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://assets.nagios.com/downloads/support/snmptrap-bins.tar.bz2 [following]
--2020-01-25 20:20:52--  https://assets.nagios.com/downloads/support/snmptrap-bins.tar.bz2
Connecting to assets.nagios.com|72.14.181.71|:443... connected.
Length: 8873 (8.7K) [application/x-bzip2]
Saving to: “snmptrap-bins.tar.bz2”
100%[================================================================>] 8,873       --.-K/s   in 0s
2020-01-25 20:20:52 (203 MB/s) - “snmptrap-bins.tar.bz2” saved [8873/8873]
Updating snmptt.ini
cp: cannot stat `/etc/snmp/snmptt.ini': No such file or directory
sed: can't read /etc/snmp/snmptt.ini: No such file or directory
Creating snmptrapd.conf
Adding the snmptt user to the nagios and nagcmd groups
usermod: user 'snmptt' does not exist
Modifying permissions
/bin/chown: cannot access `/etc/snmp/snmptt.conf': No such file or directory
chmod: cannot access `/etc/snmp/snmptt.conf': No such file or directory
/bin/chown: invalid user: `snmptt:snmptt'
chmod: cannot access `/var/spool/snmptt': No such file or directory
chmod: cannot access `/var/log/snmptt': No such file or directory
Adding firewall rules
iptables: Saving firewall rules to /etc/sysconfig/iptables:[  OK  ]
Set up the snmptt daemon to start automatically on boot
as well as starting it now
error reading information on service snmptt: No such file or directory
-bash-4.1# yum repolist
Loaded plugins: enabled_repos_upload, fastestmirror, package_upload, product-id, security, subscription-
              : manager
tlsv1 alert unknown ca
Loading mirror speeds from cached hostfile
 * epel: mirrors.sonic.net
repo id                       repo name                                                             status
base                          CentOS-6 - Base                                                        6,575
cr                            CentOS-6 - CR                                                              0
epel                          Extra Packages for Enterprise Linux 6 - x86_64                        12,584
extras                        CentOS-6 - Extras                                                         50
updates                       CentOS-6 - Updates                                                     1,263
repolist: 20,472
benjaminsmith
Re: upgrade from xi-5.4.5 to 5.5.0 and then the latest in UI
Post by benjaminsmith »
Hello @iwang,
Are you able to access the GUI? If so, can you download a System Profile and send it over?
To send us your system profile.
Login to the Nagios XI GUI using a web browser
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
Next, there is a perl dependency error, please post the output to the following commands:
yum list installed perl
rpm -qa | grep perl
which perl
iwang
Post by iwang »
thank you for your respond!
i have sent you the private message for the system profile. here is the output for the perl information:
-bash-4.1# yum list installed perl
              : manager
Installed Packages
perl.x86_64                                    4:5.10.1-144.el6                                    @base
-bash-4.1# rpm -qa | grep perl
perl-IO-Compress-Base-2.021-144.el6.x86_64
perl-Compress-Zlib-2.021-144.el6.x86_64
perl-DateTime-0.5300-3.el6.x86_64
perl-DBI-1.609-4.el6.x86_64
perl-Digest-HMAC-1.01-22.el6.noarch
perl-Params-Validate-0.92-3.el6.x86_64
perl-Crypt-SSLeay-0.57-17.el6.x86_64
perl-Net-LibIDN-0.12-3.el6.x86_64
perl-HTML-Parser-3.64-2.el6.x86_64
perl-Crypt-DES-2.05-9.el6.x86_64
perl-Math-Calc-Units-1.07-6.el6.noarch
perl-Pod-Escapes-1.04-144.el6.x86_64
perl-version-0.77-144.el6.x86_64
perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64
perl-Compress-Raw-Zlib-2.021-144.el6.x86_64
perl-IO-Compress-Zlib-2.021-144.el6.x86_64
perl-CPAN-1.9402-144.el6.x86_64
perl-Test-Simple-0.92-144.el6.x86_64
perl-URI-1.40-2.el6.noarch
perl-DBD-MySQL-4.013-3.el6.x86_64
perl-Digest-SHA1-2.12-2.el6.x86_64
perl-Socket6-0.23-4.el6.x86_64
perl-IO-Socket-INET6-2.56-4.el6.noarch
perl-Error-0.17015-4.el6.noarch
perl-SNMP_Session-1.12-4.el6.noarch
perl-Crypt-Rijndael-1.09-2.el6.x86_64
perl-Mail-POP3Client-2.18-6.el6.noarch
perl-Parse-RecDescent-1.965-1.el6.noarch
perl-Number-Format-1.73-3.el6.noarch
perl-IO-Socket-SSL-1.31-2.el6.noarch
perl-HTML-Tagset-3.20-4.el6.noarch
perl-libwww-perl-5.833-2.el6.noarch
perl-XML-Simple-2.18-6.el6.noarch
perl-Net-SNMP-5.2.0-4.el6.noarch
perl-libs-5.10.1-144.el6.x86_64
perl-Pod-Simple-3.13-144.el6.x86_64
perl-Test-Harness-3.17-144.el6.x86_64
perl-devel-5.10.1-144.el6.x86_64
perl-IO-stringy-2.110-10.1.el6.noarch
perl-Class-Singleton-1.4-6.el6.noarch
perl-Config-IniFiles-2.72-2.el6.noarch
perl-Class-Accessor-0.31-6.1.el6.noarch
rrdtool-perl-1.3.8-7.el6.x86_64
perl-Mail-IMAPClient-3.37-1.el6.noarch
perl-Digest-SHA-5.47-144.el6.x86_64
perl-Time-HiRes-1.9721-144.el6.x86_64
perl-Net-SSLeay-1.35-9.el6.x86_64
perl-TimeDate-1.16-13.el6.noarch
perl-List-MoreUtils-0.22-10.el6.x86_64
perl-Net-DNS-0.65-5.el6.x86_64
perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch
perl-XML-Parser-2.36-7.el6.x86_64
perl-Config-Tiny-2.12-7.1.el6.noarch
perl-Module-Pluggable-3.90-144.el6.x86_64
perl-ExtUtils-MakeMaker-6.55-144.el6.x86_64
-bash-4.1# which perl
/usr/bin/perl
iwang
Post by iwang »
please keep this one unlocked. thank you
benjaminsmith
Hello Irene,
A couple of things we noticed from the profile and the logs. There are mulitple Nagios processes running, so stop Nagios, kill of the processes and res-start.
