Event Handlers in Scheduled Downtime
NeoMatrixJR
Post by NeoMatrixJR »
I have checks with Event Handlers used to restart failed windows services. We will be upgrading those services this weekend and I need the event handlers to not fire when they detect an outage. Does placing a service check in Scheduled Downtime disable event handlers or do I need to deactivate the service check configs or is there another recommended method for disabling these?
swolf
Re: Event Handlers in Scheduled Downtime
Post by swolf »
Hi @NeoMatrixJR,
It looks to me like downtimes only block notifications, not event handlers. I think you'll want to directly disable event handlers for each of the hosts/services you're upgrading.
If you need Nagios Core to stay running the whole time, I would probably use external commands - here is the documentation to disable an event handler for a specific host.
If it's easier for you to change the configuration and restart Core instead, you can just set the event_handlers_enabled directive for each host or service that needs them disabled. If you're using the CCM that's in [Host/Service] -> Edit -> Check Settings. If you're using the bulk modifications tool, it should show up in "Change single config option", towards the bottom of the dropdown.
Hopefully that helps - please let me know if you have any further questions or concerns.
NeoMatrixJR
This will be on an instance of Nagios XI. I'm going to be instructing application admins on how to go in and make changes. I'll be driving them through the change this afternoon. It sounds like the easiest path for them would be to disable the service check altogether in the GUI for the duration and then re-enable when done.
swolf
Post by swolf »
That is useful context! I agree, if you have a team that you can delegate to, so that everyone is only updating a few hosts, then disabling and re-enabling the service checks individually should be fine. The two approaches I gave in the third paragraph could still work, but that's more useful if you're doing bulk management of your hosts and/or trying to get the job done as an individual.
NeoMatrixJR
Not sure how to make this a feature request, but I'd suggest that if a service is in scheduled downtime, event handlers for that service shouldn't fire.
swolf
Post by swolf »
I agree that this seems reasonable to add! I've added an issue for this on Github.
nicklesta
Post by nicklesta »
swolf wrote: Tue Mar 19, 2024 10:39 am I agree that this seems reasonable to add! I've added an issue for this on Githubsnow rider 3d
Which file would that be?
snapier3
Post by snapier3 »
This is not a good idea...
This change would then stop all "on-state-change" event handlers from being executed during a downtime window.
The handler should be executed when any host or object changes state i.e. global event handlers.
You account for this possibility by adding a step to check for a downtime depth greater than 0 to your event handler which is meant to operate outside notifications.
$SERVICEDOWNTIME$
$HOSTDOWNTIME$
Are the nagios macros that you'll want to pass as variables to evaluate in your handler.
Mikasa23
Post by Mikasa23 »
I’m not sure Scheduled Downtime alone will be sufficient. In some systems, event handlers might still run if they’re looking for specific patterns or thresholds, even if the checks themselves are in downtime. If you can, test it on a non-critical service first and see if the event handler is still firing. In my experience, it’s better to deactivate the checks completely and only reactivate them once everything is back up. That way, Block Blast you can be sure you won’t get any false alarms.
Vennpauly
Post by Vennpauly »
If you need Nagios Core to stay running the whole time, I would probably use external commands - heredrive mad is the documentation to disable an event handler for a specific host.
When I place a service in Scheduled Downtime, is there any other method to ensure that event handlers do not trigger, aside from directly disabling them for each service?
Post Reply
