ndo2db don't write anything to datadase
adengin
Post by adengin »
Hello, guys!
I have been using Nagios 4.0.8 for a some time. Recently I have to install NDOUtils 2.0 to save all nagios data in database.
It have been installed without any errors. But ndo2db don't fill the database.
In the Nagios Log i see that NDOMOD starts properly:
[1427869955] ndomod: NDOMOD 2.0.0 (02-28-2014) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
[1427869955] ndomod: Successfully connected to data sink.  0 queued items to flush.
[1427869955] ndomod registered for process data
[1427869955] ndomod registered for timed event data
[1427869955] ndomod registered for log data'
[1427869955] ndomod registered for system command data'
[1427869955] ndomod registered for event handler data'
[1427869955] ndomod registered for notification data'
[1427869955] ndomod registered for service check data'
[1427869955] ndomod registered for host check data'
[1427869955] ndomod registered for comment data'
[1427869955] ndomod registered for downtime data'
[1427869955] ndomod registered for flapping data'
[1427869955] ndomod registered for program status data'
[1427869955] ndomod registered for host status data'
[1427869955] ndomod registered for service status data'
[1427869955] ndomod registered for adaptive program data'
[1427869955] ndomod registered for adaptive host data'
[1427869955] ndomod registered for adaptive service data'
[1427869955] ndomod registered for external command data'
[1427869955] ndomod registered for aggregated status data'
[1427869955] ndomod registered for retention data'
[1427869955] ndomod registered for contact data'
[1427869955] ndomod registered for contact notification data'
[1427869955] ndomod registered for acknowledgement data'
[1427869955] ndomod registered for contact status data'
[1427869955] ndomod registered for adaptive contact data'
[1427869955] Event broker module '/usr/local/nagios/bin/ndomod-4x.o' initialized successfully.
[1427869955] Successfully launched command file worker with pid 7527
[1427870144] ndomod: Error writing to data sink!  Some output may get lost...
[1427870144] ndomod: Please check remote ndo2db log, database connection or SSL Parameters
[1427870160] ndomod: Successfully reconnected to data sink!  0 items lost, 69 queued items to flush.
[1427870160] ndomod: Successfully flushed 69 queued items to data sink.
ndo2db is working:
root@nagios:~# ps aux | grep -v grep | grep "ndo2db"
nagios    7656  0.0  0.0   6848   528 ?        Ss   09:35   0:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
mysql is also working and i can connect to the nagios database with nagios credentials, but all tables is empty:
root@nagios:~# mysql -u nagios -p
Enter password:
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 112
Server version: 5.5.41-0+wheezy1-log (Debian)
Copyright (c) 2000, 2014, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> use nagios;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> SHOW GRANTS FOR nagios@localhost;
| Grants for nagios@localhost        |
| GRANT USAGE ON *.* TO 'nagios'@'localhost' IDENTIFIED BY PASSWORD '****************************' |
| GRANT ALL PRIVILEGES ON `nagios`.* TO 'nagios'@'localhost'                                                    |
2 rows in set (0.00 sec)
mysql> select * from nagios_instances;
Empty set (0.01 sec)
Here is my versions:
Linux version 3.2.0-4-686-pae ([email protected]) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.65-1+deb7u1
nagios-4.0.8
ndoutils-2.0.0
mysql-server 5.5.41-0
libmysqlclient-dev 5.5.41
Here is my config files:
nagios.cfg:
event_broker_options=-1
broker_module=/usr/local/nagios/bin/ndomod-4x.o config_file=/usr/local/nagios/etc/ndomod.cfg
ndomod.cfg:
instance_name=default
output_type=tcpsocket
output=127.0.0.1
tcp_port=5668
use_ssl=0
output_buffer_items=5000
buffer_file=/usr/local/nagios/var/ndomod.tmp
file_rotation_interval=14400
file_rotation_timeout=60
reconnect_interval=15
reconnect_warning_interval=15
acknowledgement_data=1
adaptive_contact_data=1
adaptive_host_data=1
adaptive_program_data=1
adaptive_service_data=1
aggregated_status_data=1
comment_data=1
contact_status_data=1
downtime_data=1
event_handler_data=1
external_command_data=1
flapping_data=1
host_check_data=1
host_status_data=1
log_data=1
main_config_data=1
notification_data=1
object_config_data=0
process_data=1
program_status_data=1
retention_data=1
service_check_data=1
service_status_data=1
statechange_data=1
system_command_data=1
timed_event_data=1
config_output_options=1
ndo2db.cfg:
lock_file=/usr/local/nagios/var/ndo2db.lock
ndo2db_user=nagios
ndo2db_group=*****
socket_type=tcp
tcp_port=5668
use_ssl=0
db_servertype=mysql
db_host=127.0.0.1
db_port=3306
db_name=nagios
db_prefix=nagios_
db_user=nagios
db_pass=******
max_timedevents_age=1440
max_systemcommands_age=10080
max_servicechecks_age=10080
max_hostchecks_age=10080
max_eventhandlers_age=44640
max_externalcommands_age=44640
max_notifications_age=44640
max_contactnotifications=44640
max_contactnotificationmethods=44640
max_logentries_age=129600
max_acknowledgements_age=44640
debug_level=-1
debug_verbosity=2
debug_file=/usr/local/nagios/var/ndo2db.debug
max_debug_file_size=1000000
Also I want to add that ndo2db.debug file is empty.
