Logs not reporting again
Re: Logs not reporting again
Post by Box293 »
kwhogster wrote:1. What do I put for the node?
ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c
kwhogster wrote:2. What about logstash?
They may also need to be done, or they may auto-correct themselves. Fixing the one I highlighted should allow you to log into the interface.
kwhogster
Post by kwhogster »
Troy
ran this
curl -XPOST 'localhost:9200/_cluster/reroute' -d '{ "commands" : [ { "allocate" : { "index" : "nagioslogserver", "shard" : 0, "node" : "ceb4a326-c1f0-4e7a-b8e4-1796edfbb25c", "allow_primary" : true } } ] }'
A ton of messages came out
Trying to access the site takes a very long time now.
Ran this
[root@TGCS018 /]# curl -s -XGET http://localhost:9200/_cat/shards?v | egrep 'UNASSIGNED|INITIALIZING' logstash-2016.09.17 4 p UNASSIGNED
logstash-2016.09.17 4 r UNASSIGNED
logstash-2016.09.17 0 r UNASSIGNED
logstash-2016.09.17 3 p UNASSIGNED
logstash-2016.09.17 3 r UNASSIGNED
logstash-2016.09.17 1 r UNASSIGNED
logstash-2016.09.17 2 p UNASSIGNED
logstash-2016.09.17 2 r UNASSIGNED
logstash-2016.09.13 2 r UNASSIGNED
logstash-2016.09.13 0 r UNASSIGNED
logstash-2016.09.13 3 p UNASSIGNED
logstash-2016.09.13 3 r UNASSIGNED
logstash-2016.09.13 1 r UNASSIGNED
logstash-2016.09.13 4 r UNASSIGNED
nagioslogserver 0 r UNASSIGNED
nagioslogserver 0 p UNASSIGNED
logstash-2016.09.15 2 p UNASSIGNED
logstash-2016.09.15 2 r UNASSIGNED
logstash-2016.09.15 0 p UNASSIGNED
logstash-2016.09.15 0 r UNASSIGNED
logstash-2016.09.15 3 r UNASSIGNED
logstash-2016.09.15 1 r UNASSIGNED
logstash-2016.09.15 4 r UNASSIGNED
logstash-2016.09.12 4 r UNASSIGNED
logstash-2016.09.12 0 r UNASSIGNED
logstash-2016.09.12 3 r UNASSIGNED
logstash-2016.09.12 1 p UNASSIGNED
logstash-2016.09.12 1 r UNASSIGNED
logstash-2016.09.12 2 r UNASSIGNED
nagioslogserver_log 4 p UNASSIGNED
nagioslogserver_log 4 r UNASSIGNED
nagioslogserver_log 0 p UNASSIGNED
nagioslogserver_log 0 r UNASSIGNED
nagioslogserver_log 3 r UNASSIGNED
nagioslogserver_log 1 r UNASSIGNED
nagioslogserver_log 2 p UNASSIGNED
nagioslogserver_log 2 r UNASSIGNED
logstash-2016.08.25 4 r UNASSIGNED
logstash-2016.08.25 0 p UNASSIGNED
logstash-2016.08.25 0 r UNASSIGNED
logstash-2016.08.25 3 p UNASSIGNED
logstash-2016.08.25 3 r UNASSIGNED
logstash-2016.08.25 1 r UNASSIGNED
logstash-2016.08.25 2 r UNASSIGNED
logstash-2016.08.26 2 r UNASSIGNED
logstash-2016.08.26 0 r UNASSIGNED
logstash-2016.08.26 3 p UNASSIGNED
logstash-2016.08.26 3 r UNASSIGNED
logstash-2016.08.26 1 r UNASSIGNED
logstash-2016.08.26 4 r UNASSIGNED
logstash-2016.08.23 2 r UNASSIGNED
logstash-2016.08.23 0 r UNASSIGNED
logstash-2016.08.23 3 r UNASSIGNED
logstash-2016.08.23 1 r UNASSIGNED
logstash-2016.08.23 4 r UNASSIGNED
logstash-2016.08.24 2 p UNASSIGNED
logstash-2016.08.24 2 r UNASSIGNED
logstash-2016.08.24 0 r UNASSIGNED
logstash-2016.08.24 3 r UNASSIGNED
logstash-2016.08.24 1 r UNASSIGNED
logstash-2016.08.24 4 r UNASSIGNED
