Upgrade from 5.4.13 to 5.6.12 unsuccessful
Re: Upgrade from 5.4.13 to 5.6.12 unsuccessful
Hi, I've enabled the optional channel however I'm still having an issue performing the upgrade. Please see log attached.
Dave.
Dave.
Dave Ryan.
This looks like you are getting an error from the rpmforge repo, I would suggest you disable this repository
Thanks for the recommendation. Disabling the repo certainly got the upgrade to go a lot further. However, I still see the below at the end of the upgrade process. I've attached as much of the session that was captured from my SSH session. I've confirmed from the Nagios XI Admin page that I'm still running on version 5.4.13.
Setting up Install Process
No package shellinabox available.
Error: Nothing to do
Any ideas on what went wrong?
Dave.
Dave.
Dave Ryan.
This looks better, but now you are missing a different repo which is required for shellinabox, the epel repo
If you do not have it installed any longer and cannot enable it, you yshould be able to do the following
yum install https://dl.fedoraproject.org/pub/epel/epel-release-latest-6.noarch.rpmRe: Upgrade from 5.4.13 to 5.6.12 unsuccessful
I've executed the yum install command for epel but I'm not sure it worked. I'm seeing Error: Nothing to do, log attached.
Dave.
Dave.
Dave Ryan.
Hmm, I see this
does this machine have access to the Internet?Code: Select all
Cannot open: https://dl.fedoraproject.org/pub/epel/epel-release-latest-6.noarch.rpm. Skipping.
Can you show the output of the following
ll /etc/yum.repos.d/Re: Upgrade from 5.4.13 to 5.6.12 unsuccessful
Yes, this machines has access to the internet. Command executed, output below.
Dave.
[root@bktsfnoc01 ~]# ll /etc/yum.repos.d/
total 92
-rw-r--r-- 1 root root 739 Nov 12 2010 mirrors-rpmforge
-rw-r--r-- 1 root root 717 Nov 12 2010 mirrors-rpmforge-extras
-rw-r--r-- 1 root root 728 Nov 12 2010 mirrors-rpmforge-testing
-rw-r--r-- 1 root root 70106 Apr 4 08:08 redhat.repo
-rw-r--r-- 1 root root 2716 Jan 15 2018 remi.repo
-rw-r--r-- 1 root root 1113 Apr 6 08:53 rpmforge.repo
Dave.
Dave Ryan.
hmm, can you run the following
cd /tmp
wget https://dl.fedoraproject.org/pub/epel/epel-release-latest-6.noarch.rpm
yum localinstall epel-release-latest-6.noarch.rpmRe: Upgrade from 5.4.13 to 5.6.12 unsuccessful
Commands executed, log attached.
Dave.
Dave.
Dave Ryan.
