Exchange issues, might be with client
benningtonr
Re: Exchange issues, might be with client
I only have two black list servers entered, same ones i have in my barracuda spam filter
My guess is that there are core services in the list that aren't started, can you run the following from the command linebenningtonr wrote:Exchange 2007 Blacklist Status Critical 1h 22m 58s 5/5 2012-05-23 16:08:05 (null)
Exchange Core Services Critical 1h 22m 25s 5/5 2012-05-23 16:07:58 MSExchangeADTopology: Started - MSExchangeAntispamUpdate: Started - MSExchangeEdgeSync: Started - MSExchangeFDS: Started - MSExchangeImap4: Started - MSExchangeIS: Started - MSExchangeMailboxAssistants: Started - MSExchangeMailSubmission: Started - MSExch
cd /usr/local/nagios/libexec
./check_nt -H <EXCHANGE_SERVER_IP> -s "<NSCLIENT_PASSWORD>" -p 12489 -v SERVICESTATE -d SHOWALL -l MSExchangeADTopology,MSExchangeAntispamUpdate,MSExchangeEdgeSync,MSExchangeFDS,MSExchangeImap4,MSExchangeIS,MSExchangeMailboxAssistants,MSExchangeMailSubmission,MSExchangeMonangePop3,MSExchangeRepl,MSExchangeSA,MSExchangeSearch,MSExchangeServiceHost,MSExchangeTransport,MSExchangeTransportLogSearch,msftesql-Exchange-
benningtonr
MSExchangeMonangePop3: Not found
only one not started
That will do it, if you don't have that service, you can remove it from the list in
Configure -> Core config manager -> Services -> Core Exchange -> Modify
benningtonr
I took it out of the configured checks string.
Trying to fix the black list now, any ideas?
Testing that would be similar, run
If you get an error about Can't locate Net/DNS.pm run
then try again
./check_bl -H <EXCHANGE_SERVER_IP> -B rbl.server.com rbl.server2.com Code: Select all
yum install perl-Net-DNS -y-
benningtonr
I ran this, on a pre-built vm
yum install perl-Net-DNS.i686
got the green check now, can you send me the complete list of BL's so i can re-enter then, I took all of them but two out
zen.spamhaus.org bl.spamcop.net dnsbl.ahbl.org dnsbl.njabl.org dnsbl.sorbs.net virbl.dnsbl.bit.nl rbl.efnet.org phishing.rbl.msrbl.net 0spam.fusionzero.com list.dsbl.org multihop.dsbl.org unconfirmed.dsbl.org will-spam-for-food.eu.org blacklist.spambag.org blackholes.brainerd.net blackholes.uceb.org spamsources.dnsbl.info map.spam-rbl.com ns1.unsubscore.com psbl.surriel.com l2.spews.dnsbl.sorbs.net bl.csma.biz sbl.csma.biz dynablock.njabl.org no-more-funn.moensted.dk ubl.unsubscore.com dnsbl-1.uceprotect.net dnsbl-2.uceprotect.net dnsbl-3.uceprotect.net spamguard.leadmon.net opm.blitzed.org bl.spamcannibal.org rbl.schulte.org dnsbl.ahbl.org virbl.dnsbl.bit.nl combined.rbl.msrbl.net-
benningtonr
awsome,
I now have the complete list and it is working great.
Many thanks
Many thanks
