Return code of 4 is out of bounds
pintu
Post by pintu »
I know that there are many inquiries regarding :
(Return code of 4 is out of bounds : /usr/local/nagios/libexec/check_port.pl -p <port> -h <host> (-c <critical> -w <warning> -v)))
but I haven't found an answer, so I would like to ask.
In my Nagios configuration, I have set up:
use none
host_name TEST
service_description Port 80
check_command check_port.pl! -p 80 -h www.google.com '-w 1 -c 2 -v'
max_check_attempts 1
check_interval 1
retry_interval 1
And I'm getting a return:
I am running it from the command line.
./check_port.pl -p 80 -h google.pl -w 1000.0,80% -c 2000.0,100% -v
I get:
PORT 80 OK: google.pl/80 is responding
Which ties to the following command:
        command_name    check_port.pl
        command_line    $USER1$/check_port.pl -p $ARG1$ -h $HOSTADDRESS$
Where is the problem?
kg2857
Re: Return code of 4 is out of bounds
Post by kg2857 »
From the docs the -c and -w want integer values in seconds. A return value of 4 isn't in the range of 0-3 that are valid. The output described suggests a syntax issue.
pintu
Post by pintu »
Can you write exactly about which syntax you have in mind?
I tried:
        command_line    $USER1$/check_port.pl -p $ARG1$ -h $ARG2$ -w $ARG3$ -c $ARG4$ -v
        command_line    $USER1$/check_port.pl -p $ARG1$ -h $HOSTADDRESS$ -w $ARG2$ -c $ARG3$ -v
check_command check_port.pl! -p 80 -h www.google.com '-c 1 -w 2 -v'
pintu
Post by pintu »
any idea? someone can help?
pintu
Post by pintu »
Can anyone suggest anything?
kg2857
Post by kg2857 »
Read the script and find out why it doesn't like the syntax you use, which we see is the issue--syntax in case it was missed...
dameonmills
Post by dameonmills »
Can you point out where you think you missed it?
eloyd
Cool Title Here
Post by eloyd »
You say you're running from the command line, but I'll assume you're running as root. What happens if you run as Nagios user:
# su - nagios
$ ./check_port.pl -p 80 -h google.pl -w 1000.0,80% -c 2000.0,100% -v
pintu
Post by pintu »
-sh: 1: ./check_port.pl: not found
From this level, I cannot go to the location: /usr/local/nagios/libexec/ and that's why it wasn't found.
kg2857
Post by kg2857 »
The . translates to the current dir so you have to be in the dir containing the script to run it.
I'm not sure I like the quotes around some of the args in the following, but I could be full of crap...
Naming a command after the script could cause confusion so I'd name the command check_port.
Post Reply
