Performace graphs not displayed after upgrade
sreinhardt
-fno-stack-protector
Re: Performace graphs not displayed after upgrade
Post by sreinhardt »
I see that most of your checks are for nrpe or local checks. It also appears that you may have installed mklivestatus, is this correct?
Specifically the check_load and check_swap, are only local checks, despite being run against a hostgroup. Lets check exactly what files you have in perfdata like before but recursive.
ls -lat /usr/local/nagios/share/perfdata/
Also if you could answer my question above about whether you see host check perfdata, that would be great.
fao
Post by fao »
mklivestatus has been installed far after the issue reported here.
Yes, we can see host perfdata.
[root@hqldvnagios1 libexec]# ls -lat /usr/local/nagios/share/perfdata/
total 56
drwxrwxr-x. 2 nagios nagios 4096 Jun 11 15:47 .pnp-internal
drwxrwxr-x 2 nagios nagios 4096 Jun 11 15:46 localhost
drwxrwxr-x 2 nagios nagios 4096 Jun 11 15:45 HQLTEST1
drwxrwxr-x 2 nagios nagios 4096 Jun 11 15:45 HQLTEST2
drwxrwxr-x 2 nagios nagios 4096 Jun 11 15:44 firms.fao.org
drwxrwxr-x 2 nagios nagios 4096 Jun 11 15:43 FIRMS_website
drwxrwxr-x 2 nagios nagios 4096 Jun 11 15:42 Fishery_website
drwxrwxr-x. 14 nagios nagios 4096 Jun 11 12:49 .
drwxrwxr-x 2 nagios nagios 4096 Jun 11 12:49 ES_Connect_website
drwxrwxr-x 2 nagios nagios 4096 Jun 11 11:25 hqlprdhcp2
drwxrwxr-x 2 nagios nagios 4096 Jun 11 11:25 cio052
drwxrwxr-x 2 nagios nagios 4096 Jun 11 11:24 hqesxtcdr01
drwxrwxr-x 2 nagios nagios 4096 Jun 4 18:33 nagiosgrms.fao.org
drwxrwxr-x. 14 nagios nagios 4096 May 24 15:52 ..
abrist
Red Shirt
Post by abrist »
Just a quick question/curiosity: Have you attempted to view the performance graphs in a different browser?
Additionally, can browse directly to a pnp graph url?
https://<XI server IP>/nagiosxi/perfgraphs/?&host=HQLTEST1
Or any other host graph:
https://<XI server IP>/nagiosxi/perfgraphs/?&host=<hostname>
fao
Post by fao »
I've tried unsuccessfully to display services performance graphs on various browsers (IE, Firefox, Chrome).
I'm able to browse directly to any host pnp graph using http://<XI server IP>/nagiosxi/perfgraphs/?&host=<hostname>
anritter6281
Post by anritter6281 »
This issue is happening to me as well. It started with an NagiosXI update I did back in May, but I just did the 2012R2.2 update and the performance graphing is still empty. I did a sub-component reinstall of PNP which did not fix it, but has fixed it in the past (because this has broken in the past, but only after an update.). I also did a permissions check, and I turned on PNP logging to look for errors.
I post to this topic only to make you all aware I was having the problem as well in the hopes that it can help get it fixed. Please let me know if you want debugging information from me.
fao
Post by fao »
Any help will be greatly appreciated as we've been without graphs for a while now.
We may have to schedule a remote session to further troubleshoot your issue. Please, send us an email at [email protected]. Type "Performace graphs not displayed after upgrade" in the email's subject field. Thanks!
Post by slansing »
Closing and moving to ticket system.
