error on service check
DeanM
Post by DeanM »
Hi
I am new to nagios and this board. I was given the task to update nagios to 4.0.0 from 3.5.0. The make and install ran without errors and startup was clean. I have been looking through the boards for anything similar but have not found it yet can someone point me in the right direction.
I have the following error in the Status Information of the (ping and ifstatus) service check for my switch.
(No output on stdout) stderr:
Re: error on service check
Post by slansing »
Can you please post a copy of your service definition which is displaying this issue? Is this only occurring on the switches ping check and not elsewhere?
DeanM
Post by DeanM »
A copy of the service descriptions. This is occuring on ping and an snmp call.
use generic-service ; Inherit values from a template
host_name *,!isp
hostgroup_name !dns,!7
service_description PING ; The service description
check_command check_ping!6000.0,80%!7000.0,100% ; The command used to monitor the service
normal_check_interval 1 ; Check the service every 1 minutes under normal conditions
retry_check_interval 1 ; Re-check the service every minute until its final/hard state is determined
notification_interval 0
first_notification_delay 0
max_check_attempts 2
event_handler_enabled 1
event_handler traceme
use generic-switch
host_name pal
alias Center Router
notes ;NOTES
address 10.22.116.2
hostgroups 1
parents liberty-A
# trace
command_name trace
command_line $USER1$/check_icmp -H $ARG1$ -w $ARG2$ -c $ARG3$ -p 5
host_name pal
service_description palsw
check_command trace!10.22.16.11!4000.0,80%!5000.0,100%
# 'ifcheck_new' command definition
command_name ifcheck_new
command_line $USER1$/ifcheck_new $ARG1$ $ARG2$ $ARG3$ $ARG4$ $ARG5$ $ARG6$
host_name 1A
service_description PORT check GigabitEthernet7/45
check_command ifcheck_new!-C ^6T11xOdmK9^ -H 10.21.28.11 -d GigabitEthernet7/45
normal_check_interval 60
retry_check_interval 10
servicegroups port_check
Post by slansing »
Are you able to successfully run these commands from the command line? Do they still error out?
DeanM
Post by DeanM »
Yes, The commands work and have the proper output from the command line.
Post by slansing »
What distro are you running this core installation on? And how did you install it?
DeanM
Post by DeanM »
cent os with 2.6.18-348.18.1.el5 kernel.
DeanM
Post by DeanM »
Installed according to directions on install guide.
did a
wget http://osdn.dl.sourceforge.net/sourcefo ... y.z.tar.gz
did a
tar xzf nagios-x.y.z.tar.gz
cd nagios
ran
./configure --with-command-group=nagcmd
ran with no errors
make all
ran with no errors
make install
ran
restart was clean
/sbin/service nagios restart
Post by slansing »
What is the exact version of nagios core that you are installing? What is the true "nagios-x.y.z.tar.gz" you are untarring? There was a bug involving this with 4.0 beta 4 and the only solution was to roll back to 4.0 beta 1.
DeanM
Post by DeanM »
nagios-4.0.0.tar.gz
