Need some help with an Snmp Entry.
Re: Need some help with an Snmp Entry.
Hello ssax,
Attached this are the mib files from the Directory
But when i use the oid number i thought the mibs arent really necessary
regards john
regards john
- snmpt.tar
- (11.8 KiB) Downloaded 791 times
Nagios Core 3.5.1
Checkmk 1.2.4p5
Checkmk 1.2.4p5
Is that literally everything in your /usr/share/snmp/mibs directory? If so, you are missing all of the default MIBs.
Do i need the Default MIB's if my match is based only on the OID NumberIs that literally everything in your /usr/share/snmp/mibs directory? If so, you are missing all of the default MIBs.
regards skyerjoe
Nagios Core 3.5.1
Checkmk 1.2.4p5
Checkmk 1.2.4p5
No, you shouldn't if you are using the full OID.
Please run these commands and post the entire output:
Wait a couple seconds, then run:
service snmptt stop
snmptrap -v2c -cpublic 127.0.0.1 1431439518 .1.3.6.1.4.1.31440.0.6 .1.3.6.1.4.1.31440.2.2.1.1.5 i 2
cat /var/spool/snmptt/*
service snmptt startRe: Need some help with an Snmp Entry.
The output from the Cat command:
I think this is stil in place and correct
If i start snmptt and do it again the spooler is empty
Is also correct so far or ?
regards john
127.0.0.1
UDP: [127.0.0.1]:37000->[127.0.0.1]
.1.3.6.1.2.1.1.3.0 165:16:13:15.18
.1.3.6.1.6.3.1.1.4.1.0 .1.3.6.1.4.1.31440.0.6
.1.3.6.1.4.1.31440.2.2.1.1.5 2
regards john
Nagios Core 3.5.1
Checkmk 1.2.4p5
Checkmk 1.2.4p5
Yes, here is mine with the default MIBs installed:
You can see why I had to change mine as enterprises.31440.2.2.1.1.5
So MATCH $+1:(.1.3.6.1.4.1.31440.2.2.1.1.5:2) should have worked.
Please try this one (removed the first period):
localhost
UDP: [127.0.0.1]:34411->[127.0.0.1]
DISMAN-EVENT-MIB::sysUpTimeInstance 165:16:13:15.18
SNMPv2-MIB::snmpTrapOID.0 SNMPv2-SMI::enterprises.31440.0.6
SNMPv2-SMI::enterprises.31440.2.2.1.1.5 2So MATCH $+1:(.1.3.6.1.4.1.31440.2.2.1.1.5:2) should have worked.
MATCH $+1:(1.3.6.1.4.1.31440.2.2.1.1.5:2)Re: Need some help with an Snmp Entry.
Hello Everybody
Yes i know the thread is a little bit old but the error is still present...
@ssax:
I tried this also but this doesn't working anymore:
Tried also this without brackets ....
In think i have to try out a really simple trigger which has an binding maybe there is some ... Schema or sth. like that changed in an snmptt version ... so i think i need an more basic value with an basic Varable Binding
Any ideas ?
reagards john
@ssax:
MATCH $+1:(1.3.6.1.4.1.31440.2.2.1.1.5:2)In think i have to try out a really simple trigger which has an binding maybe there is some ... Schema or sth. like that changed in an snmptt version ... so i think i need an more basic value with an basic Varable Binding
Any ideas ?
reagards john
Nagios Core 3.5.1
Checkmk 1.2.4p5
Checkmk 1.2.4p5
Try to add all of these to your singe trap definition, when you have multiple MATCH statements on a single trap definition it acts as an OR statement to see if it meets the criteria (this is modifiable through other SNMPTT options):
Also, please check all files in /etc/snmp and /usr/share/snmp/mibs/processed_mibs to make sure you don't have any duplicate definitions.
Thank you
MATCH $+1:(enterprises.31440.2.2.1.1.5)Thank you
Hello ssax
I set all 3 Matches and running against the snmp services.
I checked /etc/snmp and in the snmptt.ini is no double entry for the confile
Only these 2 lines :
In the Directory /usr/share/snmp/mibs/processed_mibs they're no mibs at all
The Traps are still only coming in the unknown snmp section:
The xxx Values are just ip's
... Either there is some big mistake in an configuration or my System is kaput in any way
regards john
/etc/snmp/snmptt.conf.generic
/etc/snmp/snmptt.conf.owserverwatertest1line ( this is the one i use )The Traps are still only coming in the unknown snmp section:
Thu Aug 25 15:42:54 2016: Unknown trap (.1.3.6.1.4.1.31440.0.6) received from xxx.xxx.xxx.xxx at:
Value 0: xxx.xxx.xxx.xxx
Value 1: xxx.xxx.xxx.xxx
Value 2: 198:7:38:26.95
Value 3: .1.3.6.1.4.1.31440.0.6
Value 4: xxx.xxx.xxx.xxx
Value 5: public
Value 6: .1.3.6.1.4.1.31440
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: .1.3.6.1.4.1.31440.2.2.1.1.5=2
Thu Aug 25 15:42:56 2016: Unknown trap (.1.3.6.1.4.1.31440.0.6) received from xxx.xxx.xxx.xxx at:
Value 2: 198:10:25:26.22
Value 5: public
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: .1.3.6.1.4.1.31440.2.2.1.1.5=1... Either there is some big mistake in an configuration or my System is kaput in any way
regards john
Nagios Core 3.5.1
Checkmk 1.2.4p5
Checkmk 1.2.4p5
What version of SNMPTT are you running?
