Random emails
JohnFLi
Random emails
Post by JohnFLi »
In attemping to figure out how to be able to acknowledge alerts via email, I created a mailbox on my exchange server for nagios.
Since then, I have been watching the mailbox so I can see if the acknowledgement get to the mailbox (it does)
but the odd thing is, I am also seeing many NDRs.
Delivery has failed to these recipients or groups:
[email protected]
The e-mail address you entered couldn't be found. Please check the recipient's e-mail address and try to resend the message. If the problem continues, please contact your helpdesk.
I check the "Notification" link and it does not show that any notification were sent out. Why would Nagios be sending random emails? The emails that it is sending is reporting that hosts or either up, or down and the hosts it is reporting on is random.
Everybody is somebody else’s weirdo
sreinhardt
-fno-stack-protector
Re: Random emails
Post by sreinhardt »
Do you have a contact with an invalid email address that might be causing this? Could you show an example of one of the emails? Also when these emails are being sent, is the host or service at that time actually down or recovering as the email states?
JohnFLi
Re: Random emails
Post by JohnFLi »
Nope, the host machines are fine. All contacts have valid emails address's
the NDR that is returned says: (yes, that dollar sign $ is what it really shows in the NDR)
my Nagios server = g1vpnag01
my Exchange server = G1VPEXC02
[email protected]
Diagnostic information for administrators:
Generating server: G1VPEXC02.mycompany.local
[email protected]
#550 5.1.1 RESOLVER.ADR.RecipNotFound; not found ##rfc822;$
Original message headers:
Received: from g1vpnag01.mycompany.local (10.100.1.227) by
G1VPEXC02.mycompany.local (10.100.1.107) with Microsoft SMTP Server id
14.2.347.0; Fri, 25 Jul 2014 08:59:50 -0700
Received: by g1vpnag01.mycompany.local (Postfix, from userid 501) id
1DBC914195E; Fri, 25 Jul 2014 08:59:50 -0700 (PDT)
Date: Fri, 25 Jul 2014 08:59:50 -0700
To: <[email protected]>
Subject: ** Host Alert: G1POSTAGE01 is UP **
User-Agent: Heirloom mailx 12.4 7/29/08
MIME-Version: 1.0
Content-Type: text/plain; charset="us-ascii"
Message-ID: <[email protected]>
Return-Path: [email protected]
Re: Random emails
Post by Box293 »
Is there anything useful being logged?
tail /var/log/messages
What command is being used by your contacts? Here is the one used by generic-contact template.
host_notification_commands	notify-host-by-email    ; send host notifications via email
	command_name notify-host-by-email
	command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/local/bin/sendEmail -s $USER7$ -xu $USER9$ -xp '$USER10$' -t $CONTACTEMAIL$ -f $USER5$ -l /var/log/sendEmail -u "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" -m "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n"
Also, if you are able to reproduce the problem, it might be helpful to turn on debugging and catch what is happening in the debug log.
In nagios.cfg set:
debug_level=-1
The debug file should be:
debug_file=/usr/local/nagios/var/nagios.debug
JohnFLi
Re: Random emails
Post by JohnFLi »
/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n\nName:$NOTIFICATIONAUTHOR$\nNote:$NOTIFICATIONCOMMENT$" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n\nName:$NOTIFICATIONAUTHOR$\nNote:$NOTIFICATIONCOMMENT$" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
From the mail log
Jul 28 07:39:51 g1vpnag01 postfix/pickup[23545]: 4144C14195E: uid=501 from=<nagios>
Jul 28 07:39:51 g1vpnag01 postfix/cleanup[12158]: 4144C14195E: message-id=<[email protected]>
Jul 28 07:39:51 g1vpnag01 postfix/qmgr[7732]: 4144C14195E: from=<[email protected]>, size=696, nrcpt=1 (queue active)
Jul 28 07:39:51 g1vpnag01 postfix/smtp[12160]: 4144C14195E: to=<[email protected]>, orig_to=<$>, relay=10.100.9.19[10.100.9.19]:25, delay=0.73, delays=0.02/0/0.01/0.7, dsn=2.6.0, status=sent (250 2.6.0 <[email protected]> [InternalId=7757010] Queued mail for delivery)
Jul 28 07:39:51 g1vpnag01 postfix/qmgr[7732]: 4144C14195E: removed
sreinhardt
Re: Random emails
Interesting, let's check few places in the flat files:
grep -Ri '\$' /usr/local/nagios/etc/ <- probably will come up with a lot of results.
grep -Ri '\$\@' /usr/local/nagios/etc/
grep -Ri '\@companyname.com' /usr/local/nagios/etc/ <- obviously change companyname. This is to see if there are any empty addresses.
If both of those comeback clean we will need to look at user settings opposed to contact settings.
JohnFLi
Re: Random emails
Post by JohnFLi »
the bottom line came back with nothing.
As for user settings on the Linux box (CentOS) there is only my account and the Nagios account.
sreinhardt
Re: Random emails
I keep writing users, thinking this is the XI forum, my mistake. If the second one came back with a result, you should absolutely look into that one, as it is likely the culprit. Otherwise if you want to PM one of us the contacts.cfg we can certainly take a look. Being as this is core only, and no XI users to worry about, the only place contact definitions should be is in contacts.cfg unless you chose to make a second file to hold contacts.
JohnFLi
Re: Random emails
Post by JohnFLi »
oops, I'm sorry, the last two lines came back with no results.
Re: Random emails
Post by Box293 »
Can you post the results of:
grep -Ri '\@' /usr/local/nagios/etc/
