stderr: execvp(/usr/local/nagios/libexec/check_ping, ...) fa
al_orange
Re: stderr: execvp(/usr/local/nagios/libexec/check_ping, ...
Post by al_orange »
rkennedy wrote:After you ran ./configure --with-nagios-user=nagios --with-nagios-group=nagios, did you also run
make
make install
It looks like your plugins haven't been compiled yet.
Wow, we're in business! It worked! Okay, I followed the instructions again, this time with the make and make install.
So I am not receiving the error for the Nagios Server anymore...only the client now.
Nice!
I believe the reason why the other one isn't working is because it does not have a DNS entry for ora_linux7_xen2. Can you post the configuration file that has the host entry for ora_linux7_xen2?
It should look similar to -
define host {
        use                             linux-server
        host_name                       ora_linux7_xen2
        alias                           aliashere
        address                         iphere
        max_check_attempts              5
        notification_interval           30
al_orange
Post by al_orange »
rkennedy wrote:Nice!
define host {
        use                             linux-server
        alias                           aliashere
        address                         iphere
## Default Linux Host Template ##
name                            linux-box               ; Name of this template
use                             generic-host            ; Inherit default values
check_interval                  5
retry_interval                  1
max_check_attempts              10
check_command                   check-host-alive
notification_options            d,r
contact_groups                  admins
register                        0                       ; DONT REGISTER THIS - ITS A TEMPLATE
## Default
use                             linux-box               ; Inherit default values from a template
host_name                       ora_linux7_xen2.xyz.local  ; The name we're giving to this server
alias                           Oracle Linux 7          ; A longer name for the server address                                  172.17.40.152           ; IP address of Remote Linux host
Is this your full definition for the ora_linux7 host?
## Default
It seems you're missing a couple things. It should look like -
## Default
Make the change, restart the nagios service, and it should be working.
al_orange
Post by al_orange »
rkennedy wrote:Is this your full definition for the ora_linux7 host?
## Default
## Default
Yes, it's working now. Added address at the bottom lime with the IP address.
bwallace
Post by bwallace »
Glad to hear it is working now. Did you have any other questions, or may we lock this thread?
al_orange
Post by al_orange »
bwallace wrote:Glad to hear it is working now. Did you have any other questions, or may we lock this thread?
Yes, this issue has been resolved. Please lock this thread.
