problem with nagvis after upgrade to latest version
benhank
Post by benhank »
I've upgraded my server to the latest version. Afterwards when I try to open nagvis I am getting the following errors:
Error: (0) Undefined property: CorePDOHandler::$data
URL: /nagvis/server/core/ajax_handler.php?mod=Overview&act=getObjectStates&i[]=map-webpacs&_ajaxid=1581528762
File: /usr/local/nagvis/share/server/core/classes/CorePDOHandler.php
Line: 306
#0 /usr/local/nagvis/share/server/core/classes/CorePDOHandler.php(306): nagvisExceptionErrorHandler(8, 'Undefined prope...', '/usr/local/nagv...', 306, Array)
#1 /usr/local/nagvis/share/server/core/classes/CorePDOHandler.php(332): CorePDOHandler->prep('SELECT? ...')
#2 /usr/local/nagvis/share/server/core/classes/GlobalBackendPDO.php(485): CorePDOHandler->query('SELECT? ...', Array)
#3 /usr/local/nagvis/share/server/core/classes/CoreBackendMgmt.php(478): GlobalBackendPDO->getHostState(Array, 0, Array)
#4 /usr/local/nagvis/share/server/core/classes/CoreBackendMgmt.php(169): CoreBackendMgmt->fetchStateCounts('ndomy_1', 'hostState', 0, Array)
#5 /usr/local/nagvis/share/server/core/classes/CoreModOverview.php(171): CoreBackendMgmt->execute()
#6 /usr/local/nagvis/share/server/core/classes/CoreModOverview.php(64): CoreModOverview->parseMapsJson(false, Array)
#7 /usr/local/nagvis/share/server/core/functions/index.php(120): CoreModOverview->handleAction()
#8 /usr/local/nagvis/share/server/core/ajax_handler.php(59): require('/usr/local/nagv...')
#9 {main}
thanks in advance!
Proudly running:
Nagios Network Analyser
Nagios Fusion
mbellerue
Re: problem with nagvis after upgrade to latest version
Post by mbellerue »
Which version did you upgrade from? Also, was it an in place upgrade, or did you migrate to a new server, do a fresh install of XI, and restore a backup?
Also, does NagVis load enough to go to Options -> Manage Backends? I'd like to make sure that's set to nagiosxi.
benhank
Post by benhank »
this is a fresh install of nagios on a clean server. after the install of version 5.4.12 I testsed the restore which was working . I then Upgraded to latest version and noticed the error above.
I even upgraded nagvis to its latest version but the errors persist
I can browse to the backend cfg which is listed here:
Proudly running:
Nagios Fusion
Is your mysql db offloaded to a remote server? What is the output of the following command?
grep 'dbhost\|dbuser\|dbpass' /usr/local/nagvis/etc/nagvis.ini.php
benhank
Post by benhank »
dang Its pointing to my offloaded server..
Ive changed the ipaddress of db host back to local host and even tested it with the ip of my server but Im still getting the error.
Proudly running:
Nagios Fusion
If you are using localhost now, you should probably have the following in the "/usr/local/nagvis/etc/nagvis.ini.php" file:
dbhost="localhost"
dbuser="ndoutils"
dbpass="n@gweb"
unless you changed the credentials.
What do you see in the "/usr/local/nagiosxi/html/config.inc.php" file under the "// db-specific connection information" section?
benhank
Post by benhank »
here it tis
Proudly running:
Nagios Fusion
You cannot manually upgrade NagVis in XI as this is going to break it. Your config looks different than mine. For example, you have:
; default backend (id of the default backend)
backend="ndomy_1"
[backend_ndomy_1]
; type of backend - MUST be set
backendtype="ndomy"
On my system, I have:
backend="nagiosxi"
[backend_nagiosxi]
backendtype="ndomy"
I haven't looked through the whole file, but I am sure there are going to be more differences.
I would recommend that you revert to your "pre-upgrade" snapshot of Nagios XI, and run the upgrade. If you get stuck on something, ask for help on the forum. Do not attempt to upgrade NagVis separately (manually)!
benhank
Post by benhank »
thanks for the advice bro! ill give it a shot and let you know how it goes!
Proudly running:
Nagios Fusion
Sure, let us know how it went.
