All hosts/services in pending state after upgrade to 5.7
Re: All hosts/services in pending state after upgrade to 5.7
I don't have an ETA, but it would be probably in about 2-4 weeks.
alex9000
Post by alex9000 »
we are also facing this issue with Nagios 5.7.1: Round about 200 Hosts und 2000 Services.
Try the following patch to see if it is going to fix your issue.
cd /tmp
wget https://assets.nagios.com/downloads/nagiosxi/patches/patch-ndo.sh
chmod +x patch-ndo.sh
./patch-ndo.sh
Let us know if this helped. Thank you!
DennisPR
Post by DennisPR »
I have the same issue when upgrading van from 5.6.12 to 5.7.1 and the patch doesn't fix the issue.
I still see 4161 hosts and 38925 services pending.
Hope you guys will be able to fix this asap.
rrustamSAI
Post by rrustamSAI »
Same issue w/ me too, upgraded v.5.6.14 -> v5.7.1 and also just applied the NDO patched provided but no go.
All 941 hosts & 9610 services are pending.
All pending hosts & service "Last Check" = 01/01/1970 00:00:01
@rrustamSAI, you already reported the issue here:
https://support.nagios.com/forum/viewto ... 40#p311940
Let's try to keep this conversation in the thread above.
Note: Please do not append to other users' posts. It's difficult to follow up on the issue this way. The best practice is to start your own thread, in which you can reference another one, e.g. "I am having an issue, similar to the one described in <URL to a different support thread>".
Thank you!
rrustamSAI
I got completely different issue, the other one seems to better after the support re-compiled the NDO v3 but now running into this pending state
You want me to close my upgrade issue as resolved after NDO v3 recompiled then open another thread referencing the never ending 'pending' status check link to this issue?
lmiltchev wrote:@rrustamSAI, you already reported the issue here:
Thank you!
Sure.
rrustamSAI
Got it, done.
Sure.
Locking the topic.
