Just failed manual logins I've wrongly done myselfabrist wrote: Any logs worth mentioning from the remote db?
[SOLVED] NDOUtils Nagios and MySQL Server on different hosts
- sebastiaopburnay
Re: NDOUtils - Nagios and MySQL Server on different hosts
So you are able to connect them just fine now?
- sebastiaopburnay
No, that GRANT ALL has been done more that a week ago...
Strangely the Nagios Core Server is still unable to write no the remote MySQL DB.
I will ytry to reinstall NDOUtils in the Nagios Core Server... I've sen that solution working for others in some posts at linuxforums
Alright, keep us informed.
- sebastiaopburnay
Well, I'm a bit frustrated:
- I've uninstalled and reinstalled ndoutils from my nagios core server:
- Removed binaries and config files;
- Deleted log files
- Recompiled source code and placed generated binaries in respective place
- Re-Created configs and set them to appropriate values
- I've deleted and re-created nagios' BD at my MySQL server and granted required privileges
I still have exactly the same issue.....
Anyone has any idea?
- Deleted log files
Hmm. I presume you have checked remote access after the reinstall?
su nagios
mysql -u nagios -p'<PASSWORD>' -h <IP_ADDRESS_OF_MYSQL_SERVER>Former Nagios employee
- sebastiaopburnay
Yes, it works fine trough CLI mysql accessabrist wrote:Hmm. I presume you have checked remote access after the reinstall?Code: Select all
su nagios mysql -u nagios -p'<PASSWORD>' -h <IP_ADDRESS_OF_MYSQL_SERVER>
root@NagiosCoreServer:/usr/local/nagios/var# mysql -u nagios -h 172.20.81.135 -pnagios
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 91
Server version: 5.5.31-0ubuntu0.12.04.2-log (Ubuntu)
Copyright (c) 2000, 2013, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql>
I'll try that aproach tomorrow
OK. I will go back over this thread and see if I missed anything. Let us know.
- sebastiaopburnay
Well, I'm getting strange results
1 - I dropped my previous NDOUtils Schema on my DB server
2 - I stopped the NDO2DB service on my Nagios' Core Server
3 - I removed binaries and log/lock/sock files associated with NDOUtils
4 - I installed version 1.5.2 and used the installdb script on my DB server on a newly created schema with adequate previleges
5 - Moved chmod'ed and chown'ed the binaries to /usr/local/nagios/var on my Nagios' Core Server
6 - Stopped Nagios
7 - Started ndo2db
8 - Started Nagios while tracking (tail -f) the nagios.log activity
My nagios.log gives strande output
My NDOUtils DataBase is already showing Nagios' reccords of hosts and services on nagios_objects, bun nagios_services and nagios_hosts come as empty sets
6 - Stopped Nagios
7 - Started ndo2db
[1386959714] Nagios 3.5.0 starting... (PID=22090)
[1386959714] Local time is Fri Dec 13 18:35:14 UTC 2013
[1386959714] LOG VERSION: 2.0
[1386959714] Error: Unable to open file '/usr/local/nagios/bin/ndomod.o' for reading: No such file or directory
[1386959714] Error: Failed to safely copy module '/usr/local/nagios/bin/ndomod.o'. The module will not be loaded
mysql> SELECT * FROM nagios_objects;
| object_id | instance_id | objecttype_id | name1 | name2 | is_active |
| 1 | 1 | 1 | ITEN-SRVCARTMSCORE01 | NULL | 0 |
| 2 | 1 | 9 | 24x7 | NULL | 0 |
| 3 | 1 | 12 | check-host-alive | NULL | 0 |
| 4 | 1 | 2 | ITEN-SRVCARTMSCORE01 | Current Users | 0 |
| 5 | 1 | 12 | check_local_users | NULL | 0 |
| 6 | 1 | 2 | ITEN-SRVCARTMSCORE01 | Total Processes | 0 |
| 7 | 1 | 12 | check_local_procs | NULL | 0 |
| 8 | 1 | 2 | ITEN-SRVCARTMSCORE01 | Current Load | 0 |
| 9 | 1 | 12 | check_local_load | NULL | 0 |
| 10 | 1 | 1 | ITEN-SRVCAREZV01 | NULL | 0 |
| 11 | 1 | 2 | ITEN-SRVCARTMSCORE01 | PING | 0 |
| 12 | 1 | 12 | check_ping | NULL | 0 |
| 13 | 1 | 2 | ITEN-SRVCARTMSCORE01 | SSH | 0 |
| 14 | 1 | 12 | check_ssh | NULL | 0 |
14 rows in set (0.00 sec)
mysql> SELECT * FROM nagios_hosts;
Empty set (0.00 sec)
mysql> SELECT * FROM nagios_services;
Empty set (0.00 sec)Re: NDOUtils - Nagios and MySQL Server on different hosts
What is the output of:
ls -la /usr/local/nagios/bin/
grep "ndomod" /usr/local/nagios/etc/nagios.cfgFormer Nagios employee
