SNMP monitoring on Ubuntu
gvrjameskyaw
Re: SNMP monitoring on Ubuntu
Post by gvrjameskyaw »
Still getting Error
[root@vm-is-snmp02 libexec]# ./check_snmp_storage_wizard.pl -H 10.80.72.115 -C public --v2c -m ^/$ -w 80 -c 95 -f
Unknown storage : ^/$ : ERROR
[root@vm-is-snmp02 libexec]# ./check_snmp_storage_wizard.pl -H 10.80.72.115 -C public --v2c -m ^/var -w 80 -c 95 -f
Unknown storage : ^/var : ERROR
gsmith
Post by gsmith »
Hi
From a shell on the Nagios server please run:
snmpwalk -v 2c -c public 10.80.72.115 1.3.6.1.2.1.25.2.3.1
That should result in more than 50 lines of output. If it doesn't, or if it gave you errors,
then do the following on the machine you want to monitor (10.80.72.115) :
mv /etc/snmp/snmpd.conf /etc/snmp/snmpd.conf.orig
vi /etc/snmp/snmpd.conf
add the following two lines:
rocommunity public localhost
rocommunity public <ipaddress of nagios server>
save the file and exit vi
restart the snmpd service
Now go back to the shell on the Nagios server please run:
Let me know how it works out.
Thank you