logstash-2016.08.29 2 r UNASSIGNED
logstash-2016.08.29 0 r UNASSIGNED
logstash-2016.08.29 3 r UNASSIGNED
logstash-2016.08.29 1 p UNASSIGNED
logstash-2016.08.29 1 r UNASSIGNED
logstash-2016.08.29 4 r UNASSIGNED
logstash-2016.08.27 4 p UNASSIGNED
logstash-2016.08.27 4 r UNASSIGNED
logstash-2016.08.27 0 p UNASSIGNED
logstash-2016.08.27 0 r UNASSIGNED
logstash-2016.08.27 3 r UNASSIGNED
logstash-2016.08.27 1 p UNASSIGNED
logstash-2016.08.27 1 r UNASSIGNED
logstash-2016.08.27 2 r UNASSIGNED
logstash-2016.08.28 2 p UNASSIGNED
logstash-2016.08.28 2 r UNASSIGNED
logstash-2016.08.28 0 r UNASSIGNED
logstash-2016.08.28 3 r UNASSIGNED
logstash-2016.08.28 1 r UNASSIGNED
logstash-2016.08.28 4 r UNASSIGNED
logstash-2016.08.21 2 p UNASSIGNED
logstash-2016.08.21 2 r UNASSIGNED
logstash-2016.08.21 0 r UNASSIGNED
logstash-2016.08.21 3 r UNASSIGNED
logstash-2016.08.21 1 r UNASSIGNED
logstash-2016.08.21 4 r UNASSIGNED
logstash-2016.08.22 2 p UNASSIGNED
logstash-2016.08.22 2 r UNASSIGNED
logstash-2016.08.22 0 r UNASSIGNED
logstash-2016.08.22 3 p UNASSIGNED
logstash-2016.08.22 3 r UNASSIGNED
logstash-2016.08.22 1 r UNASSIGNED
logstash-2016.08.22 4 r UNASSIGNED
logstash-2016.08.20 4 p UNASSIGNED
logstash-2016.08.20 4 r UNASSIGNED
logstash-2016.08.20 0 r UNASSIGNED
logstash-2016.08.20 3 p UNASSIGNED
logstash-2016.08.20 3 r UNASSIGNED
logstash-2016.08.20 1 r UNASSIGNED
logstash-2016.08.20 2 r UNASSIGNED
logstash-2016.09.06 2 p UNASSIGNED
logstash-2016.09.06 2 r UNASSIGNED
logstash-2016.09.06 0 r UNASSIGNED
logstash-2016.09.06 3 r UNASSIGNED
logstash-2016.09.06 1 r UNASSIGNED
logstash-2016.09.06 4 p UNASSIGNED
logstash-2016.09.06 4 r UNASSIGNED
logstash-2016.09.04 2 r UNASSIGNED
logstash-2016.09.04 0 r UNASSIGNED
logstash-2016.09.04 3 r UNASSIGNED
logstash-2016.09.04 1 r UNASSIGNED
logstash-2016.09.04 4 r UNASSIGNED
logstash-2016.09.05 4 p UNASSIGNED
logstash-2016.09.05 4 r UNASSIGNED
logstash-2016.09.05 0 p UNASSIGNED
logstash-2016.09.05 0 r UNASSIGNED
logstash-2016.09.05 3 r UNASSIGNED
logstash-2016.09.05 1 r UNASSIGNED
logstash-2016.09.05 2 r UNASSIGNED
logstash-2016.09.02 4 r UNASSIGNED
logstash-2016.09.02 0 r UNASSIGNED
logstash-2016.09.02 3 p UNASSIGNED
logstash-2016.09.02 3 r UNASSIGNED
logstash-2016.09.02 1 r UNASSIGNED
logstash-2016.09.02 2 r UNASSIGNED
logstash-2016.09.03 4 r UNASSIGNED
logstash-2016.09.03 0 r UNASSIGNED
logstash-2016.09.03 3 r UNASSIGNED
logstash-2016.09.03 1 r UNASSIGNED
logstash-2016.09.03 2 r UNASSIGNED
logstash-2016.09.01 4 r UNASSIGNED
logstash-2016.09.01 0 p UNASSIGNED
logstash-2016.09.01 0 r UNASSIGNED
logstash-2016.09.01 3 r UNASSIGNED
logstash-2016.09.01 1 p UNASSIGNED
logstash-2016.09.01 1 r UNASSIGNED
logstash-2016.09.01 2 r UNASSIGNED
logstash-2016.08.09 2 p UNASSIGNED
logstash-2016.08.09 2 r UNASSIGNED
logstash-2016.08.09 0 r UNASSIGNED
logstash-2016.08.09 3 r UNASSIGNED
logstash-2016.08.09 1 r UNASSIGNED
logstash-2016.08.09 4 r UNASSIGNED
