200 code website
Bogdan_B
200 code website
Post by Bogdan_B »
I try to monitor my website. My expectation is 200 code. All is fine if I run below command but when I try to customize in Nagios Core Config Manager I received Return code of 126 is out of bounds - plugin may not be executable message. Could you please help me? Thank you !
[root@NagiosXi libexec]# ./SCRIPT.pl -u https://website.com -p xxx.xxx.xxx.xxx -l yy -e 200
OK - Status: 200 OK
Command line is :
$USER1$/SCRIPT.pl -U $HOSTADDRESS$ -P $ARG1$ -L $ARG2$ -E $ARG3$
ARG1=xxx.xxx.xxx.xxx
ARG2=yy
ARG3=200
nscott
Re: 200 code website
Post by nscott »
In the command definition you are using -E, while in the command line you're using -e, try rectifying that problem and see if that fixes it.
Nicholas Scott
Bogdan_B
Post by Bogdan_B »
Hi I rectified but the error is still there. :evil:
# cd /usr/local/nagios/libexec
[root@NagiosXi libexec]# ./script.pl -u HOST -p xxx.xxx.xxx.xxx -l yy -e 200
OK - Status: 200 OK
Command line:
 $USER1$/script.pl -u $HOSTADDRESS$ -p $ARG1$ -l $ARG2$ -e $ARG3$
Service Management of HOST
$ARG1$ = xxx.xxx.xxx.xxx
$ARG2$ = yy
$ARG3$ = 200
Additional templates
Template name = xiwizard_website_http_service ( I already tried generic-service template )
The error message is : (Return code of 126 is out of bounds - plugin may not be executable)
Bogdan_B
Post by Bogdan_B »
I rectified it but still not work. :evil:
Let's recap:
[root@NagiosXi libexec]# ./script.pl -u https://intranet -p xxx.xxx.xxx.xxx -l yy -e 200
OK - Status: 200 OK
Command line:
where:
$ARG1$=xxx.xxx.xxx.xxx
$ARG2$=yy
$ARG3$=200
P.S. I would like to have rights for Customers section because I bought Nagios Xi, what should I do ?
nscott
Post by nscott »
IN the command definition you're referring to it as czwiki.pl and in the command line example its script.pl, not sure if you're editing one, but that would cause it.
Also, could you post the permissions on the plugin directory?
ll /usr/local/nagios/libexec/
Nicholas Scott
Bogdan_B
Post by Bogdan_B »
Do you want the permissions only for script.pl right?
-rwsrwsr--  1 root   root      3529 Jul 10 15:20  script.pl
I forgot to change the name only in the last post, the name of script is the same in both.
Cheers
yancy
Post by yancy »
Bogdan_B,
Are the permissions of this file different from other files in that directory?
Regards,
-Yancy
nscott
Post by nscott »
If its going to be owned by root, you'll definitely have to make it executeable for other. I also see you have the sticky bit enabled, this should do the trick:
chmod 7555 <scriptname>
Nicholas Scott
Bogdan_B
Post by Bogdan_B »
@nscott
-r-sr-sr-t 1 root root 3529 Jul 10 15:20 /usr/local/nagios/libexec/script.pl
Now the Status information is (null). :?:
@ yancy
Yes, there are different rights for different files. You can see below one of them who works :
-rwxr-xr-x  1 apache apache    4361 May 15 12:43 ckformlogin.pl
But I already tried those rights for script.pl and no success.
yancy
Post by yancy »
Bogdan_B,
This will match the file permissions to the one that works
 chmod 755 <scriptname>
-Yancy
