Enable Notifications
btayl
Re: Enable Notifications
Post by btayl »
Yep It is still doing it
would it have anything to do with ndo2db they had me enable it when I last updated because the service would not start.
gsmith
Post by gsmith »
It's good that they had you downgrade to ndo2db because we have been seeing some issues with the NDO-3 broker.
In fact your problem might be related to the NDO-3 issue, since your configurations all look OK. I suspect
the problem is in the database, so please do the following :
mysqldump -u root -pnagiosxi nagios > /tmp/nagios.sql
cd /tmp
tar cvzf nagios.sql.tar.gz nagios.sql
Please PM me the resultant nagios.sql.tar.gz file. If it is too big to attach in a PM then do the following:
in the /tmp directory where nagios.sql.tar.gz is located:
split -b 19MB nagios.sql.tar.gz
That will create various files xaa, xab, etc. You should be able to PM me those files, one file per PM. You
may need to rename them to include an extension.
btayl
Post by btayl »
Files Sent
gsmith
Post by gsmith »
So for tkidder, I don't see her associated with any hosts or services, just
with two hostgroups:
| contact_id | contact_object_id | alias | email_address |
| 515195 | 684 | Kidder, Teresa | [email protected] |
mysql> select * from nagios_contactgroup_members
-> where contact_object_id = 684;
| contactgroup_member_id | instance_id | contactgroup_id | contact_object_id |
| 993453 | 1 | 174217 | 684 |
| 993306 | 1 | 174201 | 684 |
| 993251 | 1 | 174175 | 684 |
| contactgroup_id | instance_id | config_type | contactgroup_object_id | alias |
| 174175 | 1 | 1 | 2066 | Interface Services Team |
| 174201 | 1 | 1 | 5645 | SECONDARY-ALERT-NOTIFICATION |
| 174217 | 1 | 1 | 145 | All Contacts |
Can you please take her out of the Interface Services Team and the SECONDARY-ALERT-NOTIFICATION
groups. If that stops the notifications let me know. If it doesn't stop the notifications then please
take her out of the All Contacts group, and let me know the results of that.
btayl
Post by btayl »
I do not see this group | 174217 | 1 | 1 | 145 | All Contacts |
gsmith
Post by gsmith »
The All contacts looks like:
But don't worry about that until we see what happens with she is removed from
groups.
btayl
Post by btayl »
I actual removed the tkidder user
but the user bellow still seeing duplicates
akstaley
chekurip
clively
jonawils
kinzler
liguo
sboluyt
btayl
Post by btayl »
The one's below are from the last 24hrs
akstaley
amoisan
chekurip
clively
dstpierr
dstpierr
ganpathp
jameclem
jonawils
jonawils
kfinn
kinzler
liguo
padmav
rkralic
rsayre
sboluyt
tjavan
gsmith
Post by gsmith »
Hi
When you say "I actual removed the tkidder user ....." does that mean you removed her
from the contactgroups of you removed her account from Nagios?
btayl
Post by btayl »
Removed her account from Nagios
