# NDO2DB DAEMON CONFIG FILE
# Last Modified: 01-02-2009
# LOCK FILE
# This is the lockfile that NDO2DB will use to store its PID number
# in when it is running in daemon mode.
lock_file=/usr/local/nagios/var/ndo2db.lock
# USER/GROUP PRIVILIGES
# These options determine the user/group that the daemon should run as.
# You can specify a number (uid/gid) or a name for either option.
ndo2db_user=nagios
ndo2db_group=nagios
# SOCKET TYPE
# This option determines what type of socket the daemon will create
# an accept connections from.
# Value:
# unix = Unix domain socket (default)
# tcp = TCP socket
socket_type=unix
#socket_type=tcp
# SOCKET NAME
# This option determines the name and path of the UNIX domain
# socket that the daemon will create and accept connections from.
# This option is only valid if the socket type specified above
# is "unix".
socket_name=/usr/local/nagios/var/ndo.sock
# TCP PORT
# This option determines what port the daemon will listen for
# connections on. This option is only vlaid if the socket type
# specified above is "tcp".
#tcp_port=5668
# ENCRYPTION
# This option determines if the ndo2db daemon will accept SSL to encrypt the
# network traffic between module and ndo2db daemon.
# Both sides have to enable this feature which depends on SSL Libraries
# like openssl or kerberos
# This option is only valid if the output type
# option specified above is "tcpsocket".
# A value of '1' will enable this feature
use_ssl=0
# DATABASE SERVER TYPE
# This option determines what type of DB server the daemon should
# connect to.
# Values:
# mysql = MySQL
# pgsql = PostgreSQL
db_servertype=mysql
# DATABASE HOST
# This option specifies what host the DB server is running on.
db_host=localhost
# DATABASE PORT
# This option specifies the port that the DB server is running on.
# Values:
# 3306 = Default MySQL port
# 5432 = Default PostgreSQL port
db_port=3306
# DATABASE NAME
# This option specifies the name of the database that should be used.
db_name=nagios
# DATABASE TABLE PREFIX
# Determines the prefix (if any) that should be prepended to table names.
# If you modify the table prefix, you'll need to modify the SQL script for
# creating the database!
db_prefix=nagios_
# DATABASE USERNAME/PASSWORD
# This is the username/password that will be used to authenticate to the DB.
# The user needs at least SELECT, INSERT, UPDATE, and DELETE privileges on
# the database.
db_user=nagios
db_pass=nagios
## TABLE TRIMMING OPTIONS
# Several database tables containing Nagios event data can become quite large
# over time. Most admins will want to trim these tables and keep only a
# certain amount of data in them. The options below are used to specify the
# age (in MINUTES) that data should be allowd to remain in various tables
# before it is deleted. Using a value of zero (0) for any value means that
# that particular table should NOT be automatically trimmed.
# Keep timed events for 24 hours
max_timedevents_age=1440
# Keep system commands for 1 week
max_servicechecks_age=10080
# Keep host checks for 1 week
max_hostchecks_age=10080
# Keep event handlers for 31 days
max_eventhandlers_age=44640
# Keep external commands for 31 days
max_externalcommands_age=44640
# Keep notifications for 31 days
max_notifications_age=44640
# Keep contactnotifications for 31 days
max_contactnotifications=44640
# Keep contactnotificationmethods for 31 days
max_contactnotificationmethods=44640
# Keep logentries for 90 days
max_logentries_age=129600
# Keep acknowledgements for 31 days
max_acknowledgements_age=44640
# DEBUG LEVEL
# be written to the debug file. OR values together to log multiple
# types of information.
# Values: -1 = Everything
# 0 = Nothing
# 1 = Process info
# 2 = SQL queries
debug_level=-1
# DEBUG VERBOSITY
# This option determines how verbose the debug log out will be.
# Values: 0 = Brief output
# 1 = More detailed
# 2 = Very detailed
debug_verbosity=2
# DEBUG FILE
# This option determines where the daemon should write debugging information.
debug_file=/usr/local/nagios/var/ndo2db.debug
# MAX DEBUG FILE SIZE
# This option determines the maximum size (in bytes) of the debug file. If
# the file grows larger than this size, it will be renamed with a .old
# extension. If a file already exists with a .old extension it will
# automatically be deleted. This helps ensure your disk space usage doesn't
# get out of control when debugging.
max_debug_file_size=1000000Code: Select all
# NDOMOD CONFIG FILE
# Last Modified: 09-05-2007
# INSTANCE NAME
# This option identifies the "name" associated with this particular
# instance of Nagios and is used to seperate data coming from multiple
# instances. Defaults to 'default' (without quotes).
instance_name=localhost
# OUTPUT TYPE
# This option determines what type of output sink the NDO NEB module
# should use for data output. Valid options include:
# file = standard text file
# tcpsocket = TCP socket
# unixsocket = UNIX domain socket (default)
#output_type=file
#output_type=tcpsocket
output_type=unixsocket
