Nagios XI upgrade 5.8.6 -> 5.8.7 failed during make
markmerchant
Nagios XI upgrade failed during the 'make' step. Pls. advise, Thx.
cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.9 (Maipo)
uname -a
Linux cvglqnagiosxx.xx.xxx 3.10.0-1160.49.1.el7.x86_64 #1 SMP Tue Nov 9 16:09:48 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
currently installed
Nagios XI 5.8.6
Error mesg
*** Main program, CGIs and HTML files installed ***
You can continue with installing Nagios as follows (type 'make'
without any arguments for a list of all possible options):
make install-init
- This installs the init script in /etc/init.d
make install-commandmode
- This installs and configures permissions on the
directory for holding the external command file
make install-config
- This installs sample config files in /usr/local/nagios/etc
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.4.6'
/bin/install -c -m 755 -d -o root -g root /etc/init.d
/bin/install -c -m 755 -o root -g root startup/default-init /etc/init.d/nagios
Stopping nagios: No lock file found in /run/nagios.lock
Job for nagios.service failed because the control process exited with error code. See "systemctl status nagios.service" and "journalctl -xe" for details.
journalctl -xe oputput
Jan 12 10:27:40 cvglqnagios01.td.afg snmpd[1446]: Connection from UDP: [10.50.5.57]:54995->[10.50.4.228]:161
Jan 12 10:27:42 cvglqnagios01.td.afg sudo[1178]: nagios : TTY=unknown ; PWD=/home/nagios ; USER=root ; COMMAND=/usr/local/nagiosxi/scripts/manage_services.
Jan 12 10:27:42 cvglqnagios01.td.afg sudo[1178]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 12 10:27:42 cvglqnagios01.td.afg sudo[1178]: pam_unix(sudo:session): session closed for user root
Jan 12 10:27:42 cvglqnagios01.td.afg sudo[1186]: nagios : TTY=unknown ; PWD=/home/nagios ; USER=root ; COMMAND=/usr/local/nagiosxi/scripts/manage_services.
Jan 12 10:27:42 cvglqnagios01.td.afg sudo[1186]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 12 10:27:42 cvglqnagios01.td.afg sudo[1186]: pam_unix(sudo:session): session closed for user root
uname -a
currently installed
Nagios XI 5.8.6
Error mesg
make install-init
make install-config
Re: Nagios XI upgrade 5.8.6 -> 5.8.7 failed during make
Hello @markmerchant
Thanks for reaching out, want to verify that you are running while logged into the 'root' superuser account and security services have been disabled.
Please verify that the optional rpm's have been enabled:
Looking for results:
Perry
whoamiCode: Select all
sestatusCode: Select all
yum install -y yum-utils
yum-config-manager --enable rhel-7-server-optional-rpmsCode: Select all
yum group listPlease let us know how things are looking.Available Environment Groups:
Development Tools
Perry
markmerchant
We don't use yum or rpms, package is downloaded w wget.
Here is what we have been using for several years now:
# Upgrade NagiosXI
cd /tmp
rm -rf nagiosxi xi*.tar.gz
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
./upgradeRe: Nagios XI upgrade 5.8.6 -> 5.8.7 failed during make
Hello @markmerchant
Thanks for following up, the 'upgrade' script uses yum and rpm to install see example search:
Let us know the results on:
Perry
Want to find out exactly where it is failing looks like there is a missing dependency:grep -Ei 'yum|rpm -e' upgrade | grep -Ei 'install -y|rpm -e'
yum install -y automake autoconf php-mbstring nmap subversion
yum install -y git
yum install -y python-futures
yum install -y --skip-broken bc dstat expat-devel mailx mod_ssl numpy openldap openldap-devel perl-Mail-IMAPClient perl-Net-DNS python-lxml pymssql python-simplejson rpmdevtools rrdtool-python sudo traceroute
yum install -y "@Japanese Support" "@Chinese Support" "@Korean Support"
yum install -y ipa-gothic-fonts ipa-mincho-fonts ipa-pgothic-fonts ipa-pmincho-fonts
rpm -e Ajaxterm
yum install -y shellinabox
rpm -e wkhtmltox
yum repolist
uname -a
cat /etc/*release
yum list installed > /tmp/yumlist.txt
