Hi
I have made a short test with IE9, it seems that it doesn't work.
Regards Andy
Problem with Browser on client systems
Re: Problem with Browser on client systems
Have you tried compatibility mode in IE 9?
YEs, I did same story .....
I just tested hypermap again on IE9 and it worked just fine...
Are you accessing from the same machine using the same URL when you test firefox (working) and IE (not working)?
Yes this was the same Laptop, but just for information, our company will actually not change the standard Browser to IE9 and as it looks also not in the near future. there is a bigger chance to get the allowance with Firefox and IE8 than with IE9.
Of the choices Firefox would be best, but I'm still baffled by IE9 not working...
For me its not so nice to have our IT Department to allow Firefox for this reason, but it looks like I have to.
IE9 is no Option at all standard is IE8, and with a lot of begging i maybe can get Firefox .....
Can you do an F12 on IE and let us know what selections you have for "Browser Mode" and "Document Mode?"
I did make that under IE8 ....
Browser Mode: IE8 Document Mode: IE8
Regards Andy
Regards Andy
Hi there,
have made a short Test with IE9 .......
same problems like with IE8
So either i convince Mgmt to Firefox or .... ???
