Port monitoring
fsodah
Port monitoring
Post by fsodah »
I used to monitor a port on my core switch, which has many activities since two weeks is showing 0 value instead of the actual value that I usually see when I debug the port directly cmd line on my switch. Can you please tell me where I should look first?
vtrac
Re: Port monitoring
Post by vtrac »
Hope you are having a good day.
Did you make any changes to your system lately?
Can you please check the below two logs files?
tail -25 /usr/local/nagios/var/perfdata.log
tail -25 /usr/local/nagios/var/npcd.log
The key is to look at the Performance data output in the advanced tab in service detail.
It will allow us to see whether service checks not returning any perfdata or if the graphing itself is not working.
Here's an KB article on performance graph problems:
https://support.nagios.com/kb/article.php?id=9
You can also try deleting those rrd & XML files under
/usr/local/nagios/share/perfdata/<host-with-graph-issue>/
Restart services:
systemctl restart ncpd
systemctl restart nagios
Please allow some times (30+ minutes) for graphs to come in after delete those rrd files.
If all failed, please upload your "profile.zip" file.
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Click the "Admin" > "System Config" > "System Profile" Menu
Best Regards,
Vinh
fsodah
Re: Port monitoring
Post by fsodah »
I will check and update the ticket.
fsodah
Re: Port monitoring
Post by fsodah »
No changes have been made to the system for a long time.
I recalled the sensor from scratch by deleting the port and reconfigure it again, but it didn't help same value 0
Other port sensors are showing the correct values
Please see the logs
vtrac
Re: Port monitoring
Post by vtrac »
I do not see any issue based on the "profile.zip".
However, the "nagios.log" was empty.
Can you please let me know which host / service you are having issue?
Can you please delete those ".rrd" and ".xml" files under the below folder:
Please give it about 30+ minutes for data to come in
Can you please run the below command?
NOTE: This is a ONE line command
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios
Also, please run this:
ls -la /var/lib/mrtg/
Best Regards,
Vinh
fsodah
Re: Port monitoring
Post by fsodah »
I need to delete only the one with that sensor 2:6 only !! since under the core switch I monitor more than 50x ports
I monitor port 2:6
vtrac
Re: Port monitoring
Post by vtrac »
Yes, only delete the port which having issue.
Based on the picture from the last reply, I don't think you will see anything from the graph since the "in" and "out" have "0 mb/s" value coming into Nagios.
This is NOT Nagios issue, please check with your Network Admin about the port instead.
What is the command used to check this port?
Nagios XI GUI > Configure > Core Config Manager > Services
Now, select the service that is having issue > select "Common Settings" > Run check Command
Can you please post the command and also manually ran the command on the Nagios XI command prompt?
Regards,
Vinh
fsodah
Re: Port monitoring
Post by fsodah »
I will check it tomorrow and update you.
vtrac
Re: Port monitoring
Post by vtrac »
Sure, please talk to your Network Admin regarding that port.
Also, why is your last picture has a date of yesterday "04/26/2021 22:xx:xx"?
Best Regards,
Vinh
fsodah
Re: Port monitoring
Post by fsodah »
I captured it yesterday ... I went out of my office.. :)