logstash-2016.08.12 4 r UNASSIGNED
logstash-2016.08.12 0 r UNASSIGNED
logstash-2016.08.12 3 r UNASSIGNED
logstash-2016.08.12 1 p UNASSIGNED
logstash-2016.08.12 1 r UNASSIGNED
logstash-2016.08.12 2 r UNASSIGNED
logstash-2016.08.13 2 p UNASSIGNED
logstash-2016.08.13 2 r UNASSIGNED
logstash-2016.08.13 0 r UNASSIGNED
logstash-2016.08.13 3 r UNASSIGNED
logstash-2016.08.13 1 r UNASSIGNED
logstash-2016.08.13 4 p UNASSIGNED
logstash-2016.08.13 4 r UNASSIGNED
logstash-2016.08.14 2 r UNASSIGNED
logstash-2016.08.14 0 r UNASSIGNED
logstash-2016.08.14 3 r UNASSIGNED
logstash-2016.08.14 1 p UNASSIGNED
logstash-2016.08.14 1 r UNASSIGNED
logstash-2016.08.14 4 r UNASSIGNED
logstash-2016.08.15 2 p UNASSIGNED
logstash-2016.08.15 2 r UNASSIGNED
logstash-2016.08.15 0 r UNASSIGNED
logstash-2016.08.15 3 r UNASSIGNED
logstash-2016.08.15 1 p UNASSIGNED
logstash-2016.08.15 1 r UNASSIGNED
logstash-2016.08.15 4 r UNASSIGNED
logstash-2016.08.16 2 p UNASSIGNED
logstash-2016.08.16 2 r UNASSIGNED
logstash-2016.08.16 0 r UNASSIGNED
logstash-2016.08.16 3 r UNASSIGNED
logstash-2016.08.16 1 r UNASSIGNED
logstash-2016.08.16 4 r UNASSIGNED
logstash-2016.08.17 4 p UNASSIGNED
logstash-2016.08.17 4 r UNASSIGNED
logstash-2016.08.17 0 r UNASSIGNED
logstash-2016.08.17 3 r UNASSIGNED
logstash-2016.08.17 1 r UNASSIGNED
logstash-2016.08.17 2 r UNASSIGNED
logstash-2016.08.18 2 p UNASSIGNED
logstash-2016.08.18 2 r UNASSIGNED
logstash-2016.08.18 0 r UNASSIGNED
logstash-2016.08.18 3 r UNASSIGNED
logstash-2016.08.18 1 r UNASSIGNED
logstash-2016.08.18 4 r UNASSIGNED
logstash-2016.08.19 2 p UNASSIGNED
logstash-2016.08.19 2 r UNASSIGNED
logstash-2016.08.19 0 p UNASSIGNED
logstash-2016.08.19 0 r UNASSIGNED
logstash-2016.08.19 3 r UNASSIGNED
logstash-2016.08.19 1 r UNASSIGNED
logstash-2016.08.19 4 r UNASSIGNED
logstash-2016.08.30 2 r UNASSIGNED
logstash-2016.08.30 0 r UNASSIGNED
logstash-2016.08.30 3 p UNASSIGNED
logstash-2016.08.30 3 r UNASSIGNED
logstash-2016.08.30 1 r UNASSIGNED
logstash-2016.08.30 4 r UNASSIGNED
logstash-2016.08.31 4 r UNASSIGNED
logstash-2016.08.31 0 p UNASSIGNED
logstash-2016.08.31 0 r UNASSIGNED
logstash-2016.08.31 3 r UNASSIGNED
logstash-2016.08.31 1 r UNASSIGNED
logstash-2016.08.31 2 r UNASSIGNED
kibana-int 4 r UNASSIGNED
kibana-int 0 r UNASSIGNED
kibana-int 3 p UNASSIGNED
kibana-int 3 r UNASSIGNED
kibana-int 1 r UNASSIGNED
kibana-int 2 r UNASSIGNED
logstash-2016.08.10 4 p UNASSIGNED
logstash-2016.08.10 4 r UNASSIGNED
logstash-2016.08.10 0 r UNASSIGNED
logstash-2016.08.10 3 p UNASSIGNED
logstash-2016.08.10 3 r UNASSIGNED
logstash-2016.08.10 1 p UNASSIGNED
logstash-2016.08.10 1 r UNASSIGNED
logstash-2016.08.10 2 r UNASSIGNED
logstash-2016.08.11 4 r UNASSIGNED
logstash-2016.08.11 0 r UNASSIGNED
logstash-2016.08.11 3 p UNASSIGNED
logstash-2016.08.11 3 r UNASSIGNED
logstash-2016.08.11 1 r UNASSIGNED
logstash-2016.08.11 2 r UNASSIGNED
[root@TGCS018 /]#
Do I need to re assign all of these? by the number after the name ???
