SNMP monitoring on Ubuntu
gvrjameskyaw
Post by gvrjameskyaw »
Received this error message while trying to monitor disk usage on Ubuntu 16.04.7 LTS server
ERROR: Description/Type table : No response from remote host '10.80.72.115'.
Service Command
check_xi_service_snmp_linux_storage! -C public --v2c -m "^/$" -w 80 -c 95 -f
pbroste
Re: SNMP monitoring on Ubuntu
Post by pbroste »
Hello @gvrjameskyaw
Thanks for reaching out, and want to go ahead and verify that ports 161 and 162 are allowed. Also verify that security applications like selinux are blocking.
Verify results by running this command:
snmpwalk -c <yourcommunitystring> -v 2c <youripaddress>
We expect to see results that look similar to:
SNMPv2-MIB::sysORDescr.8 = STRING: The MIB module for managing UDP implementations
SNMPv2-MIB::sysORDescr.9 = STRING: The MIB modules for managing SNMP Notification, plus filtering.
SNMPv2-MIB::sysORDescr.10 = STRING: The MIB module for logging SNMP Notifications.
SNMPv2-MIB::sysORUpTime.1 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.2 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.3 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.4 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.5 = Timeticks: (0) 0:00:00.00
Please let us know the results,
Perry
gvrjameskyaw
Hi Perry,
Is it TCP or UDP 161 and 162? Also, only inbound traffic on destination IP?
The result I received after running snmpwalk -c communitystring -v 2c destination ip is "Timeout: No Response from 10.28.8.78"
pbroste wrote:Hello @gvrjameskyaw
Perry
pbroste
Post by pbroste »
Hello @gvrjameskyaw
SNMP uses UDP port 161 and port 162.
Please let us know if you need anything further,
Perry
gvrjameskyaw
So for firewall request it would look like...
Nagios XI server ==> open UDP 161, 162 ==> destination host.
Is there any need to open inbound ports on the Nagios server also?
gsmith
Post by gsmith »
Nope, no changes are needed on the Nagios XXI server.
gvrjameskyaw
When I try to monitor Disk Usage on Ubuntu server using SNMP
I got this error Unknown storage : ^/$ : ERROR
gsmith
Post by gsmith »
Hi
From looking at the help for that plugin it shows:
example :
Browse storage list : <script> -C <community> -H <host> -m <anything> -w 1 -c 2 -v
the -m option allows regexp in perl format :
Test drive C,F,G,H,I on Windows : -m ^[CFGHI]:
Test all mounts containing /var : -m /var
Test all mounts under /var : -m ^/var
Test only /var : -m /var -r
Test all swap spaces : -m ^Swap
Test all but swap spaces : -m ^Swap -e
So try removing the quotes around the argument to the -m option:
check_xi_service_snmp_linux_storage! -C public --v2c -m ^/$ -w 80 -c 95 -f
gvrjameskyaw
Still getting Unknown storage : ^/var : ERROR
check_xi_service_snmp_linux_storage! -C public --v2c -m ^/var -w 80 -c 95 -f
gsmith
Post by gsmith »
Please change the ^/var to ^/$ (that's a dollar sign not an S).
Here is the command and the output:
[nagios@gs-cent8-23-82 ~]$ /usr/local/nagios/libexec/check_snmp_storage_wizard.pl -H 192.168.23.93 -C public --v2c -m ^/$ -w 80 -c 95 -f
/: 26%used(6208MB/23555MB) (<80%) : OK | '/'=6208MB;18844;22378;0;23555
Thank you
