Solved !
It was a bug in the Perl script. There was a wrong path to library. Thank you for your help !
Cheers,
Bogdan B
200 code website
Re: 200 code website
Bogdan B,
Glad to hear it's been solved. If you have a chance, it would be great if you posted what library you needed to change.
Thanks!
-Yancy
Thanks!
-Yancy
I replaced use lib "/usr/lib/nagios/plugins"; with use lib "/usr/local/nagios/libexec";
#!/usr/bin/perl -w
# check_squid - Nagios check plugin for testing a Squid proxy
# Christoph Haas <[email protected]>
# Andre Osti <[email protected]>
# License: GPL 2
# V0.2
require 5.004;
use POSIX;
use strict;
use Getopt::Long;
use vars qw($opt_V $opt_h $opt_t $opt_u $opt_n $opt_s
$opt_p $opt_l $opt_o $opt_m $opt_e);
use vars qw($PROGNAME);
use utils qw($TIMEOUT %ERRORS &print_revision &support &usage);
use LWP::UserAgent;
use HTTP::Request::Common qw(POST GET);
use HTTP::Headers;
my ($url, $urluser, $urlpass, $proxy, $proxyport,
$proxyuser, $proxypass, $expectstatus, $res, $req);
$PROGNAME = "check_squid_lw.pl";
sub print_help();
sub print_usage();
Getopt::Long::Configure('bundling');
GetOptions("V" => \$opt_V, "version" => \$opt_V,
"h" => \$opt_h, "help" => \$opt_h,
"t=s" => \$opt_t, "timeout=i" => \$opt_t,
"u=s" => \$opt_u, "url=s" => \$opt_u,
"n=s" => \$opt_n, "urluser=s" => \$opt_n,
"s=s" => \$opt_s, "urlpass=s" => \$opt_s,
"p=s" => \$opt_p, "proxy=s" => \$opt_p,
"l=s" => \$opt_l, "proxyport=s" => \$opt_l,
"o=s" => \$opt_o, "proxyuser=s" => \$opt_o,
"m=s" => \$opt_m, "proxypass=s" => \$opt_m,
"e=i" => \$opt_e, "status=i" => \$opt_e);
if ($opt_V) {
print_revision($PROGNAME,'$Revision: 0.1 $'); #'
exit $ERRORS{'OK'};
if ($opt_h) {print_help(); exit $ERRORS{'OK'};}
($opt_u) || ($opt_u = shift) || usage("Use -h for more info\n");
$url = $opt_u;
($opt_p) || ($opt_p = shift) || usage("Use -h for more info\n");
$proxy = $opt_p;
($opt_l) || ($opt_l = shift) || usage("Use -h for more info\n");
$proxyport = $opt_l;
($opt_e) || ($opt_e = shift) || usage("Use -h for more info");
$expectstatus = $opt_e;
if(defined($opt_n)) { $urluser = $opt_n; }
if(defined($opt_s)) { $urlpass = $opt_s; }
if(defined($opt_o)) { $proxyuser = $opt_o; }
if(defined($opt_m)) { $proxypass = $opt_m; }
my $ua = new LWP::UserAgent;
my $h = HTTP::Headers->new();
if ($proxy)
$ua->proxy(['http', 'ftp'], "http://$proxy:$proxyport");
if ($proxyuser)
$h->proxy_authorization_basic($proxyuser,$proxypass);
if ($urluser)
$h->authorization_basic($urluser, $urlpass);
$req = HTTP::Request->new('GET', $url, $h);
$res = $ua->request($req);
if ($res->status_line =~ /^$expectstatus/)
print "OK - Status: ".$res->status_line."\n";
exit $ERRORS{"OK"};
else
print "CRITICAL - Status: ".$res->status_line." (but expected $expectstatus...)\n";
exit $ERRORS{"CRITICAL"};
sub print_usage () {
print "Usage: $PROGNAME -u <internet site> -p <proxy> -l <port proxy> -e";
print "<return http code> \n";
sub print_help () {
print "Perl check squid proxy\n";
print_usage();
print "
-V, --version
Version this script
-h, --help
Help
-t, --timeout=INTEGER
default 15s
-u, --url=http://<site>
The URL to check on the internet (http://www.google.com)
-n, --urluser=username
Username if the web site required authentication
-s, --urlpass=password
Password if the web site required authentication
-p, --proxy=proxy
Server that squid runs on (proxy.mydomain)
-l, --proxyport=INTEGER
TCP port that Squid listens on (3128)
-o, --proxyuser=proxyuser
-m, --proxypass=proxypass
-e, --status=INTEGER
HTTP code that should be returned
support();
