Nagios XI upgrade 5.8.6 -> 5.8.7 failed during make
markmerchant
Re: Nagios XI upgrade 5.8.6 -> 5.8.7 failed during make
Tried again on Monday after touching the lock file. Install might have gotten
one line farther than previous attempts. Unfortunately, lost the output. Will
try again.
try again.
Hello @markmerchant
Please let us know what that log output looks like after you try it again.
Perry
Perry
markmerchant
The old install used to ask about modifying the sudoers file. I don't see that anymore.
Hello @markmerchant
Do you see results outlined in the upgrade.log or when running the 'bash -x upgrade' ?
Here is what you should see appended in your /etc/sudoers:
Let me know what you see,
Perry
User_Alias NAGIOSXI=nagios
User_Alias NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/scripts/components/autodiscover_new.php *
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/scripts/send_to_nls.php *
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/scripts/migrate/migrate.php *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/components/getprofile.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reset_config_perms.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_ssl_config.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/backup_xi.sh *
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/scripts/components/autodiscover_new.php *
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/components/getprofile.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *Perry
markmerchant
Error is a little different this this time. Couple of things...
1) There used to be a confirmation about modifying the sudoers file which
doesn't happen anymore. We always hit "No" because that sort of thing is not
allowed here.
2) The pid mentioned in the config file is different than the message message.
Should that be the same?
allowed here.
ps -aux | grep -Ei 'nagios.cfg' && systemctl status nagios
root 2954 0.0 0.0 112812 1016 pts/1 S+ 11:05 0:00 grep --color=auto -Ei nagios.cfg
● nagios.service - LSB: Starts and stops the Nagios monitoring server
Loaded: loaded (/etc/rc.d/init.d/nagios; bad; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2022-02-01 11:03:21 EST; 2min 25s ago
Docs: man:systemd-sysv-generator(8)
Process: 2167 ExecStart=/etc/rc.d/init.d/nagios start (code=exited, status=8)
systemctl status nagios.service
Active: failed (Result: exit-code) since Tue 2022-02-01 11:08:37 EST; 8min ago
Process: 7966 ExecStart=/etc/rc.d/init.d/nagios start (code=exited, status=8)
Feb 01 11:08:37 cvglqnagios01.td.afg nagios[7966]: Check your configuration file(s) to ensure that they contain valid
Feb 01 11:08:37 cvglqnagios01.td.afg nagios[7966]: directives and data definitions. If you are upgrading from a previous
Feb 01 11:08:37 cvglqnagios01.td.afg nagios[7966]: version of Nagios, you should be aware that some variables/definitions
Feb 01 11:08:37 cvglqnagios01.td.afg nagios[7966]: may have been removed or modified in this version. Make sure to read
Feb 01 11:08:37 cvglqnagios01.td.afg nagios[7966]: the HTML documentation regarding the config files, as well as the
Feb 01 11:08:37 cvglqnagios01.td.afg nagios[7966]: 'Whats New' section to find out what has changed.
Feb 01 11:08:37 cvglqnagios01.td.afg systemd[1]: nagios.service: control process exited, code=exited status=8
Feb 01 11:08:37 cvglqnagios01.td.afg systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Feb 01 11:08:37 cvglqnagios01.td.afg systemd[1]: Unit nagios.service entered failed state.
Feb 01 11:08:37 cvglqnagios01.td.afg systemd[1]: nagios.service failed.
bash -x upgrade
Feb 01 11:03:21 cvglqnagios01.td.afg nagios[2167]: Check your configuration file(s) to ensure that they contain valid
Feb 01 11:03:21 cvglqnagios01.td.afg nagios[2167]: directives and data definitions. If you are upgrading from a previous
Feb 01 11:03:21 cvglqnagios01.td.afg nagios[2167]: version of Nagios, you should be aware that some variables/definitions
Feb 01 11:03:21 cvglqnagios01.td.afg nagios[2167]: may have been removed or modified in this version. Make sure to read
Feb 01 11:03:21 cvglqnagios01.td.afg nagios[2167]: the HTML documentation regarding the config files, as well as the
Feb 01 11:03:21 cvglqnagios01.td.afg nagios[2167]: 'Whats New' section to find out what has changed.
