Core Worker timed out and failed to reap child
hbouma
Re: Core Worker timed out and failed to reap child
Post by hbouma »
If we do have a situation where the server is just overloaded, what types of symptoms would we be seeing?
benjaminsmith
Post by benjaminsmith »
Hi Henry,
You would see a high CPU load and high check latency since Nagios is unable to schedule the checks on time and this is what I'm seeing in the system profile.
Top Command Shows High CPU Load
top - 07:54:43 up 5 days, 23:21,  1 user,  load average: 320.75, 313.22, 406.45
Tasks: 592 total, 177 running, 411 sleeping,   0 stopped,   4 zombie
Kernal Message Queues ( slow to write results to the databsae)
------ Message Queues --------
key        msqid      owner      perms      used-bytes   messages
0xd7000002 17         nagios     600        12948480     12645
I noticed that you have quite a few NCPA checks setup for an interval of every 3 minutes, if you can increase it 5 minutes that would help substantially.
The system has 8 Single Core CPU's, if you're able to add more that would help since scheduling active host and service check is CPU intensive.
Other options to reduce load would be to set up passive checks or integrating Mod Gearman.
Using NCPA For Passive Check
Integrating Mod-Gearman With Nagios XI
hbouma
Post by hbouma »
I have reached out to our server team. They will be adding CPU's next week Friday and the following Friday.
benjaminsmith
Hi Henry,
Great. Let us know the results.
