nagiosxi stuck at applying configuration
nanz28v
Re: nagiosxi stuck at applying configuration
Post by nanz28v »
I recreated the host "Ironmail-CT1" and I still have the problem. Attached please find the screenshot on the host category.
Post by slansing »
Did you apply configuration after adding it?
nanz28v
Post by nanz28v »
Yes I did yet it still runs forever... 8(
abrist
Red Shirt
Post by abrist »
Rerun the verification:
nanz28v
Post by nanz28v »
root@sm5nag01:~[root@sm5nag01 ~]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.
cfg
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config directory '/usr/local/nagios/etc/services'...
Error: Could not find any host matching 'Ironmail-CT1' (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 41)
Error: Could not expand members specified in hostgroup (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 41)
]0;root@sm5nag01:~[root@sm5nag01 ~]#
abrist
Red Shirt
Post by abrist »
Apologies. We need to write the files out first. Go to --> ccm --> write config files --> click "write" and then "verify". Post the output of the verification.
nanz28v
Post by nanz28v »
results of verification:
Error: Could not expand hostgroups and/or hosts specified in host escalation (config file '/usr/local/nagios/etc/hostescalations.cfg', starting on line 29)
Nagios Core 3.5.0
License: GPL
Processing object config file '/usr/local/nagios/etc/hosts/Ironmail-CT1.cfg'...
abrist
Red Shirt
Post by abrist »
nanz28v wrote:Error: Could not expand hostgroups and/or hosts specified in host escalation (config file '/usr/local/nagios/etc/hostescalations.cfg', starting on line 29)
Wow, how many changes were made to the configs without successfully applying a config?
You should be getting use to this process by this point. Could you post the file: /usr/local/nagios/etc/hostescalations.cfg
nanz28v
Post by nanz28v »
I have no idea how many configs failed to write, since we don't have that many items setup on this test server. Here is the file attached.
abrist
Red Shirt
Post by abrist »
The following escalation is missing required fields:
define hostescalation {
	first_notification            		3
	last_notification             		0
	notification_interval         		60
	escalation_period             		24x7
You either need to remove the escalation from the ccm, or add a contact and a nagios object to it.
