error on service check
Re: error on service check
If the Security Panel check is a ping check, it should just work. I wonder if there is a syntax issue. Could you post the service config for the Security Panel check?
Its same for me, I have upgraded the version 3.3.1 to 4.0.0 and its giving me the same error message on checks and this is random.
Sometime its showing error message some time showing correct values. I ran those commands locally from shell and output is correct.
ran same check from nagios Server from NRPE and gicing me correct values but not on the WebUI of nagios.
Nagios WebUI :
Shell output from Nagios Server
Nagios WebUI :
[nagios-server]# /opt/nagios/libexec/check_nrpe -H HOST-IPADDRESS -c check_load
OK - load average: 0.00, 0.00, 0.00|load1=0.000;15.000;30.000;0; load5=0.000;10.000;25.000;0; load15=0.000;5.000;20.000;0;-
steve.gregory
Hi Dean/everyone... I've also just updated to the latest stable release. Now I'm getting the same problem also! Each command works from the commandline but not from within Nagios itself. I get the same error under Status Information ((No output on stdout) stderr:)DeanM wrote:Yes, The commands work and have the proper output from the command line.
Now some checks are working... and some aren't... I'm going to watch this topic as i'm at a loss as to why the check works from the command line but not from within nagios. Very confused
Steve
Re: Nagios (Check_sftp)
We are unable to find any files in check_sftp_bin.tar and check_sftp_source.tar from this URL
http://exchange.nagios.org/directory/Pl ... tp/details
Can you please suggest any alternate links from which we can download these files?
steve.gregory
Update: fwiw guys, I've just downloaded the last release of stable v3 and installed this. All is back to normal again. I'll leave v4 for now
but i'll follow this stream here still. Thanks, Steve.
host_name pal
service_description pal Security Panel ;
check_command trace!10.22.16.90!4000.0,80%!5000.0,100%
normal_check_interval 30
retry_check_interval 3
notification_interval 0
first_notification_delay 0
max_check_attempts 2
host_name pal
I did also and all is working. I am going to have to try 4.0 in test.steve.gregory wrote:Update: fwiw guys, I've just downloaded the last release of stable v3 and installed this. All is back to normal again. I'll leave v4 for nowbut i'll follow this stream here still. Thanks, Steve.
Please do try it in a testing environment first. It has only been available for less than two weeks.
Downgraded to 3.5.1 and all works fine again.
Nix
Nix
If you have not done so already, open a bug report at http://tracker.nagios.org
