Return code of 4 is out of bounds
Re: Return code of 4 is out of bounds
What I see is an conflict is the arguments in the command definition and the arguments in the service check's arguments.
Your command line is
command_line    $USER1$/check_port.pl -p $ARG1$ -h $HOSTADDRESS$
And the service check command is this
check_command check_port.pl! -p 80 -h www.google.com '-w 1 -c 2 -v'
It is specifying the -p and the -h option twice in the command which is causing the error.
Change the command line to this for the command
command_line    $USER1$/check_port.pl $ARG1$
Change the check command for the service like this.
check_command check_port.pl! -p 80 -h www.google.com -w 1 -c 2 -v
Then try it out and see if it works.
pintu
Post by pintu »
It's working now, thanks a lot for the suggestion. Details - but they could be annoying
kg2857
Post by kg2857 »
Please explain so we can all learn...
Post Reply
