Trouble getting LDAP wizard to work
benningtonr
I have entered the following trying to get the ldap che4cks to worl, but i have had no success.
check_xi_service_ldap!-b "DC=whro,DC=local" -D "CN=ron bennington,OU=WHRO Staff,OU=Real Users,OU=User OUs,DC=whro,DC=local"-P "PAssword" -2
The error is:
Could not search/find objectclasses in DC=whro,DC=local
Thanks for all the help
The error is:
Re: Trouble getting LDAP wizard to work
Does your server require the Bind DN: of DC=whro,DC=local ??
benningtonr
I tried it without the bind and get this:
Could not search/find objectclasses in CN=Ron Bennington,OU=WHRO Staff,OU=Real Users,OU=User OUs,DC=whro,DC=local
benningtonr,
do you have SSL enabled on your LDAP server? If so, I believe you'll want to use check_ldaps instead of check_ldap.
try your connection string here:
[root@CENT6_x64_IP_79 /]$ /usr/local/nagios/libexec/check_ldaps
check_ldaps: Could not parse arguments
Usage: check_ldaps -H <host> -b <base_dn> [-p <port>] [-a <attr>] [-D <binddn>]
[-P <password>] [-w <warn_time>] [-c <crit_time>] [-t timeout]
[-2|-3] [-4|-6]
[-2|-3] [-4|-6]
benningtonr
I get the following:
[root@nagios ~]# /usr/local/nagios/libexec/check_ldaps -H 192.168.99.x -D CN=Ron Bennington,OU=WHRO Staff,OU=Real Users,OU=User OUs,DC=whro,DC=local
Could not init startTLS at port 389!
[root@nagios ~]# /usr/local/nagios/libexec/check_ldap -H 192.168.99.x -D CN=Ron Bennington,OU=WHRO Staff,OU=Real Users,OU=User OUs,DC=whro,DC=local
Could not search/find objectclasses in Bennington,OU=WHRO
Are you using TLS, SSL or neither in your implementation of OpenLDAP?
benningtonr
I am not sure, how would I tell?
benningtonr
I am using AD, Windows Server 2008 R2
Are we sure you can connect to the LDAP server at all?
Can you run the following from your XI machine
telnet 192.168.99.x 389-
benningtonr
Connected fine
login as:
@192.168.99.69's password:
Last login: Mon Jul 16 07:57:23 2012 from whro-ron-w7.whro.local
[@nagios ~]# telnet 192.168.99.x 389
Trying 192.168.99.x...
Connected to 192.168.99.x.
Escape character is '^]'.
Connection closed by foreign host.
[@nagios ~]#
login as:
[@nagios ~]#
