Event Handlers in Scheduled Downtime
-SN
Re: Event Handlers in Scheduled Downtime
Post by -SN »
The onus should lie with the event handler not the admins.
To do this, in your handler, put a guard in place to make sure that the handler should fire.
#SUDO CODE
#DETERMINE DOWNTIME STATUS
def isInDowntime(data):
    if int(data.downtime) > 0:
        return True
    else:
        return False
#CHECK DOWNTIME STATUS
if isInDowntime(data):
    exit()
else:
    doStuff(data)
Now, there's no flaming hoops for the admins/users to jump through to quiet the notifications or stop the handler actions from being executed.
You handler should not introduce more toil, it should help to reduce it :)
Happy Monitoring!
--SN
Post Reply
