Install failure
Re: Install failure
I am guessing that the satellite server has the repo dependencies incorrect and they would have to repair them before you can go further.
You could try and removing the conflicting packages and then disable those repos and use the default ones but you would have to get your ISP to allow that.
Bionic___
Re: Install failure
Post by Bionic___ »
I got the install working by removing conflicting packages.
It was the basic "localhost" configruation.
I restored my current system to the new system using the Nagios restore instructions pdf and everything seemed there and working except when I changed a service and applied configuration, it hangs and does not complete.
So I no longer have an install failure. Should I close this thread and open a new topic for my configuration?
I had a problem with applying configuration several years ago and I followed those instructions and they did not work.
Re: Install failure
Yes, let's keep these issues in separate threads. Please start a new thread to deal with the applying configuration issue. Explain in details what have you tried so far to troubleshoot/fix the problem. Thanks!