bash -x upgradePerry
markmerchant
yum repolist
Loaded plugins: enabled_repos_upload, package_upload, product-id, search-
: disabled-repos, subscription-manager
Repo pc_repo forced skip_if_unavailable=True due to: /etc/puppetlabs/puppet/ssl/private_keys/xxxnagios01.td.afg.pem
GAIG_EPEL_EPEL-el7-x86_64 13703/13703
GAIG_GAIHosting_GAIHosting-el7-x86_64 30/30
GAIG_Microsoft_Tools_Microsoft_Tools_EL7_x86_64 85/85
nagios-base 100/100
nagiosxi-deps 31/31
rhel-7-server-extras-rpms 1413/1413
rhel-7-server-optional-rpms 23205/23205
rhel-7-server-rh-common-rpms 243/243
rhel-7-server-rpms 32568/32568
rhel-7-server-supplementary-rpms 425/425
rhel-server-rhscl-7-rpms 13812/13812
repo id repo name status
!GAIG_EPEL_EPEL-el7-x86_64 EPEL-el7-x86_64 13,703
!GAIG_GAIHosting_GAIHosting-el7-x86_64 GAIHosting-el7-x86_64 30
!GAIG_Microsoft_Tools_Microsoft_Tools_EL7_x86_64 Microsoft Tools EL7 x86_ 85
!epel/x86_64 Extra Packages for Enter 13,712
!nagios-base Nagios 100
!nagiosxi-deps Nagios XI Dependencies 31
!pc_repo Puppet Labs puppet6 Repo 35
!rhel-7-server-extras-rpms/x86_64 Red Hat Enterprise Linux 1,413
!rhel-7-server-optional-rpms/7Server/x86_64 Red Hat Enterprise Linux 23,205
!rhel-7-server-rh-common-rpms/7Server/x86_64 Red Hat Enterprise Linux 243
!rhel-7-server-rpms/7Server/x86_64 Red Hat Enterprise Linux 32,568
!rhel-7-server-supplementary-rpms/7Server/x86_64 Red Hat Enterprise Linux 425
!rhel-server-rhscl-7-rpms/7Server/x86_64 Red Hat Software Collect 13,812
repolist: 99,362
Uploading Enabled Repositories Report
Loaded plugins: product-id, subscription-manager
2022-01-19 11:48:53,577 [WARNING] yum
Dummy-1 @logutil.py:142 - logging already initialized
Cannot upload enabled repos report, is this client registered?
uname -a
Linux xxxnagios01.td.afg 3.10.0-1160.49.1.el7.x86_64 #1 SMP Tue Nov 9 16:09:48 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
cat /etc/*release
NAME="Red Hat Enterprise Linux Server"
VERSION="7.9 (Maipo)"
ID="rhel"
ID_LIKE="fedora"
VARIANT="Server"
VARIANT_ID="server"
VERSION_ID="7.9"
PRETTY_NAME="Red Hat Enterprise Linux"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:redhat:enterprise_linux:7.9:GA:server"
HOME_URL="https://www.redhat.com/"
BUG_REPORT_URL="https://bugzilla.redhat.com/"
REDHAT_BUGZILLA_PRODUCT="Red Hat Enterprise Linux 7"
REDHAT_BUGZILLA_PRODUCT_VERSION=7.9
REDHAT_SUPPORT_PRODUCT="Red Hat Enterprise Linux"
REDHAT_SUPPORT_PRODUCT_VERSION="7.9"
2022-01-19 11:52:13,750 [WARNING] yum
nagios-base 100/100
nagiosxi-deps 31/31
repolist: 99,362
uname -a
cat /etc/*release
ID="rhel"
ID_LIKE="fedora"
VARIANT="Server"
VARIANT_ID="server"
VERSION_ID="7.9"
ANSI_COLOR="0;31"
Hello @markmerchant
Thanks for following up with the details, was wondering where the 'bash -x upgrade' failed or stopped on?
Also, when you run 'yum update' what do you get for results?
Perry
Perry
markmerchant
last few lines of upgrade.log
*** Exfoliation theme installed ***
NOTE: Use 'make install-classicui' to revert to classic Nagios theme
make install-basic
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.4.6'
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var/archives
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var/spool/checkresults
chmod g+s /usr/local/nagios/var/spool/checkresults
make install-init
make install-config
make install-basic
make install-init
make install-config
Hello @markmerchant
Thanks for following up with the detail on the upgrade results, from the last line it appears that it is stops
Should see this:
Should see the 'nagios' PID in the '/run/nagios.lock':
Results:
Then;
Perry
grep -Ei 'nagios.lock' /usr/local/nagios/etc/nagios.cfgIs there a 'nagios' process and service running:lock_file=/var/run/nagios.lock
ps -aux | grep -Ei 'nagios.cfg && systemctl status nagiosCode: Select all
less /run/nagios.lockLet's create and rerun the upgrade:PID # on nagios process
touch /run/nagios.lockCode: Select all
markmerchant
Will try this on Monday, Thx.
