Random emails
Re: Random emails
[root@g1vpnag01 libexec]# cd /usr/local/nagios
[root@g1vpnag01 nagios]# tar cj /tmp/configs.tar.xz etc/
tar: Removing leading `/' from member names
tar: /tmp/configs.tar.xz: Cannot stat: No such file or directory
bzip2: I won't write compressed data to a terminal.
bzip2: For help, type: `bzip2 --help'.
I do have Host escalation for my servers........ I checked an made sure that its email address is correct.
Everybody is somebody else’s weirdo
- -fno-stack-protector
Re: Random emails
I'd like to be 100% just for safetys sake. Let's try that one more time but slighly different.
tar cjf /tmp/configs.tar.bz2 etc/
Re: Random emails
ok, I have the file.....where would you like me to send it to?
- Box293
- Too Basu
Re: Random emails
Send it to me via private message. You might need to append .txt to the end of the file.JohnFLi wrote:ok, I have the file.....where would you like me to send it to?
- Box293
- Too Basu
Re: Random emails
I've had a good look through your configurations, specifically at the host G1POSTAGE01 as that is the one you provided an example for. I couldn't find anything out of place, it all looks as it should.
I did notice in your nagios.cfg file you have:
Can you please set this to -1
Restart Nagios and see if it catches anything now when these strange emails are sent.
debug_level=1
debug_level=-1
Re: Random emails
ok, after setting debug to -1, I got a couple of rejection emails concerning my machine G1PCWEBSERV02. (oddly enough, 2 emails saying it is up, 1 second part.
Below is from the debug log
[1407344585] SERVICE ALERT: G1PCWEBSERV02;Web_Disk_Idle;CRITICAL;SOFT;1;0.00
[1407344585] SERVICE EVENT HANDLER: G1PCWEBSERV02;Web_Disk_Idle;CRITICAL;SOFT;1;notify-host-by-email
[1407344645] SERVICE ALERT: G1PCWEBSERV02;Web_Disk_Idle;OK;SOFT;2;91.56
[1407344645] SERVICE EVENT HANDLER: G1PCWEBSERV02;Web_Disk_Idle;OK;SOFT;2;notify-host-by-email
[1407344673] wproc: Core Worker 17747: job 756 (pid=21424) timed out. Killing it
[1407344673] wproc: CHECK job 756 from worker Core Worker 17747 timed out after 30.01s
[1407344673] wproc: host=G1VPSQL15; service=(null);
[1407344673] wproc: early_timeout=1; exited_ok=0; wait_status=0; error_code=62;
[1407344673] Warning: Check of host 'G1VPSQL15' timed out after 30.01 seconds
[1407344673] wproc: Core Worker 17747: job 756 (pid=21424): Dormant child reaped
[1407344690] wproc: Core Worker 17744: job 768 (pid=21490) timed out. Killing it
[1407344690] wproc: CHECK job 768 from worker Core Worker 17744 timed out after 30.01s
[1407344690] wproc: host=G1VPSPS01; service=(null);
[1407344690] wproc: early_timeout=1; exited_ok=0; wait_status=0; error_code=62;
[1407344690] Warning: Check of host 'G1VPSPS01' timed out after 30.01 seconds
[1407344690] wproc: Core Worker 17744: job 768 (pid=21490): Dormant child reaped
- Box293
- Too Basu
Re: Random emails
Can you please provide some more log output if possible.
Re: Random emails
as requested
- debug.txt
- (96.32 KiB) Downloaded 275 times
