storage monitor
progressive.nagiosXI
Re: storage monitor
Post by progressive.nagiosXI »
Required details shared in PM,
ZIP file include :- fresh Profile.zip,IP screeshot,NagiosXI-module.conf,gearman-worker.conf
Re: storage monitor
Hi Team,
sent in private mail : ssax
had you received attachement
ssax
Dreams In Code
Re: storage monitor
Post by ssax »
Received, analyzing now. Will post an update shortly.
ssax
Dreams In Code
Re: storage monitor
Post by ssax »
Please edit your worker.conf and add that hostgroup to the worker.conf hostgroups line OR make the SXXXXN_STORAGE group a member of the SXXXXN group (in XI CCM and apply config) that's currently listed in the worker.conf. If you're just adding SXXXXN_STORAGE to SXXXXN hostgroup to resolve this, make sure your /etc/mod_gearman/module.conf has that set on the hostgroups line as well.
Then restart the worker service on the worker.
Then restart nagios/gearman on the XI server as well, please see this guide for the process:
https://support.nagios.com/kb/article.php?id=484
That should do it.
Re: storage monitor
Hi ssax,
Thanks for not locking this forum.
Due to Nagiosxi crash and gearman problem we put this devices on hold .
we are still able to get details from nagios user in Nagios gearman-worker-server for this device.
Now we put device in only hostgroup defined in both gearman-master-server(Cloud)and gearman-worker-server(onPrem) configuration.
But still not getting data and showing below error
xcli not found
Note:- we are currently monitor approx 600 devices via gearman in same hostgroup for that client.
ssax
Dreams In Code
Re: storage monitor
Post by ssax »
Please PM a fresh copy of your profile and include your /etc/mod_gearman/module.conf from the XI server and the /etc/mod_gearman/worker.conf from the workers that you modified so we can see how it's setup.
Re: storage monitor
Re: storage monitor
Sent: Tue Jul 07, 2020 10:13 pm
To: ssax
ssax
Dreams In Code
Re: storage monitor
Post by ssax »
That looks proper.
Do you have the worker on the XI server disabled?
Please PM the output of this command from the XI server:
gearman_top
What are you seeing in /var/log/mod_gearman/mod_gearman_worker.log on the worker?
Re: storage monitor
Do you have the worker on the XI server disabled? yes disabled
/var/log/mod_gearman/mod_gearman_worker.log >> empty
ssax
Dreams In Code
Re: storage monitor
Post by ssax »
Oh, I'm wondering if this is a PATH issue, in the code it shows this:
    # Add the special directories to the general path, and go searching
    # for the xcli command line utility
    dlist = os.environ['PATH'].split(':') + special_dirs
    for d in dlist:
        fullpath = os.path.join(d,'xcli')
        if os.path.exists(fullpath):
            xcli_path = fullpath
            break
    if xcli_path is None:
        print('xcli not found')
        sys.exit(3)
It's trying all the locations in the PATH to find where xcli is. Is xcli in your PATH on the gearman worker?
which xcli
Try changing the code here:
special_dirs = ['/usr/local/XIVGUI','/opt/XIVGUI','/opt/ibm/XIVGUI']
To:
special_dirs = ['/usr/local/XIVGUI','/opt/XIVGUI','/opt/ibm/XIVGUI','/usr/local/nagios/libexec']
That should hopefully resolve it.