If i start tcpdump i see a traffic flow in tcp:5668 socket, but nothing in tcp:3306 socket.
Here is the file permissions:
root@nagios:~# ls -ls /usr/local/nagios/etc/
total 88
12 -rw-rw-r-- 1 nagios nagios 11945 Feb 13 12:26 cgi.cfg
 4 -rw-r--r-- 1 nagios nagcmd    50 Feb  2 17:22 htpasswd.users
48 -rw-rw-r-- 1 nagios nagios 45222 Mar 31 16:37 nagios.cfg
 8 -rwxrwxrwx 1 nagios nagios  4829 Apr  1 09:31 ndo2db.cfg
 8 -rw------- 1 nagios nagios  5104 Mar 31 20:15 ndomod.cfg
 4 drwxrwsr-x 2 nagios nagios  4096 Mar 31 20:17 objects
 4 -rw-rw---- 1 nagios nagios  1312 Feb  2 17:19 resource.cfg
root@nagios:~# ls -ls /usr/local/nagios/var/
total 1164
  4 drwxrwsr-x 2 nagios nagios   4096 Mar 31 23:59 archives
  4 -rw-r--r-- 1 nagios nagios   1527 Apr  1 09:32 nagios.configtest
  4 -rw-r--r-- 1 nagios nagios      5 Apr  1 09:32 nagios.lock
 40 -rw-r--r-- 1 nagios nagios  40193 Apr  1 09:51 nagios.log
  0 -rwxrwxrwx 1 nagios nagios      0 Mar 31 14:52 ndo2db.debug
  4 -rw-r--r-- 1 nagios nagios      5 Apr  1 09:35 ndo2db.lock
  4 -rw-r--r-- 1 nagios nagios      6 Mar 31 20:13 ndo2db.run
  0 -rw-r--r-- 1 nagios nagios      0 Apr  1 09:32 ndomod.tmp
212 -rw-r--r-- 1 nagios nagios 214522 Apr  1 09:32 objects.cache
212 -rw-r--r-- 1 nagios nagios 214522 Apr  1 09:32 objects.precache
336 -rw------- 1 nagios nagios 343342 Apr  1 09:32 retention.dat
  4 drwxrwsr-x 2 nagios nagcmd   4096 Apr  1 09:32 rw
  4 drwxrwsr-x 3 root   nagios   4096 Feb  2 17:19 spool
336 -rw-rw-r-- 1 nagios nagios 342232 Apr  1 09:53 status.dat
root@nagios:~# ls -la /usr/local/nagios/bin/
total 1612
drwxrwsr-x  2 nagios nagios   4096 Mar 31 17:45 .
drwxr-sr-x 11 root   staff    4096 Mar 25 17:18 ..
-rwxrwxr--  1 nagios nagios  38295 Mar 31 17:45 file2sock
-rwxrwxr--  1 nagios nagios  40359 Mar 31 17:45 log2ndo
-rwxrwxr--  1 nagios nagios 684440 Mar 23 12:14 nagios
-rwxrwxr--  1 nagios nagios  36876 Mar 23 12:14 nagiostats
-rwxr-xr-x  1 nagios nagios 276780 Mar 31 17:45 ndo2db
-rwxr-xr-x  1 nagios nagios 180239 Mar 30 18:16 ndomod-4x.o
-rwxr-xr-x  1 nagios nagios 180239 Mar 31 17:45 ndomod.o
-rwxrwxr-x  1 nagios nagios 143564 Mar  4 16:19 nrpe
-rwxrwxr--  1 nagios nagios  35383 Mar 31 17:45 sockdebug
I have no idea what to do next and how to solve this problem.
