hi Greg,
thanks for keep helping me, i have again one more question that the attached file is in txt format so can i upload this file as it is in or do i have to convert it into different file ?
yes i figure out the txt to mp4 video matter.
thanks
BENNING UPS ( monitor temp, output, load,voltage) with snmp
Re: BENNING UPS ( monitor temp, output, load,voltage) with s
Those MIB files have a variety of extensions...sometimes .mib sometimes .txt
They are all just text files, you can view them in Notepad or Notepad++
I am pretty confident that Nagios will take it as it is. But if it doesn't you can just rename it
with a .mib extension.
If you can't get it uploaded, or have any other questions please let me know.
Thanks!
Thanks!
Dear Greg,
Hi i hope you are fine in this pandemic.
So after adding the OIDS for the UPS in the rows column.Can it shows the number of input lines, Ambient Temperature,output and Voltage or we need to create some kind of service so that we have the desired parameters from the UPS.
I got the Mibs files from the shared URL and downloaded the Mibfiles with .Mib extension and uploaded into the Nagios Xi server.
BR,
Muhammad Waqas
BR,
Muhammad Waqas
Hi
After running through the SNMP Wizard and Saving it, you will need to do "Apply Configuration"
Choose Home, Services. Then hit the Apply Configuration button (circled), you will see if the configuration
for a Service has been applied by looking under the Status column (also circled). Let me know how it works out.
Thanks!
Thanks!
Hi greg,
Its early morning here and i will try this tomorrow and will let you know as yesterday i was stuck in some other issues of CISCO ASA 5520 IPSEC Tunnel. So i will work on this tommorrow and let you know .
Appreciate your help
Thanks.
Thanks.
Hi
Sounds good - you are very close to having that UPS set up for monitoring
Let me know how you are doing once you apply the configuration.
I am facing this error.
Configuration verification failed.
Configuration Error
An error occurred while attempting to apply your configuration to the monitoring engine. Contact your Nagios administrator if this problem persists.
Run this monitoring wizard again
Run another monitoring wizard
View the latest configuration snapshots
i dont know what need to be done so that it will be working.
Configuration Error
Hi greg,
I got the Benning UPS mib file from their website but i dont find any OIDs in this file that we will use for all these parameters ?
Hi Greg,
There is no SNMP Walk wizard option of the Mib file in step 1 of our 5.6.5 Nagios XI. So what is the best way to use the Benning Vendor Mib file so that i can have the desired paramters of the UPS
Hi
Would you like to schedule a remote (screen sharing) session so we can work through these issues?
If so schedule a time at this link: redacted
If you can't find a suitable time please let me know and we can continue using this forum.