UPDATE UPDATE
I restarted the server
I got the same error as I first reported in the issue. Finally the signon screen came back after about 10 minutes.
Now I can not logon error could not get user specified id maybe wrong
using nagiosadmin
What is up with this product. seems very unstable to me
Help
Post by Box293 »
I suggest adding another 8GB memory to the server and see if that helps.
kwhogster
Post by kwhogster »
Troy
increased ram to 16 GB which is double from 8 GB
Same results still can not access logserver
Could not get user. Specified ID may be wrong.
Also extremely slow to access takes long time to present the logon screen
kwhogster
Post by kwhogster »
To All
I think I know what the problem is now.
[root@TGCS018 ~]# df -h
/dev/mapper/centos-root 50G 50G 20K 100% /
devtmpfs 7.7G 0 7.7G 0% /dev
tmpfs 7.8G 0 7.8G 0% /dev/shm
tmpfs 7.8G 8.6M 7.7G 1% /run
tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup
/dev/mapper/centos-home 26G 33M 26G 1% /home
/dev/sda1 497M 123M 375M 25% /boot
tmpfs 1.6G 0 1.6G 0% /run/user/0
tmpfs 1.6G 0 1.6G 0% /run/user/1001
[root@TGCS018 ~]#
Look at root file system it is 100 %
What did logserver do to fill up this file system???
Log server requires disk space to operate. I'm guessing you dumped quite a bit of logs into it?
Running out of disk space is catastrophic in NLS terms, and some times unrecoverable. You'll want to increase the disk space as soon as possible to correct this.
Post by Box293 »
Here's how to add disk space if you've used the VM provided by us.
https://support.nagios.com/kb/article.php?id=486
kwhogster
Post by kwhogster »
Troy,
Two things.
1. What VM provide by us? please provide link to that and I will rebuild that VM
2. The instructions were good but the VM when I go to Edit Settings with the VM powered off the Disk provisioning settings are greyed out I can not modify them
One Last thing
Where are all the files that NLS stores located? I can delete them
Is there a way to tell NLS where to put the files?
I can add additional storage on this VM just can not modify the original disk
Post by Box293 »
kwhogster wrote:1. What VM provide by us? please provide link to that and I will rebuild that VM
The VM that can be downloaded here.
http://library.nagios.com/library/produ ... /downloads
kwhogster wrote:2. The instructions were good but the VM when I go to Edit Settings with the VM powered off the Disk provisioning settings are greyed out I can not modify them
Perhaps your VM has an active snapshot, you cannot increase the size of a virtual disk if a snapshot currently exists.
kwhogster wrote:Where are all the files that NLS stores located? I can delete them
/usr/local/nagioslogserver/elasticsearch/
I would not try and delete them, they are part of the elasticsearch database.
kwhogster wrote:Is there a way to tell NLS where to put the files?
You could move /usr/local to another partition. This guide explains how to move /var/log and could be easily adapted to move /usr/local
https://support.nagios.com/kb/article.php?id=473
Post by mcapra »
Split post into the following thread: https://support.nagios.com/forum/viewto ... =6&t=39489