service nagios stop
pkill -9 -u nagios
service nagios start
1. The Continous Release (CR) Repo may cause package conflicts and/or incompatibilities and is not recommended.
2. You'll need to have the following version of perl installed, and will need to downgrade from perl-5.10.1-144.el6.x86_64 to: perl = 4:5.10.1-141.el6_7.1 If you are running a VM, take a snapshot before making any changes.You can use the downgrade command in yum.
yum downgrade perl-5.10.1-141.el6.x86_64
See: How to use yum to downgrade or rollback some package updates?
Try running the installer again and post any error messages. Also, if you're still having trouble, please post the output to the following command:
yum list installed
iwang
Post by iwang »
Hi Benjamin,
I still got the same error. here is the output of yum list installed. please find attached output.
and downgrade perl&php doesn't seem successful to me. please check the attached.
the latest upgrade log
Nagios XI Upgrade Log
DATE: Mon Jan 27 17:49:10 PST 2020
DISTRO INFO:
CentOS
6.7
x86_64
Archive:  sourceguardian/ixed4.lin.x86-64.zip
  inflating: /usr/lib64/php/modules/ixed.5.3.lin
Sourceguardian extension found for PHP version 5.3
Sourceguardian extension already in php.ini
Stopping httpd:                                            [  OK  ]
Starting httpd:                                            [  OK  ]
Checking required prereqs...
Please wait...
OLD VERSION: 5500
              : security, subscription-manager
Setting up Update Process
No Packages marked for Update
Setting up Install Process
Resolving Dependencies
---> Package php-imap.x86_64 0:5.3.3-46.el6_7.1 will be installed
--> Processing Dependency: php-common(x86-64) = 5.3.3-46.el6_7.1 for package: php-imap-5.3.3-46.el6_7.1.x86_64
--> Processing Dependency: libc-client.so.2007()(64bit) for package: php-imap-5.3.3-46.el6_7.1.x86_64
---> Package libc-client.x86_64 0:2007e-11.el6 will be installed
DATE: Mon Jan 27 18:03:06 PST 2020
DISTRO INFO:
CentOS
6.7
x86_64
Please wait...
OLD VERSION: 5500
benjaminsmith
Hi Irene,
Did it error on the php-common package as well? It looks like the upgrade log is cut off, can you run this again and post the entire output.
It may save time to just take a backup and restore it on a clean (minimal) distribution. Are you running this on a physical server or a VM?
Backing Up and Restoring Nagios XI
iwang
Post by iwang »
here is the php downgrade output
# yum downgrade php-common-5.3.3-46.el6_7.1.x86_64
              : subscription-manager
Setting up Downgrade Process
---> Package php-common.x86_64 0:5.3.3-46.el6_7.1 will be a downgrade
---> Package php-common.x86_64 0:5.3.3-49.el6 will be erased
Error: Package: php-xml-5.3.3-49.el6.x86_64 (@base)
           Requires: php-common(x86-64) = 5.3.3-49.el6
           Removing: php-common-5.3.3-49.el6.x86_64 (@base)
           Downgraded By: php-common-5.3.3-46.el6_7.1.x86_64 (C6.7-updates)
           Available: php-common-5.3.3-40.el6_6.x86_64 (C6.7-base)
               php-common(x86-64) = 5.3.3-40.el6_6
           Available: php-common-5.3.3-46.el6_6.x86_64 (C6.7-updates)
               php-common(x86-64) = 5.3.3-46.el6_6
Error: Package: php-cli-5.3.3-49.el6.x86_64 (@base)
Error: Package: php-pgsql-5.3.3-49.el6.x86_64 (@base)
Error: Package: php-5.3.3-49.el6.x86_64 (@base)
Error: Package: php-gd-5.3.3-49.el6.x86_64 (@base)
Error: Package: php-pdo-5.3.3-49.el6.x86_64 (@base)
Error: Package: php-mbstring-5.3.3-49.el6.x86_64 (@base)
Error: Package: php-ldap-5.3.3-49.el6.x86_64 (@base)
Error: Package: php-snmp-5.3.3-49.el6.x86_64 (@base)
Error: Package: php-mysql-5.3.3-49.el6.x86_64 (@base)
yes. it's on a VM
iwang
Post by iwang »
the reason we cannot do on a clean env because we need replicate the firewall configuration but we lost the track of the nagios server configuration for the new env. it will take longer time.
can you share what's the requirement of the kernel libraries? including the core and dependent libs version.
from the log, it fails not only one package but also the dependent ones. and Nagios upgrade is looking for lower release version instead of the latest.
benjaminsmith wrote:Hi Irene,
iwang
Post by iwang »
@ benjaminsmith,
is it possible install two nagios server on one host? do we have document? i would like to use the same host and install a fresh nagios latest version and then redirect the db configuration to the newer one if everything works fine. this way, it won't effect my current setup neither.
thanks,
Irene
