NSClient - ERROR: PDH Collection thread not running.
Re: NSClient - ERROR: PDH Collection thread not running.
The attachment is nsclient.ini
nsclient.ini- (12.55 KiB) Downloaded 315 times
It looks like the NSClientServer isn't enabled on your remote host and that is causing the issue.
Under this section in the nsclient.ini file
Add this line
Save it out and restart the nsclient++ service and see if that resolves it for you.
[/modules]Code: Select all
NSClientServer = 1Be sure to check out our Knowledgebase for helpful articles and solutions!
When I add the line:
NSClientServer = 1
It's OK now.
Thanks very much for all help.
NSClientServer = 1
It's OK now.
Glad to hear it worked, is there anything else we can do for you, or are we good to close this one?
Former Nagios Employee.
me.
me.
You can close the one issue, thanks very much.
