Trouble getting LDAP wizard to work
Re: Trouble getting LDAP wizard to work
Lets run the following command editing only the IP and password (note we changed to check_ldap from check_ldaps)
/usr/local/nagios/libexec/check_ldap -H 192.168.99.x -b "DC=whro,DC=local" -D "CN=ron bennington,OU=WHRO Staff,OU=Real Users,OU=User OUs,DC=whro,DC=local"-P "PAssword" -2
benningtonr
Post by benningtonr »
Here are the results, thanks again for all your help
[root@nagios ~]# /usr/local/nagios/libexec/check_ldap -H 192.168.99.x -b "DC=whro,DC=local" -D "CN=ron bennington,OU=WHRO Staff,OU=Real Users,OU=User OUs,DC=whro,DC=local"-P "password" -2
Could not search/find objectclasses in DC=whro,DC=local
Do you know what version of the ldap protocol your ldap server uses?
benningtonr
I do not, but I can check.
benningtonr
V3
Then lets try and run the following
/usr/local/nagios/libexec/check_ldap -H 192.168.99.x -b "DC=whro,DC=local" -D "CN=ron bennington,OU=WHRO Staff,OU=Real Users,OU=User OUs,DC=whro,DC=local"-P "PAssword" -3
yancy
Post by yancy »
Your connection string should look like this:
Note CN instead of OU
/usr/local/nagios/libexec/check_ldap -H 192.168.99.x -b "DC=whro,DC=local" -D "CN=ron bennington,CN=WHRO Staff,CN=Real Users,CN=User OUs,DC=whro,DC=local"-P "PAssword"
to verify, from your Windows domain controller,
start > run > ldp
from Ldp:
connection > connect (current user should be fine)
Next:
Browse > search >
Base DN:
Scope: Subtree
Example results:
ldap_search_s(ld, "CN=usernagios,CN=Users,dc=jupiter,dc=nagios,dc=org", 0, "(objectclass=*)", attrList, 0, &msg)
Getting 1 entries:
Dn: CN=usernagios,CN=Users,dc=jupiter,dc=nagios,dc=org
canonicalName: jupiter.nagios.org/Users/usernagios;
objectClass (4): top; person; organizationalPerson; user;
benningtonr
***Searching...
ldap_search_s(ld, "DC=whro,DC=local" -D "CN=ron bennington,OU=WHRO Staff,OU=Real Users,OU=User OUs,DC=whro,DC=local"", 2, "(objectclass=*)", attrList, 0, &msg)
Error: Search: Invalid DN Syntax. <34>
Server error: 0000208F: LdapErr: DSID-0C090715, comment: Error processing name, data 0, v1db1
Error 0x208F The object name has bad syntax.
Result <34>: 0000208F: LdapErr: DSID-0C090715, comment: Error processing name, data 0, v1db1
Getting 0 entries:
benningtonr
***Searching...
ldap_search_s(ld, "DC=whro,DC=local" -D "CN=ron bennington,CN=WHRO Staff,CN=Real Users,CN=User OUs,DC=whro,DC=local"", 2, "(objectclass=*)", attrList, 0, &msg)
Getting 0 entries:
yancy
Post by yancy »
Just to confirm, your AD FQDN is "whro.local"
can you ping that address:
ping whro.local
for example,
C:\Users\Administrator>ping nagios.jupiter.org
Pinging nagios.jupiter.org [176.74.176.175] with 32 bytes
Reply from 176.74.176.175: bytes=32 time=114ms TTL=49
***Searching...
ldap_search_s(ld, "CN=administrator,CN=Users,dc=jupiter,dc=nagios,dc=org", 2, "(objectClass=*)", attrList, 0, &msg)
Getting 1 entries:
Dn: CN=Administrator,CN=Users,DC=jupiter,DC=nagios,DC=org
canonicalName: jupiter.nagios.org/Users/Administrator;
description: Built-in account for administering the computer/domain;