I would be grateful for any help!
Thank you!
jdalrymple
Skynet Drone
Re: ndo2db don't write anything to datadase
Post by jdalrymple »
Any reason you're using:
socket_type=tcp
instead of
socket_type=unix
And if so - is mysql definitely listening on 3306?
[jdalrymple@localhost etc]$ netstat -an | grep 3306
tcp        0      0 0.0.0.0:3306                0.0.0.0:*                   LISTEN
adengin
Post by adengin »
jdalrymple, thank you for your reply!
The reason i'm using tcp socket is just a test. I didn't know how to capture data flow in unix socket, so i decided to switch it to tcp. So I made sure that the ndomod transmits data to the ndo2db.
Mysql is working on tcp:3306
root@nagios:~# netstat -apn | grep 3306
tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      2864/mysqld
jdalrymple
Skynet Drone
It's a reach, but let's make sure that you can connect using mysql client to the TCP port:
[jdalrymple@localhost ~]$ echo "SHOW GRANTS;"  | mysql -u ndoutils -pPASSWORD nagios  --protocol=tcp --host=127.0.0.1 --port=3306
Grants for ndoutils@localhost
GRANT USAGE ON *.* TO 'ndoutils'@'localhost' IDENTIFIED BY PASSWORD 'XXXX'
GRANT ALL PRIVILEGES ON `nagios`.* TO 'ndoutils'@'localhost' WITH GRANT OPTION
Of course you'll have nagios where I have ndoutils.
adengin
Post by adengin »
jdalrymple, sure!
root@nagios:~# echo "SHOW GRANTS;"  | mysql -u nagios -p************** nagios  --protocol=tcp --host=127.0.0.1 --port=3306
GRANT USAGE ON *.* TO 'nagios'@'localhost' IDENTIFIED BY PASSWORD '*82802C50A7A5CDFDEA2653A1503FC4B8939C4047'
In your ndomod.cfg file, add the following to it
data_processing_options=-1
Change
to
config_output_options=2
Restart Nagios and see if the data populates the MYSQL database.
adengin
Post by adengin »
tgriep, thank you for reply!
I have been done it, but the database is still empty. ndo2db.debug is empty too.
root@nagios:/usr/local/nagios/etc# grep data_processing_options ndomod.cfg
root@nagios:/usr/local/nagios/etc# grep config_output_options ndomod.cfg
[1428009242] ndomod: NDOMOD 2.0.0 (02-28-2014) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
[1428009242] ndomod: Successfully connected to data sink.  0 queued items to flush.
[1428009242] ndomod registered for timed event data
[1428009242] ndomod registered for log data'
[1428009242] ndomod registered for system command data'
[1428009242] ndomod registered for event handler data'
[1428009242] ndomod registered for notification data'
[1428009242] ndomod registered for service check data'
[1428009242] ndomod registered for host check data'
[1428009242] ndomod registered for comment data'
[1428009242] ndomod registered for downtime data'
[1428009242] ndomod registered for flapping data'
[1428009242] ndomod registered for program status data'
[1428009242] ndomod registered for host status data'
[1428009242] ndomod registered for service status data'
[1428009242] ndomod registered for adaptive program data'
[1428009242] ndomod registered for adaptive host data'
[1428009242] ndomod registered for adaptive service data'
[1428009242] ndomod registered for external command data'
[1428009242] ndomod registered for aggregated status data'
[1428009242] ndomod registered for retention data'
[1428009242] ndomod registered for contact data'
[1428009242] ndomod registered for contact notification data'
[1428009242] ndomod registered for acknowledgement data'
[1428009242] ndomod registered for contact status data'
[1428009242] ndomod registered for adaptive contact data'
[1428009242] Event broker module '/usr/local/nagios/bin/ndomod-4x.o' initialized successfully.
Empty set (0.00 sec)
jdalrymple
Skynet Drone
In your post above it looked like 69 items got queued then flushed and nothing showed up - and that was weird.
Now things appear different in that it appears nothing is queued?
Anything going on with Nagios - is it running?
adengin
Post by adengin »
Any other ideas?
ssax
Dreams In Code
Post by ssax »
Please post the output of the following commands:
ls -l /usr/local/nagios/bin/ndo*
ls -l /usr/local/nagios/etc/nd*
service nagios restart
Then post the last 100 or so lines of your /usr/local/nagios/var/nagios.log file (in code tags).
