This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
lveitch
Posts: 38 Joined: Fri Mar 22, 2024 10:02 am
Post
by lveitch » Mon Apr 01, 2024 1:36 pm
I went ahead and just ran the
wget -O upgrade.sh https://assets.nagios.com/downloads/nagiosxi/upgrade.sh
sh ./upgrade.sh to install the upgrade and that worked great.
But updating from the UI still generates that failed update check
cnorell
Developer
Posts: 141 Joined: Mon Nov 27, 2017 3:08 pm
Post
by cnorell » Tue Apr 02, 2024 9:34 am
Interesting, I'll create a ticket internally to take a look and try to recreate the issue. Thanks for the details.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
lveitch
Post
by lveitch » Wed Apr 03, 2024 11:37 am
I appreciate it! let me know if you need anything additional from me as I will gladly check and give what information i can.
sgardil
Posts: 357 Joined: Wed Aug 09, 2023 9:58 am
Post
by sgardil » Mon Apr 08, 2024 10:14 am
lveitch wrote: ↑ Wed Apr 03, 2024 11:37 am
Hey
@lveitch
I am unable to reproduce this issue to try to find whats wrong. Could you open a tick with our support team
here and they can try to find what exactly is going wrong with your system?
lveitch
Post
by lveitch » Tue Apr 09, 2024 9:51 am
Wish I could; dont believe the org paid for support features....just the standard license for our nodes.
Its all good. I will just add a scheduled task to my workflow to login and check for updates manually
I appreciate you looking into this and seeing if anything showed up
