Port monitoring
vtrac
Re: Port monitoring
Post by vtrac »
haha!! ..... Thank you ..... :-)
fsodah
Re: Port monitoring
Post by fsodah »
I am still checking the issue with our Network Eng. however, I need few days to get back to you. please keep the ticket open till I get back to you.
vtrac
Re: Port monitoring
Post by vtrac »
Will do ..... good luck!! ... :-)
fsodah
Re: Port monitoring
Post by fsodah »
Regarding your below request find the output:
>What is the command used to check this port?
>Nagios XI GUI > Configure > Core Config Manager > Services
>Now, select the service that is having issue > select "Common Settings" > Run check Command
vtrac
Re: Port monitoring
Post by vtrac »
So, it is using "check_rrdtraf".
As you already aware, those "in" and "out" has "0 mb/s".
Best Regards,
Vinh
fsodah
Re: Port monitoring
Post by fsodah »
Anything is wrong with the above ...
I am still investigating the switch ports I did (enable/disable) the port but didn't change anything, I am still investigating.
vtrac
Re: Port monitoring
Post by vtrac »
I tested this on my Nagios XI and it is also using "check_rrdtraf".
Since I pointed this to a test switch so some of my "in" and "out" also has "0 mb/s" as well.
Best Regards,
Vinh
fsodah
Re: Port monitoring
Post by fsodah »
Do I need to use another option with the run a command?
vtrac
Re: Port monitoring
Post by vtrac »
Sorry, same command work for you before and not now.
I think something has changed in your Switch / Router.
Best Regards,
Vinh
fsodah
Re: Port monitoring
Post by fsodah »
It was working perfectly before 2 weeks