# OUTPUT
# This option determines the name and path of the file or UNIX domain
# socket to which output will be sent if the output type option specified
# above is "file" or "unixsocket", respectively. If the output type
# option is "tcpsocket", this option is used to specify the IP address
# of fully qualified domain name of the host that the module should
# connect to for sending output.
#output=/usr/local/nagios/var/ndo.dat
#output=127.0.0.1
output=/usr/local/nagios/var/ndo.sock
# TCP PORT
# This option determines what port the module will connect to in
# order to send output. This option is only valid if the output type
#tcp_port=5668
# ENCRYPTION
# This option determines if the module will use SSL to encrypt the
use_ssl=0
# OUTPUT BUFFER
# This option determines the size of the output buffer, which will help
# prevent data from getting lost if there is a temporary disconnect from
# the data sink. The number of items specified here is the number of
# lines (each of variable size) of output that will be buffered.
output_buffer_items=5000
# BUFFER FILE
# This option is used to specify a file which will be used to store the
# contents of buffered data which could not be sent to the NDO2DB daemon
# before Nagios shuts down. Prior to shutting down, the NDO NEB module
# will write all buffered data to this file for later processing. When
# Nagios (re)starts, the NDO NEB module will read the contents of this
# file and send it to the NDO2DB daemon for processing.
buffer_file=/usr/local/nagios/var/ndomod.tmp
# FILE ROTATION INTERVAL
# This option determines how often (in seconds) the output file is
# rotated by Nagios. File rotation is handled by Nagios by executing
# the command defined by the file_rotation_command option. This
# option has no effect if the output_type option is a socket.
file_rotation_interval=14400
# FILE ROTATION COMMAND
# This option specified the command (as defined in Nagios) that is
# used to rotate the output file at the interval specified by the
# file_rotation_interval option. This option has no effect if the
# output_type option is a socket.
# See the file 'misccommands.cfg' for an example command definition
# that you can use to rotate the log file.
#file_rotation_command=rotate_ndo_log
# FILE ROTATION TIMEOUT
# This option specified the maximum number of seconds that the file
# rotation command should be allowed to run before being prematurely
# terminated.
file_rotation_timeout=60
# RECONNECT INTERVAL
# This option determines how often (in seconds) that the NDO NEB
# module will attempt to re-connect to the output file or socket if
# a connection to it is lost.
reconnect_interval=15
# RECONNECT WARNING INTERVAL
# This option determines how often (in seconds) a warning message will
# be logged to the Nagios log file if a connection to the output file
# or socket cannot be re-established.
reconnect_warning_interval=15
#reconnect_warning_interval=900
# DATA PROCESSING OPTIONS
# These options determine what data the NDO NEB Module will process
data_processing_options=-1
acknowledgement_data=1
adaptive_contact_data=1
adaptive_host_data=1
adaptive_program_data=1
adaptive_service_data=1
aggregated_status_data=1
comment_data=1
contact_status_data=1
downtime_data=1
event_handler_data=1
external_command_data=1
flapping_data=1
host_check_data=1
host_status_data=1
log_data=1
main_config_data=1
notification_data=1
object_config_data=0
process_data=1
program_status_data=1
retention_data=1
service_check_data=1
service_status_data=1
statechange_data=1
system_command_data=1
timed_event_data=1
# CONFIG OUTPUT OPTION
# This option determines what types of configuration data the NDO
# NEB module will dump from Nagios. Values can be OR'ed together.
# Values:
# 0 = Don't dump any configuration information
# 1 = Dump only original config (from config files)
# 2 = Dump config only after retained information has been restored
# 3 = Dump both original and retained configuration
config_output_options=2Code: Select all
[1429533977] Nagios 4.0.8 starting... (PID=3067)
[1429533977] Local time is Mon Apr 20 15:46:17 MSK 2015
[1429533977] LOG VERSION: 2.0
[1429533977] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1429533977] qh: core query handler registered
[1429533977] nerd: Channel hostchecks registered successfully
[1429533977] nerd: Channel servicechecks registered successfully
[1429533977] nerd: Channel opathchecks registered successfully
[1429533977] nerd: Fully initialized and ready to rock!
[1429533977] wproc: Successfully registered manager as @wproc with query handler
[1429533977] wproc: Registry request: name=Core Worker 3075;pid=3075
[1429533977] wproc: Registry request: name=Core Worker 3076;pid=3076
[1429533977] wproc: Registry request: name=Core Worker 3077;pid=3077
[1429533977] wproc: Registry request: name=Core Worker 3080;pid=3080
[1429533977] wproc: Registry request: name=Core Worker 3079;pid=3079
[1429533977] wproc: Registry request: name=Core Worker 3078;pid=3078
[1429533978] ndomod: NDOMOD 2.0.0 (02-28-2014) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
[1429533978] ndomod: Successfully connected to data sink. 196 items lost, 5000 queued items to flush.
mysql> select * from nagios_instances;
Empty set (0.00 sec)
