problem with nagvis after upgrade to latest version
Re: problem with nagvis after upgrade to latest version
fixed it bro had to change the db user to the correct one and fix the db host as recommended thanks fellas you can lock it up!
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Great!benhank wrote:fixed it bro had to change the db user to the correct one and fix the db host as recommended thanks fellas you can lock it up!
Locking