Feb 01 11:03:21 cvglqnagios01.td.afg systemd[1]: nagios.service: control process exited, code=exited status=8
Feb 01 11:03:21 cvglqnagios01.td.afg systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Feb 01 11:03:21 cvglqnagios01.td.afg systemd[1]: Unit nagios.service entered failed state.
Feb 01 11:03:21 cvglqnagios01.td.afg systemd[1]: nagios.service failed.
*** Main program, CGIs and HTML files installed ***
You can continue with installing Nagios as follows (type 'make'
without any arguments for a list of all possible options):
make install-init
- This installs the init script in /etc/init.d
make install-commandmode
- This installs and configures permissions on the
directory for holding the external command file
make install-config
- This installs sample config files in /usr/local/nagios/etc
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.4.6'
/bin/install -c -m 755 -d -o root -g root /etc/init.d
/bin/install -c -m 755 -o root -g root startup/default-init /etc/init.d/nagios
Stopping nagios:
Usage:
kill [options] <pid|name> [...]
Options:
-a, --all do not restrict the name-to-pid conversion to processes
with the same uid as the present process
-s, --signal <sig> send specified signal
-q, --queue <sig> use sigqueue(2) rather than kill(2)
-p, --pid print pids without signaling them
-l, --list [=<signal>] list signal names, or convert one to a name
-L, --table list signal names and numbers
-h, --help display this help and exit
-V, --version output version information and exit
For more details see kill(1).
done.
Job for nagios.service failed because the control process exited with error code. See "systemctl status nagios.service" and "journalctl -xe" for details.
+ exit 0
upgrade.log
make install-basic
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.4.6'
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var/archives
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var/spool/checkresults
chmod g+s /usr/local/nagios/var/spool/checkresults
make install-init
make install-config
Stopping nagios: done.
What is the output of these commands?
/usr/local/nagios/bin/nagios -vv /usr/local/nagios/etc/nagios.cfg
sestatus
umask
markmerchant
<code>
upgrade
Feb 01 11:03:21 xxxxxnagios01.td.afg nagios[2167]: Check your configuration file(s) to ensure that they contain valid
Feb 01 11:03:21 xxxxxnagios01.td.afg nagios[2167]: directives and data definitions. If you are upgrading from a previous
Feb 01 11:03:21 xxxxxnagios01.td.afg nagios[2167]: version of Nagios, you should be aware that some variables/definitions
Feb 01 11:03:21 xxxxxnagios01.td.afg nagios[2167]: may have been removed or modified in this version. Make sure to read
Feb 01 11:03:21 xxxxxnagios01.td.afg nagios[2167]: the HTML documentation regarding the config files, as well as the
Feb 01 11:03:21 xxxxxnagios01.td.afg nagios[2167]: 'Whats New' section to find out what has changed.
Feb 01 11:03:21 xxxxxnagios01.td.afg systemd[1]: nagios.service: control process exited, code=exited status=8
Feb 01 11:03:21 xxxxxnagios01.td.afg systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Feb 01 11:03:21 xxxxxnagios01.td.afg systemd[1]: Unit nagios.service entered failed state.
Feb 01 11:03:21 xxxxxnagios01.td.afg systemd[1]: nagios.service failed.
make install-init
make install-config
Stopping nagios:
Usage:
Options:
done.
+ exit 0
upgrade.log
*** Exfoliation theme installed ***
NOTE: Use 'make install-classicui' to revert to classic Nagios theme
make install-basic
make install-init
make install-config
</code>
upgrade
make install-init
make install-config
Stopping nagios:
Usage:
Options:
done.
+ exit 0
upgrade.log
make install-basic
make install-init
make install-config
</code>
markmerchant
I am unable to reply...
Hello @markmerchant
Please let us know if you are experiencing issue with forum post, are you able to provide the output of these commands?
Perry
sestatus
umask
Perry
markmerchant
<code>
Nagios Core 4.4.6
Last Modified: 2020-04-28
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/sn-heartbeat.cfg'...
Error: Invalid max_attempts, check_interval, retry_interval, or notification_interval value for service 'SN Heartbeat' on host 'localhost'
Error: Could not register service (config file '/usr/local/nagios/etc/services/sn-heartbeat.cfg', starting on line 16)
sestatus
SELinux status: disabled
umask
0002
</code>
Nagios Core 4.4.6
License: GPL
sestatus
umask
0002
</code>
